Lexmoto xtr125
Mini Stalk
PostPosted: 10:07 - 11 Jan 2012    Post subject: Lexmoto xtr125 Reply with quote
Hi guys, if all goes well on thursday i am getting my hands on a 2010 plate Lexmoto xtr125 and was just woundering what you guys think on them
Thanks
Dave
PostPosted: 10:11 - 11 Jan 2012    Post subject: Re: Lexmoto xtr125 Reply with quote
Thanks
Dave
One of the better makers of Chinese 125s, although that's like saying The Plague one of the better medieval diseases. Thumbs Up
In all seriousness some seem to be getting a bit better now, so just hope you've got a semi-decent one. Still assume it's going to fall to bits, and I'd suggest a CG125 over one any day of the week.
Mini Stalk
PostPosted: 10:19 - 11 Jan 2012    Post subject: Reply with quote
Yea have been trying to hunt somthing out a little more reliable but found nohing in my price range really, then this poped up very cheep.
To be honnest id jump at another yamaha sr.
I have been looking though google and trying to find out about them but not having a great deal of luck Sad
DrDonnyBrago
PostPosted: 10:22 - 11 Jan 2012    Post subject: Re: Lexmoto xtr125 Reply with quote
Thanks
Dave
As above, lexmoto are supposed to be one of the better Chinese brands but for what a 2010 plate chink bike will cost you, an older jap bike will probably be a better bet.
They cost what, £900ish? You can get jap bikes for that, I'd much rather have an older CBR if I wanted fairings or a CG/YBR/GS if I didn't. TBH better still would be to get something as cheap as possible to do your tests on and get out of the expensive learner legal bike bracket and onto something bigger.
Mini Stalk
PostPosted: 10:29 - 11 Jan 2012    Post subject: Re: Lexmoto xtr125 Reply with quote
DonnyBrago wrote:
Thanks
Dave
Im picking this one up for £250 and need a little cosmetic work, apparntly mecanily sound. Im going to see the bike tomorrow and check it over.
Is there anythink you guy think i should keep a real close out out for?
PostPosted: 10:32 - 11 Jan 2012    Post subject: Re: Lexmoto xtr125 Reply with quote
Check everything.
Check the frame or cracks and corrosion. Missing vital bolts, noisy engines, dodgey electrics, leaking brakes. Check it over with the finest toothed comb you can find and use any defect as a major haggling point.
Mini Stalk
PostPosted: 10:43 - 11 Jan 2012    Post subject: Re: Lexmoto xtr125 Reply with quote
Check everything.
Ok, but other than them being chinise, if you can get hold of a good one what are they like?
PostPosted: 10:55 - 11 Jan 2012    Post subject: Reply with quote
If you don't mind...what was your budget?
Example - £500 could have got you a tatty jap 125, needs a little love and paint but will run for a while with no major trouble.
My £500 chinese bike started rusting (58 plate) and bolts snapped, exhaust shield fell off....then it got stolen Laughing
Mini Stalk
PostPosted: 11:27 - 11 Jan 2012    Post subject: Reply with quote
My budget was £350 but that included insurance too.
Dam Paddy i just seen your post about your crash. Hope your ok.
UnspeedySam
PostPosted: 11:38 - 11 Jan 2012    Post subject: Reply with quote
To be fair though. For £250 I'd have it. It's just over a year old!
What brand was your Chinese bike? They do seem to vary wildly in quality from brand to brand.
DrDonnyBrago
PostPosted: 11:57 - 11 Jan 2012    Post subject: Reply with quote
£250 isn't a lot of cash to be fair, that said small things can quickly mount up. Rusty fork stanchions for example need replacing, which is never cheap. Warped discs, shagged out brake calipers, rusty downpipes, bearings etc etc can quickly add up and your bargain is no longer a bargain.
Check for oil on the stanchions, rust on the stanchions (the chromed tubes that go into the fork bottoms), check the brakes for binding by spinning the wheels. Check the bearings in the wheels and swingarm by tugging the wheels back and forth and trying to move them sideways, any play in the wheel or rear end is bad. Do the same on the front, check for play in the forks and wheel. Also get the front wheel off the ground and turn the bars to full lock both sides, check there is no crunchy sounds and that they turn freely, no tight or loose spots. Check the chain and sprockets for wear, really pointy sprocket teeth will mean it all needs replacing, check the rear shock(s?) for leaks and have a sit and a bounce on it.
