Infrared heaters - anyone used them? Opinions?
D O G
PostPosted: 23:33 - 18 Jan 2012    Post subject: Infrared heaters - anyone used them? Opinions? Reply with quote
Hello.
The missus has a small studio in the middle of nowhere where she does her arty business stuff. Problem is that the heating (or rather the insulation of the building) is dire, when she turned up this morning it was 4degrees inside, and after the heating being on full bore all day it was a balmy 8 degrees.
This is not ideal, especially when doing detailed work, and we can't use one of those propane space heater things as there is insufficient ventilation. It's only her, or her and one other bod, who is there at any one time, and so I thought an infrared heater would be a good idea - it is just her we need to keep warm.
I've never used one, neither has she, just wondering whether anyone on here has, what their thoughts are on them, and if you have any other ideas.
Do they cost a lot to run, relative to others?
Thanks in advance!
Frost
PostPosted: 00:03 - 19 Jan 2012    Post subject: Reply with quote
They cost less to run than fan heaters. The head out of them is very directional though and also fairly localised. So finding that sweet spot between being warm all over and having your leg on fire is a constant battle.
The best solution is one of those oil filled electric heaters. They have a termostat so you can set the room temp you want and forget about it. Most also have a timer built in so it can be set to pre warm the room. Get a 2.5kw one, it might be overkill but that just means it heats the room up faster. Once it's at the right temp it'll use the same power as a smaller one holding it there.
herulach
PostPosted: 00:12 - 19 Jan 2012    Post subject: Reply with quote
Bit obvious, but why not just insulate it better? I worked out that our conservatory needs something like 4kw (2.4m of double radiators) to maintain 18deg at a 0degree ambient temp, not counting what it takes to heat it up in the first place.
Maintaining a decent temp (assuming its a shed/portakabin type effort) will be pretty expensive.
YBR 125>FZS600
fatpies
PostPosted: 00:18 - 19 Jan 2012    Post subject: Reply with quote
I had one or rather the waiting rooms I had to wait in had them.
They are extremely directional. So that while the bit it is pointing at can be burning off. The rest of you can be frozen solid. Unless you get a big enough one to point at you from most directions.
Alternatively make a little space out of plastic sheeting and canvas and heat that instead rather than letting it escape.
angryjonny
PostPosted: 10:52 - 19 Jan 2012    Post subject: Reply with quote
+1 Thumbs Up Karma
When my boiler packed up I ran my house off a single 1.5kw oil filled radiator. Wasn't toasty warm but it kept it liveable. They heat the air and the room itself, those infrared heaters are like sunlight, warm when you're in its glare but otherwise not warm at all.
DrDonnyBrago
PostPosted: 11:20 - 19 Jan 2012    Post subject: Reply with quote
All heaters cost the same to run for the amount of heat that they produce.
I.e. 1 unit of electricity will produce the same amount of heat be it a fan heater, oil filled radiator, infrared heater, toaster, stereo, television, fridge etc etc. They will all produce the same amount of heat for a given unit of energy.
Infrared heaters are good at warming up people as you can point it at them, they are good in big rooms where you don't want to waste energy heating the whole room, just warming the occupants. Oil filled radiators, convection heaters etc warm up the air which then warms the room and warms the people. Fan heaters kind of blur the divide in that they heat the room but can be pointed at the occupants.
It is more pleasant to be in a hot room than in a cold room with a source of heat aimed at you, but also more expensive.
If it is a big room then I'd go for a fan heater and point it at her chair, small room I'd go for a oil filled radiator.
PostPosted: 11:53 - 19 Jan 2012    Post subject: Reply with quote
As above - they warm what they hit, not the air.
So if it's a big space but the work is done in one place, it can make good sense. If it's a smaller space and you're moving around, some (more) oil filled radiators, convection heaters etc are probably the best bet.
Look for rating in watts and go as high as you can
Fan heaters will be less efficient because power is used for the van.
Some heaters produce visible light, though not sure if there's really much 'waste' there.
Infrared heaters may heat items that aren't very good at radiating heat.
Convection heaters may make the air dry, where a radiator style one presumably doesn't 'burn' it as much.
