Quick question about oil change
R6 Wilson
PostPosted: 13:12 - 13 Jan 2012    Post subject: Quick question about oil change Reply with quote
Am I supposed to be changing the sump plug gasket/washer when I change my oil? 05 R6
♥ YZF-R6 '05 ♥
Time is money so I stay late
Quote Me Happy
PostPosted: 13:14 - 13 Jan 2012    Post subject: Reply with quote
In a word, yes.
I always do now, in the past I haven't and had no problems but why risk it for the sake of a 10p part?
R6 Wilson
PostPosted: 13:22 - 13 Jan 2012    Post subject: Reply with quote
Cause I can't find one of these 10p pieces anywhere
Please direct me
♥ YZF-R6 '05 ♥
Quote Me Happy
PostPosted: 13:28 - 13 Jan 2012    Post subject: Reply with quote
When I get a new bike I usually buy a few oil filters, washers and a magnetc sump plug from Wemoto then I'm set for a while and do an oil change when I feel like it.
I believe Halfords also sell sump washers if you need one today. I expect a motor factors would be able to help as well.
R6 Wilson
PostPosted: 13:35 - 13 Jan 2012    Post subject: Reply with quote
I went to Halfords, they directed me to a wall full of different sized washers :/
♥ YZF-R6 '05 ♥
Quote Me Happy
PostPosted: 13:37 - 13 Jan 2012    Post subject: Reply with quote
But of course you went armed with the knowledge of the size you're after, right?
R6 Wilson
PostPosted: 13:41 - 13 Jan 2012    Post subject: Reply with quote
I did not
Where would I find out the size of washer? Besides taking mine off?
♥ YZF-R6 '05 ♥
arry
PostPosted: 13:47 - 13 Jan 2012    Post subject: Reply with quote
R6 Wilson wrote:
I did not
Google the sump plug thread size perhaps.
R6 Wilson
PostPosted: 13:52 - 13 Jan 2012    Post subject: Reply with quote
Vincent wrote:
25p here:-
https://www.wemoto.com/bikes/Yamaha/YZF_600_R6_5SL/05/picture/Sump_Plug_-_Drain_Ally_Washer/
As they're ally, I'm really not sure that you need to replace.
Thankyou so much <3
♥ YZF-R6 '05 ♥
whitedevil
PostPosted: 13:53 - 13 Jan 2012    Post subject: Reply with quote
Ive never changed one unless one has come with a filter.
As long as the plug hasnt been over tightened and crushed or deformed the washer i would leave it.
It may be 25p but i bet delivery will be a few quid.
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
PostPosted: 13:56 - 13 Jan 2012    Post subject: Reply with quote
I've never bothered and never had any trouble.
R6 Wilson
PostPosted: 14:09 - 13 Jan 2012    Post subject: Reply with quote
My mechanic mate said it's not totally necessary unless it's rubber :l Might not bother!
♥ YZF-R6 '05 ♥
james1988
PostPosted: 14:20 - 13 Jan 2012    Post subject: Reply with quote
I've never done it on the cars or bikes. Just pinch it up and don't over tighten it; the last thing you want is to strip the threads. If you use a Haynes manual or follow an online guide use a bit of common sense as sometimes the torque figures can be a bit over ambitious.
James
weasley
PostPosted: 14:26 - 13 Jan 2012    Post subject: Reply with quote
The washers are supposed to crush - that's how they work. They are relatively soft alloys that crush and therefore fill the uneven mating surfaces between the bolt head and the sump face. Once used, they are not suitable for reuse since they are already crushed and won't crush again. You can anneal a copper washer but for a few pence why would you?
There's not much more disheartening than filling up with fresh oil only to see the sump plug leaking, meaning you have to drain and start again - all for the sake of a 10p washer. Of course you could "just nip up the plug a bit tighte.... oh BALLS!! Now I need a new sump...".
R6 Wilson
PostPosted: 15:13 - 13 Jan 2012    Post subject: Reply with quote
Oh right. Fuck sake.
♥ YZF-R6 '05 ♥
R6 Wilson
PostPosted: 15:19 - 13 Jan 2012    Post subject: Reply with quote
Ok, I'm always sceptical when buying shit online, how certain are we that this will fit my bike? What does the 5SL mean? I'm going to order about 10 of these seeing as delivery is £2.25 :l
♥ YZF-R6 '05 ♥
Quote Me Happy
PostPosted: 15:32 - 13 Jan 2012    Post subject: Reply with quote
According to Wemoto the sump plug is a M14. Take a M14 bolt to Halfords and hold it against their sump washers to find the right size.
PostPosted: 15:48 - 13 Jan 2012    Post subject: Reply with quote
I would go for a set like this:-
https://www.ebay.co.uk/itm/Copper-sealing-washers-metric-250-pieces-RH023-/250891718298?pt=LH_DefaultDomain_3&hash=item3a6a4fce9a
(bought one from them a few years ago).
Costs a bit more in the short term but saves faffing in the future. And when you find the sizes you use more often just buy a pack of that size.
Ericck
PostPosted: 15:54 - 13 Jan 2012    Post subject: Reply with quote
I'm no mechanic but I've done a fair few oil changes.
On my bandit it is an actual crush washer and therefore needs changing. (Also bought 10 at a time from wemoto due to delivery charge).
On my CBR it is not a crush washer but a normal washer.
Haynes destruction manual says change it, actual Honda
manual says only replace if it is badly scored. I reused it no
problem.
So if it is not a really thin crush washer, you should be able
to reuse if still in okay condition.
Current Bike: 2004 Suzuki Bandit 600S
Previous Bikes: Yamaha FS1E, Mobylette Moped Thingy, Suzuki GS125, Kawasaki Zephyr 550, Kawasaki Zephyr 750, Kawasaki ER500, Suzuki Bandit 600, Honda CBR600F, Triumph Street Triple 675, Suzuki V Strom 650, Suzuki Bandit 1200, Suzuki SV650N, Honda CB500F.
R6 Wilson
PostPosted: 16:15 - 13 Jan 2012    Post subject: Reply with quote
Buying 10 washers from Wemoto instead of fucking around Confused thanks for the idea Kickstart but I doubt I'll ever had to use another kind of washer in the next ten years lol
♥ YZF-R6 '05 ♥
Fizzer Thou
PostPosted: 17:18 - 13 Jan 2012    Post subject: Reply with quote
My local corner shop car spares place does these washers 10 for a quid.
I did my car the other day and just reannealed the existing one.Worked fine.
As for the bikes I have a good look at the one on the drain plug and if it is too badly compressed then I replace it.
Always have a 'Plan B'
The last post was made 14 years, 282 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 121.83 Kb
