MOT Certificate(s) - Pass and Fail. Both in my hand.
anthony_r6
PostPosted: 19:01 - 16 Jan 2012    Post subject: MOT Certificate(s) - Pass and Fail. Both in my hand. Reply with quote
Dropped the bike off for it's MOT on Saturday and went to pick it up tonight. I made sure they aligned the rear wheel and adjusted the rear brake light for me as these were issues I couldn't be bothered dealing with.
Anyway, I've just been to pick it up and the guy tells me it's passed, but with some advisories. Namely being the front suspension is slightly bent. They took it out for a test ride and deemed it okay and not to adversely effect the bike.
After a little bit of rustling about, trying to find the paperwork, he tears off three pieces of paper, which I didn't look at - just shoved them in my bag and set off home. I've just looked at them now, and I'm confused.
1. Is the Invoice for the work and for the MOT.
2. Is my "MOT Test Certificate"
3. Is my "Refusal of an MOT Test Certificate" Confused
He explicitly told me it passed, and I appear to have the paperwork to prove it. So why do I have the failure too?
The only difference between the two sheets is the failure one has a "Reason for refusal" section, which says - "001 Rear reflector on motorcycle missing [1.4.1]. I was under the impression that the rear brake light casing was considered a reflector?
Has someone failed me the first time, and realised that I DO have the reflector and had to issue me a pass?
The other advisories I've got are ;
1 Rear Mono-shock pivot worn but not excessive.
2 Front Roller brake test indicates slight fluctuation of brake effort
3 Rear Roller brake test indicates slight fluctuation of brake effort
4 Front suspension has slight stiffness in the movement of the suspension
5 Front suspension assembly is slightly bent
6 Front wheel alignment slightly misaligned.
Are any of these a real problem ?
Thanks!
PostPosted: 19:04 - 16 Jan 2012    Post subject: Reply with quote
They took your bike out for a test ride on an MOT....?
If they did that to mine I'd be rather pissed.
I'd sort the suspension and brakes firstly. Neutral
Chris750
PostPosted: 19:08 - 16 Jan 2012    Post subject: Reply with quote
I had the same thing happen with mine.
They MOT it, see what it fails on and issue a fail certificate as its effectively failed.
They then fix the issues, then retest and issue a pass certificate.
Current Rides: GSXR-750 WS, GSXR-1000 K5, KTM EXC 300
anthony_r6
I've not had a problem with the brakes, seem fine to me, braking fine and all that and I've not had a problem with the suspension either, doesn't feel stiff to me, but I'm basing that on nothing really.
They rode it, yeah, but I'm not concerned with that, they wanted to check it was not a problem, and when I asked him what he thinks I should do about it, he said "I shouldn't think it'll be a problem" - So I'm not sure what the hell I'm doing.
Wanting to sell the thing anyway.
moppy
PostPosted: 19:13 - 16 Jan 2012    Post subject: Reply with quote
Wouldn't show the potential buyer the fail slip then Laughing
PostPosted: 19:17 - 16 Jan 2012    Post subject: Re: MOT Certificate(s) - Pass and Fail. Both in my hand. Reply with quote
Nope, although some brake / tail lights have an integrated reflector.
anthony_r6
PostPosted: 19:19 - 16 Jan 2012    Post subject: Reply with quote
It'll be getting shredded very soon!
But the reason for the failure isn't legit anyway, since the red brake casing surely counts as the reflector? Passed it's MOT like that last year no problem.
PostPosted: 19:31 - 16 Jan 2012    Post subject: Reply with quote
No, a very legit and very common reason for a fail.
anthony_r6
PostPosted: 19:39 - 16 Jan 2012    Post subject: Reply with quote
I would understand if it was just a fail. But I have the pass certificate, which makes no mention of it, and the mechanic told me it was a pass. My theory is that someone did it, failed me, only to be told that my back light thing counted?
Would you consider the red casing on the rear brake light to be a reflector for an NSR 125 2001 FOXEYE Model?
biker58
PostPosted: 20:15 - 16 Jan 2012    Post subject: Reply with quote
Was the MOT pass printed after the fail?
1995 Suzuki GSX600F rider
Kwaks
I'm not a fast rider
PostPosted: 20:26 - 16 Jan 2012    Post subject: Reply with quote
Ok LISTEN..... You have been told more than once on this thread that the rear brake casing is NOT a reflector.
Stop bloody going on about the bloody brake casing, buy a reflector from the pound shop and stick it on your plate and ask take the bike back. Unless you have a pass certificate to hand the bike has failed.
www.cliqueycuntsmcc.co.uk
anthony_r6
10:35 on both of them.
J.M.
PostPosted: 20:34 - 16 Jan 2012    Post subject: Reply with quote
Could always get a MOT status check and MOT history check from the DVLA and see what it says?
