| stevo123 |
 stevo123 Nitrous Nuisance
 Posted: 12:13 - 19 Sep 2004 Post subject: Baking soda to clean exhaust the rs125 |
Hi, i am going to have a go at cleaning the gunk from the exhaust system. How much of the soda do i need, was thinking bout 3/4 of a cup full? Also do i use cold water or hot? Thanks in advance  |
| sickpup |
 sickpup Old Timer
| badlydamaged |
 badlydamaged Spanner Monkey
 Posted: 15:38 - 19 Sep 2004 Post subject: |
Hey, I use caustic soda when decoking exhausts, normally lots of it (I dont bother to measure it) and find it works best with lots of hot water (best as in lots of bubbling and violent release of nasty gases). You can use it with cold water, as the soda causes the water to heat up as it reacts, however it works quicker with hot water.
Just dont use it on any aluminion alloys or aluminion, if you want to know why just chuck an old Coke can or similar into the solution and watch it slowly discolve away.
Oh, and if you get any caustic soda onto your skin, or clothes rinse it off with lots of cold water, as its really nasty stuff!
Cheers, Jonathan ____________________ My bike: 1988 Kawasaki KH100 Status: Polluting Devon with two stroke smog and noise pollution!
"Its not your engine size that matters!, It's what you do with it that counts"
Add me to MSN if you want! [email protected]. |
| stinkwheel |
 Posted: 15:47 - 19 Sep 2004 Post subject: |
Yeah, it is caustic soda (sodium hydroxide) that you want for that job. As its name suggests, it is very caustic so eye protection and rubber gloves would be a good idea, it is sold as drain cleaner.
Take the exhaust off, stick a potato in one end and fill up with a strong solution of caustic. After about 20 minutes, empty out (down the drain, which it will clean) and flush out with plenty of water, a hosepipe is ideal. Throw the potato in the bin in case something tries to eat it.
Caustic soda will dissolve exhaust coke, alloy, aluminium, paint, skin and eyes. Bear this in mind! ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| ZRX61 |
 ZRX61 Victor Meldrew
| stevo123 |
 Posted: 19:55 - 19 Sep 2004 Post subject: |
don't know where to get this caustic stuff from, tried mr muscle drain cleaner. did nothing at all . Think its pretty clean anyhow. |
| badlydamaged |
 Posted: 20:02 - 19 Sep 2004 Post subject: |
I get mine from the local DIY shop, just ask around as to where you can get it locally, its pretty easy to get hold of . ____________________ My bike: 1988 Kawasaki KH100 Status: Polluting Devon with two stroke smog and noise pollution!
| ZRX61 |
| mr jamez |
 mr jamez World Chat Champion
 Posted: 20:41 - 19 Sep 2004 Post subject: |
You can get it from homebase, seal up one end of the exhaust, mix caustic soda with water then fill it up and allow it to soak for a few hours. When you pour it out the water should be brown and 'orrible btw, if you have any cuts on your hands wear gloves as it stings like hell when it gets in them  |
There is a gap of 3 years, 11 days between these two posts... |
| rg500 |
 rg500 L Plate Warrior
 Posted: 03:11 - 01 Oct 2007 Post subject: |
GOOD O'L CAUSTIC SODA,WORKS A TREAT IF YOUR CHAMBERS ARE NOT COKED UP LIKE - 2MM THICK. I HAVE AN OLD RZ/ RD500, CURRENTLY DECOKING THE EXHAUSTS. 250M OF CAUSTIC SODA IN A BUCKET OF HOT WATER, BE VERY VERY CAREFULL WHEN "ADDING" THE CAUSTIC TO THE HOT WATER, ONE TABLE SPOON AT A TIME, ALWAYS LEAVE PLENTY OF ROOM BETWEEN YOURSELF & THE BUCKET IN CASE OF ANY FLARE UP, & OBVIOUSLY WEAR ALL THE SAFETY STUFF, GOGGLES & GLOVES. SO ROUGHLY EIGHT TABLE SPOONS OF CAUSTIC. MIX WITH A TALL WOODEN STICK UNTIL DISOLVED.I USED A SINK PLUG I BOUGHT FROM THE HARDWARE TO BUNG UP ONE END OF THE EXHAUST, THEN SEALED IT UP WITH BLACK DUCT TAPE - JUST THE PLASTIC STRETCHABLE TAPE IS OK. SIT THE PIPE UPRIGHT, WITH THE BUNGED END ON THE FLOOR. SLOWLY & CAREFULLY POUR YOUR SOLUTION INTO THE UPRIGHT END (OBVIOUSLY), USING A FUNNEL, UNTIL IT REACHES THE TOP, AND IS COMPLETELY FULL. I LEFT MINE IN THEIR OVERNIGHT, CAUSE THE PIPES WERE PRETTY GUNKED UP. NEXT DAY, POOR OUT ALL THE SOLUTION & WATCH ALL THE SHIT COME OUT OF IT. TAKE OUT THE BUNG, THEN FLUSH THROUGH WITH COLD WATER - HOSE IS A GOOD OPTION. MAKE SURE ALL ALLOY PARTS ARE REMOVED, AND OF COURSE THE BAFFLE. FOR REALLY HEAVY SOLID BUILD UP, THE OXY MAY HAVE TO COME OUT. HEAT UP THE ENTIRE CHAMBER TILL THE PAINT STARTS TO REMOVE & TRY TO KEEP THE WHOLE PIPE A UNIFORM, VER HOT TEMP. WHEN YOUR SATISFIED THIS IS OK, DUMP THE EXHAUST IN A COLD BATH OF WATER TO REVERSE THE ACTION, THIS METHOD AGAIN SHOULD BE DONE CAREFULLY WHEN DUMPING THE EXHAUST IN EITHER, YOUR SWIMMING POOL, BATH TUB, OR AT LEAST A HOSE - NOT SURE IF THE MISSUS WOULD APPRECIATE THE BATH TUB OR POOL BY THE WAY. MIX UP ANOTHER CAUSTIC SOLUTION AS DESCRIBED BEFORE AND POUR INTO THE EXHAST FOR ANOTHER OVERNIGHT CAUSTIC BATH TO RELEASE ALL SCALING. IF ALL THIS FAILS, WWW.JOLLYMOTO.COM, GREAT SET OF CHAMBERS AT ABOUT $2500aud, WORTH EVERY CENT, SEE YA'S. |
| Syx |
 Syx World Chat Champion
 Posted: 12:37 - 01 Oct 2007 Post subject: |
My eyes!  |
| lukamon |
 lukamon World Chat Champion
 Posted: 19:47 - 01 Oct 2007 Post subject: |
my local engine shop has a different method :
1. get a propane torch with 3' flame, stick down one end of pipe
2. wait 10 mins
3. revome torch. carbon (basically coal) is now glowing. position fan at one end of pipe and leave overnight. carbon burns itsself away
(however, it strips all the paint) ____________________ killa wrote: Im an ass man myself |
| ncrn |
 ncrn World Chat Champion
 Posted: 20:32 - 01 Oct 2007 Post subject: |
| Blau Zedong |
 Blau Zedong Banned
 Posted: 21:38 - 01 Oct 2007 Post subject: |
Pissed my pants at the title of this thread. Baking soda - won't clean your spanny but might make it rise at gas mark 5 for 40 mins.  ____________________ 18:54:48 Rob Fzs: jews don't give away stuff for free
18:54:59 Rob Fzs: unless its their clothes/ hair/ golden teeth |
| bladerunner |
 bladerunner World Chat Champion
The last post was made 19 years, 15 days ago. Instead of replying here, would creating a new thread be more useful? |
