| ecoartist |
 ecoartist L Plate Warrior
| Howling TerrorOutOfOffice |
 Posted: 23:03 - 18 Jan 2012 Post subject: |
Oil does evaporate, but not that much.
I suspect a leak or worn piston rings.
Don't let the light come on again and get a compression test.
Hopefully some more experienced users will offer more ideas. ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| hornetmike |
 hornetmike World Chat Champion
| ecoartist |
 Posted: 23:18 - 18 Jan 2012 Post subject: |
Thanks for your replies.
God.... all sounds expensive
There is no oil leak. Why would that happen as the milage is not really high? |
 Posted: 23:46 - 18 Jan 2012 Post subject: |
Wear happens.
Maybe that particular engine is susceptible to premature wear, maybe the previous owner skipped oil changes and valve clearances. Maybe they thrashed it as soon as the key was turned.
Does it emit blue smoke when you first fire it up? Best seen when the weather is above 10 degrees. Or how about going down a hill off the throttle then cracking it open, does it puff out smoke? ____________________ Diabolical homemade music Bandcamp and Soundcloud
| ecoartist |
| Noxious89123 |
| ecoartist |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 09:49 - 19 Jan 2012 Post subject: |
My guess is that its ridden hard from cold... do you let the bike warm up fully before riding it hard?
You'd have done a good job to knacker the valve stem seals at 23k miles, so my guess is on rings.
Best thing to do is do a compression test, then add some oil into to the bore and do it again. If there is a big difference between the 2 readings (the oil being the higher of the two) then you rings are shot.
If not, it's possible the stem seals are fucked.
Neither are a massive job to do but it will be expensive, and in the long run I expect it'll be cheaper to get a new engine if it turns out the rings are the problem. You'll need a new set of barrels as I'd expect the ones you've got will be oval and hence the high consumption.
If the compression test comes back that the rings are fine, it'll be around £80 to do the stem seals. If the rings are gone, I'd say a minimum of £200.
Personally, in the long run it'll be cheaper to just use some cheap oil and keep topping it up. The time for change is when the bike just becomes impossible to start from hot or cold.
HTH ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| Fizzer Thou |
| Robby |
 Robby Dirty Old Man
 Posted: 16:41 - 19 Jan 2012 Post subject: |
You haven't said how much you are putting in, but it sounds like you are topping up every 800 miles or so. I would expect that the bike could easily burn half a litre in 1000 miles.
However, you mentioned the oil (red) light coming on. In most bikes, althought not on the odd kawasaki, this is the oil pressure light (on some kawasakis, I think the GPZ500 is one, it is the oil level light). By the time this light comes on it is really just telling you that your engine is toast. If you carried on riding with the oil pressure light on, your engine is definately toast.
You're doing quite a few miles too, you must be servicing it every two months, assuming a 4000 mile oil change interval. The air lock thing is bollocks, oil systems do not air lock, but it takes a couple of seconds to get oil into the filter when drained down. If you have run so low on oil that the pump is full of air, you've broken it.
I would just change the engine. It's burning a lot of oil, you've had the oil pressure light on. It is possible that the crank is fine and the rings are worn out, but to re-ring that engine would cost an easy £200 in parts, assuming you do all the work yourself. Valve stem seals being a problem is fairly unlikely, they get killed by age and lack of use (drying up over several years sitting). They can get killed by extreme heat and lack of oil (blocked oil feed to the head) but if this was the case your camshaft would be knackered. |
| dangerousdave |
 dangerousdave Traffic Copper
 Posted: 18:42 - 19 Jan 2012 Post subject: Re: ZX6R uses too much oil |
| ecoartist wrote: | Riding my 1997 Kawasaki ZX6R(23,000 mls on the clock) almost every day- 80 miles a day-, rides lovely, great fun but have to keep adding oil every other week sometimes after a week if I make more miles. |
Do you ride the bike at high revs regularly ?
If you are regularly stressing the engine with high loads and high revs the engine will burn a lot more oil.
I have a Thunderace which is well known for high oil consumption. However, I've found mine uses very little oil unless its visiting the red-line often.
If you are riding the bike well within its limits most of the time, then adding oil after 400miles (1 week) does sound a bit of a chore - but how much oil are you adding? If you're topping up your oil every 800miles then that's not too bad.
I guess what I am trying to say is how bad is the problem? How much is it costing you and how often ? Is your riding style contributing to it ?
How does the cost of topping up the oil compare to the cost of fitting new piston rings ? ____________________ 1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50 |
| ecoartist |
| Walloper |
 Walloper Super Spammer
The last post was made 14 years, 264 days ago. Instead of replying here, would creating a new thread be more useful? |
