Battery problems..
samold55
PostPosted: 01:03 - 03 Feb 2012    Post subject: Battery problems.. Reply with quote
I posted on here a while back that I was having trouble with my battery dying. It died when it had been raining and from then th e battery had troubles. Id charge the battery once a week through a charger and it would work then die again. I done this for about a month untill it filly died out. I have now bought a new battery and it's died again. This is very annoying lol. What else could it be that is making this happen ?
Sam
samold55
PostPosted: 01:23 - 03 Feb 2012    Post subject: Reply with quote
sorry about the double thread internet crashed Shocked Shocked
whitedevil
PostPosted: 01:30 - 03 Feb 2012    Post subject: Reply with quote
Have you got a multimeter? You need to check the charging system.
have a look here
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
Nick 50
PostPosted: 04:51 - 03 Feb 2012    Post subject: Reply with quote
What bike is it?
Sounds like an Alternator issue not charging the battery, have you checked that? (well if your bike has one).
harscot
PostPosted: 12:11 - 03 Feb 2012    Post subject: Reply with quote
Hi bud, apart from the obvious, Alternater, Rectifier, which you will need to discount first, you may have a frayed or such wire arcing, so that would discharge your bat quickly, they are not easy to find sometimes, hence an auto electriction, if you are not up to speed on electrics, check alternater/rectifier first, then may be take to a garage might save you time and money in the long run, also if you painstakingly go through the forum you wil find a thread somewhere for all the info that you need on how to do it....you may even get a good answer here..good luck..stay loose and safe Thumbs Up
Mikey3
PostPosted: 12:19 - 03 Feb 2012    Post subject: Reply with quote
Sounds like the Reg/Rec (Regulator/Rectifier)
Do a test with a multimeter, like said above, check bike specific info for the output.
They're not TOO expensive on ebay, but brand new theyre £50>
Mike
'04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it'
samold55
PostPosted: 12:28 - 03 Feb 2012    Post subject: Reply with quote
Well I have orded a new regulator the battery is completely dead now even though it's brand new Laughing were is the regulator located by the way ?
Sam
samold55
PostPosted: 13:50 - 03 Feb 2012    Post subject: Reply with quote
Right okay I have just checked over the bike an it turns out the bike has actually been leaking petrol from the tank and it's leaked all over the regulator it basically looks wrecked. I have a spare petrol tank anyway that I will put on and I'll replace the regulator and hopefully that should do the trick.
The last post was made 14 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 54.1 Kb