D O G
PostPosted: 12:27 - 19 Jan 2012    Post subject: Reply with quote
We don't have the money to do it is the short answer.
It is a pretty big space - I'd say 6x10x3m, and was originally a battery store for the little railway which ran throughout the site (an old munitions facility). The roof is basically concrete slabs, so terribly insulated, I have looked at putting a floating roof in place but it is looking in the thousands, which we cannot afford at the mo.
She does work in one place at a time for extended periods, but from the replies I think that the IR heaters may not really do what is needed. Can't heat the whole space anymore than it is at the mo - so I think we'll look at fan heaters as a best solution.
Cheers chaps. Karma
angryjonny
PostPosted: 12:35 - 19 Jan 2012    Post subject: Reply with quote
If there's no ceiling insulation at all, you might find you get big results just by sticking a load of this to the ceiling:
https://www.wickes.co.uk/polystyrene-insulation-board/invt/210823/
For a 6x10m room, you're looking at about £130 to cover the whole ceiling. It's only an inch thick but it's better than nothing, and will probably pay for itself in energy savings over a year or two.
(edit: of course this stuff is designed to go "inside" a wall or ceiling - no idea if you'd be breaching any fire regulations or anything, but you get polystyrene tiles, right?)
doggone
PostPosted: 14:32 - 19 Jan 2012    Post subject: Reply with quote
If the existing heating can only raise it to 8C an oil filled electric radiator won't make much difference unless on for hours beforehand.
If the place has cheap rate overnight it could be set to come on at 4am or something.
A fan heater can economically keep a small area warm, or at least make you feel warm directed under a desk for example!
The glare from infra-red is a bit much on nearly all day and as someone mentioned they tend to overheat your head while your feet are cold.
DrDonnyBrago
PostPosted: 15:15 - 19 Jan 2012    Post subject: Reply with quote
G wrote:
Fan heaters will be less efficient because power is used for the fan.
Incorrect.
Any losses from running the fan will end up as heat. Moving air warms it up so any air resistance to the fan and kinetic energy of the air will become heat. Any friction losses in the motor will become heat. Any electrical resistance in the circuits becomes heat. Similarly, any visible light is still absorbed and turned into heat.
ALL electronic devices are 100% efficient heaters.
Last time I checked, neither convection heaters nor radiators thermolytically split water vapour Wink . IME it tends to be the burning of dust and debris on the hot element that gives convection heaters the acrid dry feeling in the air.
fatpies
PostPosted: 15:21 - 19 Jan 2012    Post subject: Reply with quote
Yup,
Just to side track this thread for a moment.
I've always wondered why we don't use old PCs as heaters. In that electricity goes in and ultimately ends up as heat.
So why not heat things with old CPUs number crunching important things? Since you get the electricity to do some work before being turned to heat. Rather than just directly heat?
DrDonnyBrago
PostPosted: 15:28 - 19 Jan 2012    Post subject: Reply with quote
I really like that idea, could have orchestrated number crunching from several hundred old PCs networked into a winter supercomputer. Opensource supercomputing in the winter Thumbs Up .
PostPosted: 16:25 - 19 Jan 2012    Post subject: Reply with quote
So would a 800w fan create the same heat that a 800w heating element would.
A bit fuzzy on the physics these days, but while it does 'make sense', doesn't seem quite right.
colin1
Captain Safety
PostPosted: 17:12 - 19 Jan 2012    Post subject: Reply with quote
a fan heater would heat more efficiently, as it moves the air around more. However for a given power output, a heater without a fan will be cheaper. A radiator actually does most of it's heating by convection not radiation. A fan improves the efficiency by forcing air movement rather than it just being due to hot air rising.
You may be able to get a 2.5kw oil filled radiator, but I doubt you could get a 2.5kw fan heater for the same price.
However, you could team up a oil filled radiator, with the type of fan used to keep people cool in summer. That might be a good combo, as it forces hot air from around the radiator, into the room.
DrDonnyBrago
PostPosted: 17:18 - 19 Jan 2012    Post subject: Reply with quote
Yes it would, All energy is eventually lost as heat.
