Taking swing arm off - how to
grant965
PostPosted: 16:48 - 11 Jan 2012    Post subject: Taking swing arm off - how to Reply with quote
Hey, need to get at suspension because the bearing (or w/e its called) needs replacing. Thinking I may aswell take most of rear off to clean up and respray but how can I support my bike whilst the rear is off?
thanks
Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R
daemonoid
PostPosted: 16:53 - 11 Jan 2012    Post subject: Reply with quote
What bike is it? Mostly you can just put an old towel down and rest it upright on that. Maybe also take the front wheel off to counter the lean angle if necessary.
current: ducati monster 750
daemonoid
PostPosted: 17:10 - 11 Jan 2012    Post subject: Reply with quote
My description was a bit shoddy I added an image (ignore the sub frame and stand). Remove the plastic pointed to by the red arrow. Then there *should* be a flatish bit pointed to by the yellow arrow where you can balance it for a while.
https://www.bikechatforums.com/download.php?id=82057
That's assuming you don't have a centre stand of course:
https://www.rolandbeverley.is-a-geek.com/blog/wp-content/uploads/2011/08/No_rear_wheel.jpg
PostPosted: 17:14 - 11 Jan 2012    Post subject: Reply with quote
To remove the one on the GSXR all I did was a few bricks stacked with plank of wood slid under it. Jacked up on the sump iwht a car jack and lowered onto the wood to keep rear off the floor.
Loosen the bolts before raising off the floor Thumbs Up
grant965
PostPosted: 17:28 - 11 Jan 2012    Post subject: Reply with quote
cheers for the replies, its a yammie thundercat so not a light bike due to the thick steel frame Sad
How do i paint the swing arm? Same as fairings, i.e coats of primer (can i use same stuff?) then colour?
thanks
Nope.
PostPosted: 18:12 - 11 Jan 2012    Post subject: Reply with quote
thanks
Dont paint the swing arm! You'll only have to do it again in a months time because it will be full of chips from stones etc. If you want it coloured then get it powder coated, the finish should last a long longer providing they do a decent job and for something the size of a swingarm it shouldn't cost you all that much.
grant965
PostPosted: 20:32 - 11 Jan 2012    Post subject: Reply with quote
thanks
Dont paint the swing arm! You'll only have to do it again in a months time because it will be full of chips from stones etc. If you want it coloured then get it powder coated, the finish should last a long longer providing they do a decent job and for something the size of a swing arm it shouldn't cost you all that much.
already thought about powder coating but thought it was expensive but turns out its actually rather affordable, anyone on here a powdercoater or had work done and can give me an estimate on what it cost them?
chegg
PostPosted: 02:22 - 13 Jan 2012    Post subject: powder coating Reply with quote
the factory i used to work for does it they charged me £120 to do the frame and swing arm on my nc30 but that was with god knows how many acid baths and plus i did a bit of stiffening mods on the frame with the tig welder and that was the bill for that aswell as the materials i used where about are you in the uk if your up Cheshire way there are a fair few good reliable powder coaters and spray places ie bentley motors and chk for powder coating or john Wilkinson
well that fucked it, ive got more power in me left testicle and thats plastic
The last post was made 14 years, 295 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 64.39 Kb
