Setting torque...
philcxiv
PostPosted: 22:00 - 18 Sep 2004    Post subject: Setting torque... Reply with quote
Selling my kawazaki 85cc. But before i do that i have to replace the piston. So just now the bikes lying in bits all over the garage floor
because i don't have a torque wrench to set the appropriate torque for the cylinder head and even if i did it would not fit in the small space. If i tighten it up really tight will this do the job or will i have to set the torque using a different method of just get a wrench.
Any help would be great thanks, phil
[philcxiv] [lucky 14] Thumbs Up Twisted Evil "I only use the brakes so I can accelerate all over again"
bikepics | ratemybike
tatters
Exxon Valdez
PostPosted: 22:05 - 18 Sep 2004    Post subject: Reply with quote
stop being a tight git, get a toruqe wrench only £30. if you do the cylinder head bolts up too tight you will snap/shear them, and not tight enthough the head gasket will leak. the same with the cylinder base nuts
Jammy-G This post is not being displayed because the poster is banned. Unhide this post / all posts.
swampy
PostPosted: 00:15 - 19 Sep 2004    Post subject: Reply with quote
You need a torque wrench to ensure that the mating surfaces are flush and form a good seal. Easy for me to say though, I can borrow my old mans Smile
Mind you, if the bikes in bits, you could tighten it all up before putting the engine back in....
PostPosted: 00:25 - 19 Sep 2004    Post subject: Reply with quote
If you do not torque the bolts down properly, progressivley and in the correct order, you will warp the cylinder head and it will never seal properly again without remachining. You could always borrow a wrench off someone. If you can't get it to fit somehow, drop the engine.
swampy
PostPosted: 00:35 - 19 Sep 2004    Post subject: Reply with quote
Stinky raised a good point there, you need to tighten in the right order, normally that means tightening in diagonal opposites from the inside nut outwards.
stevo123
PostPosted: 12:11 - 19 Sep 2004    Post subject: Reply with quote
Also important is to ensure the threads on the nuts/bolts/studs are very clean and lightly oiled(wd40) but not dripping with the stuff. Make sure there is no water or oil in the holes as this will give a false reading as water and oil do not compress and the wrench will be fooled into thinking the torque required has been met Thumbs Up Good luck
The last post was made 21 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 54.9 Kb