If you took a sealed room (i.e. no air escaping) with perfect insulation (i.e. no heat conducting/radiating out) and stick a 800w fan in, it would warm the room the same amount as an 800w heater.
Essentially, 100% efficient heaters are found in every electrical device in your house (unless you leave the curtains drawn and light goes out the window Wink ) because all energy (kinetic, light, sound, etc etc) will eventually be lost as heat.
The law gets an update when we are considering things from the perspective of quantum physics, it still holds true but is a little more complex (i.e. energy can be defined as a mass and vice versa ( relativity (E=mc^2 etc))).
if you are interested in a refresher:
Thermodynamics (essentially what we have been talking about):
https://en.wikipedia.org/wiki/First_law_of_thermodynamics
When you let geeks (Einstein) get a hold of it it gets adapted to include mass/energy relativity:
https://en.wikipedia.org/wiki/Conservation_of_energy#First_law_of_thermodynamics
PostPosted: 17:22 - 19 Jan 2012    Post subject: Reply with quote
A fair bit less for the fan heater I'd say.
For instance the cheapest fan heater tescos direct lists is £10; for a 2kw model.
The cheapest oil filled radiator is £20 for a 700w model, with the next up at 1.5kw for £50!
colin1
Captain Safety
PostPosted: 17:42 - 19 Jan 2012    Post subject: Reply with quote
that surprises me, in that case I think fan heaters are the one to go for if the person doesnt mind a bit of noise as it will bring a room up to temperature faster
Ayrton
PostPosted: 17:44 - 19 Jan 2012    Post subject: Reply with quote
fatpies wrote:
Yup,
I would always use my old computer as a sort of heater. If i was cold i would leave it on so that it warms the room up. In a 1.5.x3m room it worked quite well.
Quote Me Happy
PostPosted: 17:49 - 19 Jan 2012    Post subject: Reply with quote
Make a wood burning stove out of an old gas canister.
colin1
Captain Safety
PostPosted: 17:55 - 19 Jan 2012    Post subject: Reply with quote
That's gonna be a lot of work, compared to eletric heating as it's not just the canister, it's fitting a flue. Fine if there is already a chimney, in which case could just use the fireplace, but if no chimney, it means making holes in walls or roof for the flue to go out of.
DrDonnyBrago
PostPosted: 18:30 - 19 Jan 2012    Post subject: Reply with quote
One thing to bare in mind with fan heaters is that some can have a really annoying thermal cut out switch as a temperature controller.
I have this Delonghi, it is shit:
https://www.swiftelectrical.net/store/image/cache/data/hve134-500x500.jpg
It is actually very hot when it runs but every 5 minutes or so it will stop for a few minutes because the built in thermometer has got hot and told it to stop. The idea is that you turn it on, set he temperature and walk away, in reality the temp controller gets heated by the heater body when the room is still freezing and wont come back on until the sensor has cooled down. It is an utterly useless piece of shit.
My advice would be to get a cheaper one without a thermostat, just heat settings. At the very least avoid that one like the plague.
D O G
PostPosted: 20:35 - 19 Jan 2012    Post subject: Reply with quote
That probably wouldn't match well with the large quantities of volatile, flammable solvents she has there. Laughing
I was looking at this one.
Thoughts?
Hex
Party Boy
PostPosted: 00:02 - 20 Jan 2012    Post subject: Reply with quote
I had one of them for the shop. Will definitely heat your room
My only issue is when it hits the temperature, it turns off the element butnot the fan. So you end up with a constant breeze, but if the elements on all the time its no issue and a great heater for a good sized area.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
PostPosted: 01:30 - 20 Jan 2012    Post subject: Reply with quote
I like the ET05 for use with electric heaters - https://www.google.co.uk/search?q=et05 .
You can set the temperature and it'll turn your heater on/off as required. Will only work with heaters that can turn on when power is turn on at the plug of course (fancier ones may go in to a 'stand by' when power is first applied.)
It works much better than the on-device thermometers in my experience as you can position it away from the heater.
The last post was made 14 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 133.72 Kb
