ZX6R uses too much oil
ecoartist
PostPosted: 22:53 - 18 Jan 2012    Post subject: ZX6R uses too much oil Reply with quote
Riding my 1997 Kawasaki ZX6R(23,000 mls on the clock) almost every day- 80 miles a day-, rides lovely, great fun but have to keep adding oil every other week sometimes after a week if I make more miles. Because I forget red light comes on and gets an air lock, I have to put oil start the bike and unscrew the filter while accelareting gently.
Is it normal for Kawak to use that much oil? My previous bikes never used oil like this. (600 Bandit, GSX750)
I am considering to get a sensible Versys if I can't sort it out.
Many thanks
PostPosted: 23:03 - 18 Jan 2012    Post subject: Reply with quote
Oil does evaporate, but not that much.
I suspect a leak or worn piston rings.
Don't let the light come on again and get a compression test.
Hopefully some more experienced users will offer more ideas.
hornetmike
PostPosted: 23:07 - 18 Jan 2012    Post subject: Reply with quote
Sounds like valve oil seals or pistons rings letting go, compression test to check its all fixable
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
ecoartist
PostPosted: 23:18 - 18 Jan 2012    Post subject: Reply with quote
Thanks for your replies.
God.... all sounds expensive Sad
There is no oil leak. Why would that happen as the milage is not really high?
PostPosted: 23:46 - 18 Jan 2012    Post subject: Reply with quote
Wear happens.
Maybe that particular engine is susceptible to premature wear, maybe the previous owner skipped oil changes and valve clearances. Maybe they thrashed it as soon as the key was turned.
Does it emit blue smoke when you first fire it up? Best seen when the weather is above 10 degrees. Or how about going down a hill off the throttle then cracking it open, does it puff out smoke?
ecoartist
PostPosted: 00:06 - 19 Jan 2012    Post subject: Reply with quote
its pretty cold now and haven't noticed blue smoke. Previous
seemed like a very orginised businessman all services done, paperwork properly filed.
Is that mean that many hours of £45 labour?
Noxious89123
PostPosted: 00:24 - 19 Jan 2012    Post subject: Reply with quote
Is all the mileage genuine? Got old MOTs to prove it?
ecoartist
PostPosted: 07:53 - 19 Jan 2012    Post subject: Reply with quote
need to check the MOT s but I'm sure I checked them when I brought the bike,
0l0dom0l0
PostPosted: 09:49 - 19 Jan 2012    Post subject: Reply with quote
My guess is that its ridden hard from cold... do you let the bike warm up fully before riding it hard?
You'd have done a good job to knacker the valve stem seals at 23k miles, so my guess is on rings.
Best thing to do is do a compression test, then add some oil into to the bore and do it again. If there is a big difference between the 2 readings (the oil being the higher of the two) then you rings are shot.
If not, it's possible the stem seals are fucked.
Neither are a massive job to do but it will be expensive, and in the long run I expect it'll be cheaper to get a new engine if it turns out the rings are the problem. You'll need a new set of barrels as I'd expect the ones you've got will be oval and hence the high consumption.
If the compression test comes back that the rings are fine, it'll be around £80 to do the stem seals. If the rings are gone, I'd say a minimum of £200.
Personally, in the long run it'll be cheaper to just use some cheap oil and keep topping it up. The time for change is when the bike just becomes impossible to start from hot or cold.
HTH
Fizzer Thou
PostPosted: 12:38 - 19 Jan 2012    Post subject: Reply with quote
From experience the sport Kawasakis tend to run a loose piston skirt to liner clearance - except the ZX12R,which used impossibly tight clearances and people wondered why the engine seized.By running a loose clearance the engine suffered less from power loss due to friction.But this showed up at a later date as needing attention to the engine far sooner than say a Honda,which run with clearances that seem to control oil consumption much better.
It is not a big deal to replace piston rings if on your engine the barrel is seperate to the top crankcase.I did the piston rings and valve guide seals on my 'H' reg Exup 1000 due to high oil consumption and it did make a differance.I do not use fully-synth but semi-synth oil.I have heard of poeple using mineral oil for high oil consumption engines,but this can hurt performance.If this is not a consideration then it may be an option instead of ripping into the engine.
Another engine from a breakers may well have the same problem as you are experiencing,so cheaper in the long run to do the job yourself.
Always have a 'Plan B'
Robby
Dirty Old Man
PostPosted: 16:41 - 19 Jan 2012    Post subject: Reply with quote
You haven't said how much you are putting in, but it sounds like you are topping up every 800 miles or so. I would expect that the bike could easily burn half a litre in 1000 miles.
However, you mentioned the oil (red) light coming on. In most bikes, althought not on the odd kawasaki, this is the oil pressure light (on some kawasakis, I think the GPZ500 is one, it is the oil level light). By the time this light comes on it is really just telling you that your engine is toast. If you carried on riding with the oil pressure light on, your engine is definately toast.
You're doing quite a few miles too, you must be servicing it every two months, assuming a 4000 mile oil change interval. The air lock thing is bollocks, oil systems do not air lock, but it takes a couple of seconds to get oil into the filter when drained down. If you have run so low on oil that the pump is full of air, you've broken it.
I would just change the engine. It's burning a lot of oil, you've had the oil pressure light on. It is possible that the crank is fine and the rings are worn out, but to re-ring that engine would cost an easy £200 in parts, assuming you do all the work yourself. Valve stem seals being a problem is fairly unlikely, they get killed by age and lack of use (drying up over several years sitting). They can get killed by extreme heat and lack of oil (blocked oil feed to the head) but if this was the case your camshaft would be knackered.
dangerousdave
PostPosted: 18:42 - 19 Jan 2012    Post subject: Re: ZX6R uses too much oil Reply with quote
Do you ride the bike at high revs regularly ?
If you are regularly stressing the engine with high loads and high revs the engine will burn a lot more oil.
I have a Thunderace which is well known for high oil consumption. However, I've found mine uses very little oil unless its visiting the red-line often.
If you are riding the bike well within its limits most of the time, then adding oil after 400miles (1 week) does sound a bit of a chore - but how much oil are you adding? If you're topping up your oil every 800miles then that's not too bad.
I guess what I am trying to say is how bad is the problem? How much is it costing you and how often ? Is your riding style contributing to it ?
How does the cost of topping up the oil compare to the cost of fitting new piston rings ?
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
ecoartist
PostPosted: 00:07 - 20 Jan 2012    Post subject: Reply with quote
Just wanted to say thank you so much to all you helpful people, I'll check a bit more during this weekend, will check blue smoke and start making notes on every time I add oil to see if there is a pattern. I do ride the pretty revvy in summer but kind of calm in winter.
I'll check this week and get back to you fab people.
many thanks
Walloper
PostPosted: 00:32 - 20 Jan 2012    Post subject: Reply with quote
many thanks
You may have a leak.
Best way to find a leak is to park the bike on something clean.
If you have a roll off wall paper unroll that and stand the bike on it after a good run.
Don't bother to dry it off any oil will be very evident on a clean surface.
You should have NO oil leaks. If you see oil on the paper then you have a leak.
A drip every second will soon cause the level to drop as bike engines don't have a massive amount of reserve.
Engine wear is HIGHLY unlikely unless you have a very serious failure in the internals. So if you do not find a positive leak then you need to have the machine checked out by a bike shop.
Or you could do a simple check of the combustion conditions by removing and examining the spark plugs. Sticky black plugs is a sign of a lubrication issue.
The last post was made 14 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 85.52 Kb
