Bike with a Cracked Frame
Gazz
PostPosted: 21:31 - 16 Jan 2012    Post subject: Bike with a Cracked Frame Reply with quote
Just curious since I have seen a bike advertised with a cracked frame.
Is this only suitable for the recycle bin, or could it be repaired? The bike was in an accident.
I dont know where the crack is (because I haven't asked yet), but does this usually mean that there is no coming back for this bike?
How easy would it be to repair?
Worth the hassle?
Sorry if I am being a vague but details are a bit sketchy at the moment. I can find out more information if required.
Cheers for the replies in advance.
MaybeGuy
PostPosted: 21:34 - 16 Jan 2012    Post subject: Reply with quote
buy new frame, swap into new frame, job done.
1cyl
PostPosted: 21:40 - 16 Jan 2012    Post subject: Reply with quote
https://zebracakes1.co.uk/wp-content/uploads/2011/10/Piece-Of-Cake.jpg
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
PostPosted: 21:49 - 16 Jan 2012    Post subject: Reply with quote
Nothing to stop someone repairing the crack if they have the skills, but most of the time not worth it.
New 2nd hand frame will mean a new identity from the bike the frame came from (ie, frame with log book). Brand new frame is more hassle (but they probably come without a frame number, ready to be stamped up).
pepperami
PostPosted: 22:03 - 16 Jan 2012    Post subject: Reply with quote
I`d be thinking about what caused the frame to crack in the first place?
Is it poor quality materials or has the owner been mistreating the bike?
jimspeed
PostPosted: 22:05 - 16 Jan 2012    Post subject: Reply with quote
or maybe the accident it's had Question
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
PostPosted: 22:42 - 16 Jan 2012    Post subject: Reply with quote
Not exactly a crack, but my bike has a MASSIVE dent in the front left part of the frame about 4 inches from the headstock area...Hidden by fairings when they are attached Laughing
Gazz
PostPosted: 23:30 - 16 Jan 2012    Post subject: Reply with quote
I have asked the guy for pics, price and more details.
DrDonnyBrago
PostPosted: 18:39 - 17 Jan 2012    Post subject: Re: Bike with a Cracked Frame Reply with quote
Is the bike an insurance write off? If so, what category?
Aluminium or steel frame?
All depends on how bad the crack is, if it was a big split in a cross beam it would be worse than a small crack in an engine mount for example. Would probably be simpler to buy a new frame with V5 and inform the DVLA of an engine change. It should be quite cheap to be worthwhile.
PostPosted: 18:46 - 17 Jan 2012    Post subject: Re: Bike with a Cracked Frame Reply with quote
Frame damage is cat B, especially cracks.
PostPosted: 18:49 - 17 Jan 2012    Post subject: Reply with quote
I presume you know what sort of bike it is?
A mate of mine is on the third frame for his ZX9R, never been crashed.
The frame on a modern sportsbike is distressingly small and lightweight. You order one off the breakers and a couple of days later the postie comes wandering up the drive with a small cardboard box tucked under one arm containing your frame.
Gazz
PostPosted: 17:11 - 18 Jan 2012    Post subject: Reply with quote
Update:
It is a 1999 ZX6R
Been in contact with the guy and he is looking for £450 for it.
https://i94.photobucket.com/albums/l100/Photobucket_Gazz/photo3-1.jpg
Thats the crack.
Also needs all fairings, grabrail, indicator, levers to name a few parts.
0ddball
PostPosted: 17:24 - 18 Jan 2012    Post subject: Reply with quote
As far as i can see on my phone it's only the subframe mount? I'd just get that welded and keep an eye on it.
ZXR750L
PostPosted: 17:26 - 18 Jan 2012    Post subject: Reply with quote
That should be easily weldable, but would also expect the result to be fairly obvious and put people off buying it in future. If for a track bike or something to run into the ground then possible.
I rebuilt a ZX6R with the owner a few years ago, also due to a cracked frame (below the peg hangers). It is a fair amount of work. Also watch out for minor changes in the frame over the years (ie, on the ZX6R the engine mounts half way down the frame changed design - not a problem except for the delay waiting for the new mounting bolt to be delivered).
HD
PostPosted: 19:58 - 18 Jan 2012    Post subject: Reply with quote
Or weld both sides so it matches?
MaybeGuy
PostPosted: 20:19 - 18 Jan 2012    Post subject: Reply with quote
If it's not registered as a write off, I'd buy that in a second. Repair would be a piece of piss. If it's a cat B though, new frame time.
If you don't want it, and it's HPI clear, PM me the deetz.
The last post was made 14 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 89.66 Kb
