| philcxiv |
 philcxiv Scooby Slapper
 Posted: 22:00 - 18 Sep 2004 Post subject: Setting torque... |
Selling my kawazaki 85cc. But before i do that i have to replace the piston. So just now the bikes lying in bits all over the garage floor
because i don't have a torque wrench to set the appropriate torque for the cylinder head and even if i did it would not fit in the small space. If i tighten it up really tight will this do the job or will i have to set the torque using a different method of just get a wrench.
Any help would be great thanks, phil ____________________ [philcxiv] [lucky 14] "I only use the brakes so I can accelerate all over again"
bikepics | ratemybike |
| tatters |
 tatters Exxon Valdez
 Posted: 22:05 - 18 Sep 2004 Post subject: |
stop being a tight git, get a toruqe wrench only £30. if you do the cylinder head bolts up too tight you will snap/shear them, and not tight enthough the head gasket will leak. the same with the cylinder base nuts ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| Jammy-G |
 Jammy-G Banned
| swampy |
 swampy World Chat Champion
 Posted: 00:15 - 19 Sep 2004 Post subject: |
You need a torque wrench to ensure that the mating surfaces are flush and form a good seal. Easy for me to say though, I can borrow my old mans
Mind you, if the bikes in bits, you could tighten it all up before putting the engine back in.... ____________________ "I hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me." Hunter S Thompson
 Posted: 00:25 - 19 Sep 2004 Post subject: |
If you do not torque the bolts down properly, progressivley and in the correct order, you will warp the cylinder head and it will never seal properly again without remachining. You could always borrow a wrench off someone. If you can't get it to fit somehow, drop the engine. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| swampy |
| stevo123 |
 stevo123 Nitrous Nuisance
 Posted: 12:11 - 19 Sep 2004 Post subject: |
Also important is to ensure the threads on the nuts/bolts/studs are very clean and lightly oiled(wd40) but not dripping with the stuff. Make sure there is no water or oil in the holes as this will give a false reading as water and oil do not compress and the wrench will be fooled into thinking the torque required has been met Good luck |
The last post was made 21 years, 355 days ago. Instead of replying here, would creating a new thread be more useful? |