2004 R1 & 2018 XSR900
Nb
PostPosted: 20:40 - 16 Jan 2012    Post subject: Reply with quote
The tester used PRS he failed it but fixed the minor item within an hour and then instantly issues a pass certifcate but it also issues a fail to show the problem he fixed.
If they didn't do anything about your reflector then the tester is just keeping his stats up......
biker58
PostPosted: 20:41 - 16 Jan 2012    Post subject: Reply with quote
They haven't made it easy for you have they lol, just give them a call in the morning Thumbs Up
Burnside
PostPosted: 20:43 - 16 Jan 2012    Post subject: Reply with quote
Same thing happened for my car - it failed on the wipers so mechanic replaced them then passed it. I got both fail and pass certificates with same time on them. 2nd MOT didn't cost me anything.
Was there definately a reflector there in the first place? He maybe failed it then stuck the reflector on to pass it.
Seems a bit daft to issue a failed certificate cos it took a matter of seconds to fix it - one reason might be that the garage has pass/fail stats to reach.
No point in shredding the failed cert, it will show up on the MOT history anyhow https://motinfo.direct.gov.uk/internet/jsp/ECSID-Internet-Status-Request.jsp
I started out with nothing and I still got most of it left.
PostPosted: 20:46 - 16 Jan 2012    Post subject: Reply with quote
Look for a small stick on reflector on the back of the bike or on the numberplate. Most MOT places will have a stack of them ready to bung onto bikes that would otherwise fail.
Don't think it has a built in reflector so no it wouldn't count.
PostPosted: 20:47 - 16 Jan 2012    Post subject: Reply with quote
Ok,
Sit down, shut up and read this.
First off, you DO need a seperate reflector. The brake light cover is NOT a reflector.
Secondly the garage aren't trying to rip you off. Are you sure that they didn't stick a small circular reflector to the bottom of the numberplate? If they did, that would explain why they gave you a pass and a fail sheet.
Secondly a MOT centre is allowed to do a test ride if they don't have the brake efficiency equipment. I suspect they checked the brakes on the test ride.
Chill out and accept the pass certificate. If a new owner wants to check out the MOT history, he'll see the fail sheet online, so shredding it is probably not going to help you.
HTH.
PostPosted: 20:51 - 16 Jan 2012    Post subject: Reply with quote
They can do a test ride if they feel like it, although the most common reason is probably to do a brake test on a 4wd vehicle which can't go on the rollers.
boundy
PostPosted: 20:53 - 16 Jan 2012    Post subject: Reply with quote
If im viewing a new bike or car I'll look at the MOT paperwork and see if the little box is checked, it advises if an advisory sheet has been issued, I'll then ask the seller what the adviseries are. If they haven't got the sheet I'll check on line and compare to what I've been told. If they lied to me or tried to cover up a fault that should of been sorted I'll walk away.
PostPosted: 20:57 - 16 Jan 2012    Post subject: Reply with quote
Thumbs Up Cheers for clearing that up... Although insurance says they can ride another bike with the owners permission. If I say wanted to MOT a fully carbon fibred Desmo... and didn't give them permission to ride it and they then rode it... what could you do? Could you say you do not have my permission to ride this bike?
Not starting a battle here Laughing Just if you had a fucking expensive bike that you had saved the best part of 10-15 years for.. I know I wouldn't want another guy riding it....especially to test the brakes Laughing
jimspeed
PostPosted: 21:04 - 16 Jan 2012    Post subject: Reply with quote
Simple one this , the tester has actually done YOU a favour and failed it due to no reflector then stuck one on (at a guess) and passed it.
what he could have done is failed it and made you provide one and then maybe wait until he had time for a retest.
Rolling Eyes
Both times I have taken my bikes for mot he has nipped off down the road on it (no lid or anything Cool )
only to make sure the brakes work and it rides straight tho he says lol.
as long as you have the pass cert and all the details are right on it then don't worry about it. Thumbs Up
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
PostPosted: 21:09 - 16 Jan 2012    Post subject: Reply with quote
There are well known examples of the YTS boy writing off 'exotic' cars on MOT test drives... It happens. If you don't want someone to test ride your bike, then I suggest you watch the MOT being done. It is perfectly legal for you to stand and watch.
JP7
PostPosted: 21:14 - 16 Jan 2012    Post subject: Reply with quote
You will find that many garages will issue a fail certificate, then a pass, rather than simply rectifying the faults and passing it.
VOSA monitor pass/fail rates, and any garage that passes too many will be investigated. So many will keep their figures up by failing them first.
It's nothing to worry about, you've got a pass certificate so you're sorted.
MaybeGuy
PostPosted: 21:15 - 16 Jan 2012    Post subject: Reply with quote
From what I've been told, VOSA question garages that have a very high pass rate. They probably failed your bike on what they could, then passed it straight afterwards to make them look more stringent.
The last post was made 14 years, 306 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.17 - MySQL Queries: 13 - Page Size: 138.65 Kb
