Tappet loose in cylinder head?
deleted111
PostPosted: 11:38 - 14 Jan 2012    Post subject: Tappet loose in cylinder head? Reply with quote
Morning folks.
The engine died a death on my ZZR250 so I bought a replacement lump, seemed more sensible than buying a new bike since this one's only recently been reinsured, mot'd and tax'd!
Anyway.
This new engine arrives, and I notice a few stress cracks around the rocker cover.
No biggy, I'll just swap the rocker cover with the one off my dead engine, I thought.
Then, after removing the rocker cover on the new-to-me engine, I noticed a tappet just sat there in the middle, between the spark plug holes. Loose.
Now, that's not right. Is there any way I can remedy this? Something's telling me it's not supposed to come off like that.
TL;DR, found my ass a tappet flying around the inside of the cylinder head, what do?
Cheers guys.
Steve.
The Artist
PostPosted: 13:22 - 14 Jan 2012    Post subject: Reply with quote
Pictures would help.
Tappet should screw into the rocker arm and have a locking nut.
MickC
PostPosted: 13:27 - 14 Jan 2012    Post subject: Reply with quote
By tappet I'm guessing you meant the adjuster and not the arm. If so find out where it's from, which arm is missing one?. Make sure you set it right then turn the engine over manually to make sure everything is okay. Before using it drain any old oil and remove the sump, check the gunk in the bottom of the plate for metal filings. Re assemble then put in fresh oil and manually turn the engine over again before starting it.
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
MickC
PostPosted: 13:30 - 14 Jan 2012    Post subject: Reply with quote
Good point, you need to find the locking nut if its not on the tappet.
XX XXXx
Ichy
PostPosted: 14:14 - 14 Jan 2012    Post subject: Reply with quote
First thing should be to take photos and make the seller aware of the problem.
deleted111
PostPosted: 14:46 - 14 Jan 2012    Post subject: Reply with quote
thanks for your input guys. I've given up trying to figure out how to mend it, and have just decided to down tools and let the seller know... see thread in DABCF.
Cheers again,
Steve
The last post was made 14 years, 269 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 47.8 Kb
