Bar end mirrors
c_dug
PostPosted: 12:09 - 30 Jan 2012    Post subject: Bar end mirrors Reply with quote
Hi guys,
My current commute is directly through the centre of London, I've been folding my mirrors in lots to fit through gaps, and somehow one came loose and is somewhere along the A13 at the moment.
I considered removing the other mirror, I can negotiate traffic well enough with the use of shoulder checks, but fear of plod and my final three points is enough for me to want mirrors. My choice is standard or bar end.
Are bar end mirrors any good? Will they hinder my filtering less than standard mirrors? Will I actually be able to see behind me? Will I look ghey?
Thanks
Conan
[/img]
nowhere.elysium
The Pork Lord
PostPosted: 12:25 - 30 Jan 2012    Post subject: Reply with quote
I've got a bar end mirror on my right bar. I took the stock ones off some time ago, and haven't suffered any ill effects. If anything, I've actually got a better view of what's behind me now, because the mirror doesn't solely aim itself at the inside of my elbow, which is a bonus.
Not had any problems with filtering, either.
As to whether it makes you the ghey, that's down to you to decide.
c_dug
PostPosted: 12:36 - 30 Jan 2012    Post subject: Reply with quote
Does it sweep under your bar or stick out to the side?
nowhere.elysium
The Pork Lord
PostPosted: 12:43 - 30 Jan 2012    Post subject: Reply with quote
It actually sticks up from the bar end. I'll get a photo when I'm down in the garage later on. It's one of those cheapo Chinese ones, which comes in a pair for <£30. I'd imagine that if it's on a set of riser or flat bars, you'll be able to get away with having the mirror on under the bar, but since my bike's got clip-ons, it seemed the most sensible fitting method.
c_dug
PostPosted: 12:52 - 30 Jan 2012    Post subject: Reply with quote
Didn't think of that!
WannaBeDude
PostPosted: 17:46 - 30 Jan 2012    Post subject: Reply with quote
15 quid hk oberon rip offs ...
https://i37.photobucket.com/albums/e53/covdude/2011/IMG_0136.jpg
nowhere.elysium
The Pork Lord
PostPosted: 18:17 - 30 Jan 2012    Post subject: Reply with quote
hahadumball wrote:
pretty decent just a bit hopeless if you have a passenger, probably not in all cases but if i do i can only see legs
You're doing it wrong, then. I have a totally unobstructed view when my Mrs is on the back. Aim them so you can only just see the outer edge of your hip. Unless you've got a bow-legged pillion (ergo, this won't work for warped), you should be fine.
nowhere.elysium
The Pork Lord
PostPosted: 18:24 - 30 Jan 2012    Post subject: Reply with quote
hahadumball wrote:
I have clip ons that point inwards with next to no movement and im pretty sure the bar ends are adjusted as much as possible but ill take a look later.
You can rotate the mirror arm, if you loosen off the grub screw that's securing it.
c_dug
PostPosted: 18:26 - 30 Jan 2012    Post subject: Reply with quote
covdude wrote:
Any chance of a link please?
nowhere.elysium
The Pork Lord
PostPosted: 18:28 - 30 Jan 2012    Post subject: Reply with quote
Here you go.
:edit: looks like I overestimated the price.
nowhere.elysium
The Pork Lord
PostPosted: 18:31 - 30 Jan 2012    Post subject: Reply with quote
hahadumball wrote:
the movement on it from forward to back is as far as it goes, itll do for now though.
Um, how do you have this set up? Is the arm going in at the top of the bar end, or does it stick in to the end of it?
nowhere.elysium
The Pork Lord
PostPosted: 18:35 - 30 Jan 2012    Post subject: Reply with quote
hahadumball wrote:
Ah. I avoided those ones, because they looked totally unadjustable.
WannaBeDude
PostPosted: 18:40 - 30 Jan 2012    Post subject: Reply with quote
This seller mate, great item, screws / bolt things not much cop, work fine, but not stainless steel fittings. but actual item is same as oberon 80 quid ones.
Colours available .. ?
https://www.ebay.co.uk/itm/Bike-BarEnd-Rear-Convex-CNC-Mirror-Silver-Suzuki-/260837190267?pt=Motorcycles_Parts_Accessories&hash=item3cbb1baa7b
1cyl
PostPosted: 21:09 - 30 Jan 2012    Post subject: Re: Bar end mirrors Reply with quote
c_dug wrote:
I considered removing the other mirror, I can negotiate traffic well enough with the use of shoulder checks, but fear of plod and my final three points is enough for me to want mirrors. [/img]
You can really get points for no mirrors?
Shocked
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
nowhere.elysium
The Pork Lord
PostPosted: 22:24 - 30 Jan 2012    Post subject: Re: Bar end mirrors Reply with quote
Shocked
I don't believe so. I've run bikeswith no mirrors, and had no problems. You've got to blank off the mounting points for MOT, though (I think).
c_dug
PostPosted: 23:48 - 30 Jan 2012    Post subject: Reply with quote
Laughing You've misunderstood, I'm worried about speeding off from lights or something and not knowing there is plod behind me.
c_dug
PostPosted: 23:57 - 30 Jan 2012    Post subject: Reply with quote
https://www.ebay.co.uk/itm/2-X-CHROME-ALLOY-MOTORCYCLE-REARVIEW-MIRROR-BAR-END-NEW-/290595670349?pt=UK_Motorcycle_Parts&hash=item43a8da094d#ht_4789wt_1270
These the sort of oberon-alikes you were on about Gerry?
bikertomm
PostPosted: 00:04 - 31 Jan 2012    Post subject: Reply with quote
I like these kind of mirrors alot, look good on supermoto's I think.
https://www.youtube.com/watch?v=fJK3xQv6OjM
Razz Thumbs Up
WannaBeDude
PostPosted: 00:09 - 31 Jan 2012    Post subject: Reply with quote
As much as they are proberly all the same, i've got these and have pictured them.
The size of the mirrors is smaller than pic suggest, and bar the fittings, the item is top notch and delivered in about 10 days or so.
Stick with what you know and order these, in the colour of your choice. Thumbs Up Idea
The last post was made 14 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 144.58 Kb
