Honda nsr 250 c reg
jez125
PostPosted: 00:55 - 13 Jan 2012    Post subject: Honda nsr 250 c reg Reply with quote
just inquiring how much you think this is worth completely original Honda nsr 250 c reg v5 runs body work bit tatty as been sat in shed for 7 years i bought it for £480 even i know that is a bargain just want to get an idea of how much i could get for it
also is it worth more as it is or more with a respray exactly the same?
cheers
jez125
PostPosted: 01:06 - 13 Jan 2012    Post subject: hi Reply with quote
also its an mc 16 if that helps
PostPosted: 01:30 - 13 Jan 2012    Post subject: Re: Honda nsr 250 c reg Reply with quote
Certainly worth a lot more than you paid for it then.
A lot of speculators trying to push prices unreasonably high unfortunately.
A high milage MC21 went for £2100 on ebay recently it seems.
tatters
Exxon Valdez
PostPosted: 09:22 - 13 Jan 2012    Post subject: Reply with quote
It would seem that even the low end 250 two-strokes are going for around £1200-1400 theses days on ebay.
Mikey CB500
PostPosted: 13:00 - 13 Jan 2012    Post subject: Reply with quote
didnt happen to buy it off ebay just before christmas time? a red and white one with the side fairings removed as the guy had been trying to set the carbs to make it run right?
jez125
PostPosted: 14:00 - 13 Jan 2012    Post subject: hi Reply with quote
na got this of a mate where i live been sat in his shed for years?
Robby
Dirty Old Man
PostPosted: 14:32 - 13 Jan 2012    Post subject: Reply with quote
Values are going up quite quickly, and will quite likely continue to do so.
I would put some neat 2-stroke down the bores, change the gearbox oil for some fresh, spray the whole thing down with ACF-50, then put a cover on it and forget about it for two or three years. Probably worth filling the fuel tank and adding some stabiliser to stop it rusting, or just fill it with parraffin or something that doesn't go off like petrol.
Don't do anything to it. People want to buy totally original ones to restore.
st3v3
PostPosted: 17:04 - 13 Jan 2012    Post subject: Reply with quote
While I'd be itching like a mad-man to have a ride of it, this is the best advice you could get.
jez125
PostPosted: 21:23 - 13 Jan 2012    Post subject: hi Reply with quote
Ah cheers for that i will put some pics up soon wasn't firing so found the problem re-wired her cleaned the carbs flushed the oil out filled it back then put some distilled water in turned the key kicked her over fired up 1st time sound magic Very Happy so tempted to go have a spin Very Happy got to mot it at some point so i think then its got to be done Thumbs Up and her new names bargain bucket Smile
jez125
PostPosted: 20:28 - 16 Jan 2012    Post subject: hi Reply with quote
hi here's a picture for you
https://www.gumtree.com/p/cars-vans-motorbikes/000/94777103
nsr 250
Suntan Sid
PostPosted: 23:40 - 16 Jan 2012    Post subject: Reply with quote
The main problems with the MC16 are:-
Virtually none of the later model parts are interchangeable.
There are 2 CDI units, one per coil, if these aren't working then you're into big expense. The parts are no longer available new, there are no after market alternatives, so your only options are buying second hand or having the units repaired. You can have new ones made at £600 a pop, they can be repaired but you can't get a price until they've been tested at £35 per unit.
Other than that, tiny little bike, surprisingly comfortable to ride.
Here's mine:-
https://i645.photobucket.com/albums/uu172/Troodos-Pool-Guy/RZR%20250/P1010205.jpg
jez125
PostPosted: 23:48 - 16 Jan 2012    Post subject: hi Reply with quote
ah looks really smart nice you know of anywhere for transfers and stickers for them?
shes all good at the moment but ive decided im going to sell her il clean it up a bit more and see how much i can get
Suntan Sid
PostPosted: 23:56 - 16 Jan 2012    Post subject: Reply with quote
If your going to sell her, I'd look into breaking it, parts are now obsolete, if the CDI units are working you'll get £100 each, no problem, I'd buy them off you now!!
jez125
PostPosted: 00:15 - 17 Jan 2012    Post subject: hi Reply with quote
il sell the bike complete don't want to break up a working bike but i will let you know
The last post was made 14 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 89.32 Kb
