Fzr 600 3he Fuel pump mounting point?
Rncv
PostPosted: 19:11 - 15 Jan 2012    Post subject: Fzr 600 3he Fuel pump mounting point? Reply with quote
Does anyone know where the fuel pump mounting point is on an fzr 600 3he?
got the bike in a state and things are finally nearly all together, just need to find out where this mounting point is. Thanks.
https://i39.tinypic.com/29qi3ko.jpg
https://i44.tinypic.com/k1yzcl.jpg
Current: 01' Bandit 600, 92' Goose 350
Previous: Lots!
PostPosted: 20:47 - 15 Jan 2012    Post subject: Reply with quote
From memory it mounts on the tank itself.
Rncv
PostPosted: 23:37 - 15 Jan 2012    Post subject: Reply with quote
I thought the same although there is no suitable place to mount it
Cheers.
Previous: Lots!
jjdugen
PostPosted: 00:16 - 16 Jan 2012    Post subject: Reply with quote
If its the steel framed model there should be a crossmember between the frame rails just behind the carbs. It unbolts so might have been lost / cast.
Now I've looked at the photo a little closer you can see the two mounting lugs with the screw thread.
PostPosted: 12:50 - 16 Jan 2012    Post subject: Reply with quote
Those are the mounts for the petrol tank.
PostPosted: 15:13 - 16 Jan 2012    Post subject: Reply with quote
Vincent wrote:
Are you sure that's the right pump bracket?
Don't think it is.
You can see the pump and how it mounts here
PostPosted: 15:27 - 16 Jan 2012    Post subject: Reply with quote
Sure mine was on the actual tank itself... Neutral
jjdugen
PostPosted: 17:12 - 16 Jan 2012    Post subject: Reply with quote
Apologies, the other posters are correct in that it mounts to the tank. When I did mine last year I fitted a ZX-9 tank (and Fireblade seat unit) and used the crossbeam for the fuel pump. Oh, and thats a TDM 850 17'' rear wheel on there too. Quite nice if I do say so myself.
PostPosted: 17:20 - 16 Jan 2012    Post subject: Reply with quote
I am no fan of putting bit from random bikes onto other bikes, but that looks good. Seat unit does look a bit bulky but still within reason.
How easy was it to fit the 17" rear wheel? On my 3HE with the stock wheel and 150 tyre the clearance between the chain and tyre is tiny (~5mm).
jjdugen
PostPosted: 17:59 - 16 Jan 2012    Post subject: Reply with quote
Hi. ANYTHING looks better than a stock early FZR, the post '93 models were the best of them all, far better looking than the T'cat IMHO. I did this as I had picked up a £200 shed and had all these bits cluttering up the workshop. The more I did, the more it grew on me. Total cost, to me, was about £600, would be more if you had to source the bits, but you can go your own way with these old things.
The TDM wheel fits like a dream, all you have to do is cut the caliper hanger to allow for the extra width of the hub, about half an inch as I recall. A hacksaw and grinder and it was done within an hour. The chain side lines up perfectly with the stock spacer, stock spindle, stock disk too. I'll have to do some digging but I'm sure I have this documented and photographed somewhere if you want more info.
PostPosted: 18:11 - 16 Jan 2012    Post subject: Reply with quote
I actually quite like the FZR styling.
The wheel fitment is interesting. Given that a legitimate rear tyre is difficult to get for the stock rear wheel.
Keith (who also has an FZR600 3HE floating around)
The last post was made 14 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 2.12 - MySQL Queries: 13 - Page Size: 89.46 Kb
