| D O G |
 D O G World Chat Champion
 Posted: 23:33 - 18 Jan 2012 Post subject: Infrared heaters - anyone used them? Opinions? |
Hello.
The missus has a small studio in the middle of nowhere where she does her arty business stuff. Problem is that the heating (or rather the insulation of the building) is dire, when she turned up this morning it was 4degrees inside, and after the heating being on full bore all day it was a balmy 8 degrees.
This is not ideal, especially when doing detailed work, and we can't use one of those propane space heater things as there is insufficient ventilation. It's only her, or her and one other bod, who is there at any one time, and so I thought an infrared heater would be a good idea - it is just her we need to keep warm.
I've never used one, neither has she, just wondering whether anyone on here has, what their thoughts are on them, and if you have any other ideas.
Do they cost a lot to run, relative to others?
Thanks in advance! |
| Frost |
 Frost World Chat Champion
| herulach |
 herulach World Chat Champion
| fatpies |
 fatpies World Chat Champion
| angryjonny |
 angryjonny World Chat Champion
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
 Posted: 11:20 - 19 Jan 2012 Post subject: |
All heaters cost the same to run for the amount of heat that they produce.
I.e. 1 unit of electricity will produce the same amount of heat be it a fan heater, oil filled radiator, infrared heater, toaster, stereo, television, fridge etc etc. They will all produce the same amount of heat for a given unit of energy.
Infrared heaters are good at warming up people as you can point it at them, they are good in big rooms where you don't want to waste energy heating the whole room, just warming the occupants. Oil filled radiators, convection heaters etc warm up the air which then warms the room and warms the people. Fan heaters kind of blur the divide in that they heat the room but can be pointed at the occupants.
It is more pleasant to be in a hot room than in a cold room with a source of heat aimed at you, but also more expensive.
If it is a big room then I'd go for a fan heater and point it at her chair, small room I'd go for a oil filled radiator. |
| G |
 G The Voice of Reason
| D O G |
| angryjonny |
 Posted: 12:35 - 19 Jan 2012 Post subject: |
If there's no ceiling insulation at all, you might find you get big results just by sticking a load of this to the ceiling:
https://www.wickes.co.uk/polystyrene-insulation-board/invt/210823/
For a 6x10m room, you're looking at about £130 to cover the whole ceiling. It's only an inch thick but it's better than nothing, and will probably pay for itself in energy savings over a year or two.
(edit: of course this stuff is designed to go "inside" a wall or ceiling - no idea if you'd be breaching any fire regulations or anything, but you get polystyrene tiles, right?) |
| doggone |
 doggone World Chat Champion
| DrDonnyBrago |
| fatpies |
| DrDonnyBrago |
| G |
| colin1 |
 colin1 Captain Safety
| DrDonnyBrago |
| G |
| colin1 |
| Ayrton |
 Ayrton World Chat Champion
 ..... Quote Me Happy
| colin1 |
| DrDonnyBrago |
 Posted: 18:30 - 19 Jan 2012 Post subject: |
One thing to bare in mind with fan heaters is that some can have a really annoying thermal cut out switch as a temperature controller.
I have this Delonghi, it is shit:
https://www.swiftelectrical.net/store/image/cache/data/hve134-500x500.jpg
It is actually very hot when it runs but every 5 minutes or so it will stop for a few minutes because the built in thermometer has got hot and told it to stop. The idea is that you turn it on, set he temperature and walk away, in reality the temp controller gets heated by the heater body when the room is still freezing and wont come back on until the sensor has cooled down. It is an utterly useless piece of shit.
My advice would be to get a cheaper one without a thermostat, just heat settings. At the very least avoid that one like the plague. |
| D O G |
| Hex |
 Hex Party Boy
 Posted: 00:02 - 20 Jan 2012 Post subject: |
I had one of them for the shop. Will definitely heat your room
My only issue is when it hits the temperature, it turns off the element butnot the fan. So you end up with a constant breeze, but if the elements on all the time its no issue and a great heater for a good sized area. ____________________ The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio |
| G |
 Posted: 01:30 - 20 Jan 2012 Post subject: |
I like the ET05 for use with electric heaters - https://www.google.co.uk/search?q=et05 .
You can set the temperature and it'll turn your heater on/off as required. Will only work with heaters that can turn on when power is turn on at the plug of course (fancier ones may go in to a 'stand by' when power is first applied.)
It works much better than the on-device thermometers in my experience as you can position it away from the heater. |
The last post was made 14 years, 269 days ago. Instead of replying here, would creating a new thread be more useful? |