As for the engine, tappy sounds might be ok, check for exhaust leaks and try and see where the noise is coming from - could be loose valves that are easily adjusted on smaller bikes, could be something worse. Knocking and clunking sounds are bad. Check for stupid amounts of rust on fasteners, can be a royal pain in the ass to sort when they seize and then snap off.
Test ride it.
PostPosted: 12:03 - 11 Jan 2012    Post subject: Reply with quote
Someone stole it? I bet you rejoiced! Laughing
Compared to a Japanese bike, crap (at the moment). As I say Lexmoto are meant to be one of the better ones, but I'd still avoid and save up more money for a CG or something.
UnspeedySam
PostPosted: 12:09 - 11 Jan 2012    Post subject: Reply with quote
If it checks out on closer inspection on all the points mentioned by DonnyBrago then as a ride it, pass test and sell it bike I reckon you could actually make a profit. However if you plan on keeping it more than a couple of years I would consider something a bit more solid.
My friend just bought a 1982 Honda CM125 and the thing has barely got any rust on it and runs like clockwork (came with new pistons and rings). He did pay over the odds (£550) but I think he'll be able to sell it in the summer for the money he paid.
jjdugen
PostPosted: 12:23 - 11 Jan 2012    Post subject: Reply with quote
I'd love to know where all these 'bombproof' Jap 125's are. Everytime I've had one in they suffer:- Rusty exhaust, pitting on fork legs, general canker of paintwork, rusty rims, crap wiring. Thats before dealing with rattly cam chains, failing ECU's and the usual rusty drive chain and hooked sprockets.
They were made to a budget too. The Chinks I've seen or worked on were no better, no worse, in fact, start with the premise that they are ALL crap and have been hammered into the ground and you wont go far wrong.
PostPosted: 12:33 - 11 Jan 2012    Post subject: Reply with quote
I wasn't too upset Laughing
Mini Stalk, I'm alright thanks Thumbs Up
PostPosted: 12:38 - 11 Jan 2012    Post subject: Reply with quote
Lexmoto doesn't make anything, that's a Skyjet SJ125-24, which is also just a branding of whatever WhangDong Speedly Good Bike it was originally manufactured as.
The 156FMI engine should be the most robust bit, although it'll hardly set your pulse racing. It's the ancient air cooled pushrod design from the CG125 (tucked away behind fairings) so if you try and ride it like it were a real CBR125, you'll likely cook it and bend a pushrod or shag the gearbox. Oil change early and often, treat it as a pretty commuter, don't expect or try to get more than a sustained 55mph out of it.
Definitely give the frame, cycle parts and electrics a good check over. Pay particular attention to the exhaust mounting bolts which are prone to coming loose or snapping. In fact, check every nut and bolt for security, and add spring washers and Loctite as required.
Although all that said, for £250 you could just part it out if it's a dog.
truslack
PostPosted: 12:43 - 11 Jan 2012    Post subject: Reply with quote
For £250 you should find a decent Japanese 2 stroke 100cc Commuter.
UnspeedySam
PostPosted: 13:11 - 11 Jan 2012    Post subject: Reply with quote
I wouldn't sell my beloved RXS for that but you might be able to find a slightly tatty H100 or something.
Mini Stalk
PostPosted: 10:49 - 12 Jan 2012    Post subject: Reply with quote
sorry for no replys we ended up going to look at it yesterday.
We got there and it was mint really, started up first time, no rust, everythink worked, no rattels from the engine. the only think with it was were it has been in a slight spank the bars not streght with the frount wheel, but im hoping if i undo the bolts move the bars round every think sould be ok, it did say on advert that the bars were off, i just didnt read it right, :/ but other than that really its mint, other than it being chinese i cant really falt it. even half a tank of fule Smile
nowhere.elysium
The Pork Lord
PostPosted: 11:00 - 12 Jan 2012    Post subject: Reply with quote
Wouldn't bother trying to straighten the bars; they'll only be a few quid to replace.
If it's that tidy, then make sure that you stay on top of corrosion treatment, and it should do you OK for a while.
This forum's played host to many horror stories about CHinese bikes, but also, it's had a few that've been OK. I've had mine since 2008, and it's been fine. Having said that, I'm expecting to sell it tomorrow Laughing
gg
PostPosted: 22:12 - 17 Jan 2012    Post subject: Reply with quote
This thread is putting me off the idea of chinese bikes. my first bike was a lifan 125, which was stolen, after the foot peg started falling off the first week. though that could be due to who built it rather than the quality of bike. anyone know of the time they last before rusting?
The last post was made 14 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 118.97 Kb
