bike frozen
Auzfest
PostPosted: 11:04 - 03 Feb 2012    Post subject: bike frozen Reply with quote
Just a big metal block of ice to be honest ,not.firing up.throttle cable sticking and can't even get key in fuel cap.any advice on preventing a freeze up?
Atomic Punk
PostPosted: 11:19 - 03 Feb 2012    Post subject: Reply with quote
Use a bike cover
I may have lost my way but I'm way ahead of schedule.
mistergixer
PostPosted: 11:20 - 03 Feb 2012    Post subject: Reply with quote
Keep it indoors, tucked up with slippers and a blanket, next to the fire with a lovely hot mug of coco.
Space Monkey #7
Kris
PostPosted: 11:32 - 03 Feb 2012    Post subject: Reply with quote
Heat the key up on the gas hob first. Then try it in the lock. Start it on choke and let it run for a while.
www.prisonplanet.com
PostPosted: 11:46 - 03 Feb 2012    Post subject: Reply with quote
Warm/hot water and pour over ignition.
snikks
PostPosted: 12:00 - 03 Feb 2012    Post subject: Reply with quote
I found a hot water bottle applied to ignition allowed me to get my key in this morning (despite the bike having been covered overnight). Once the key was in, full choke and a bit of determination was required to get it started. It's mornings like this that I recall my previous (fuel injected) Varadero fondly.
- CBT: 02/01/11 Theory: 26/04/11 Mod 1: 19/05/11 Mod 2: 19/08/11
- 2007 Honda XL125V Varadero (Sold), 1999 Yamaha FZS600 Fazer (Sold), 2001 CBR600F
anthony_r6
PostPosted: 12:35 - 03 Feb 2012    Post subject: Reply with quote
I'm selling my bike this morning and it won't start, bloody typical. No issues since the day I bought it, been sat for a few days and now won't do anything.
I've got it sat in my hallway next to the radiator, hoping to god that this warms it enough to start before the guy comes to collect.
It sounds like it's just about to start and then it just dies before the engine gets into it's cycle. No idea what to do about it!
PostPosted: 12:37 - 03 Feb 2012    Post subject: Reply with quote
Charge the battery, if its sat there doing nothing its more than likely eaten its life away. My GSXR has been stunning with the battery since I got it. Left it for 3 days and it wont even power the heated grips Laughing
anthony_r6
PostPosted: 13:00 - 03 Feb 2012    Post subject: Reply with quote
I did charge it, no problem with the lights and things- hi-beam as 'bright' as it usually is. Managed to get it going with a little bit of prayer, must've just wanted a warm environment for a little bit.
UnspeedySam
PostPosted: 13:08 - 03 Feb 2012    Post subject: Reply with quote
My trusty ZZR thankfully started nicely this morning. Had to bump it last night though because I left the heated grips on all day. Embarassed
Mrjoolz
PostPosted: 13:27 - 03 Feb 2012    Post subject: Reply with quote
I have heard that if the battery does go flat, even if you charge it, the cells inside are already damaged and wont hold charge again (properly) Had to buy new battery. (This was information given to me by an RAC geezer, few years ago), although this was on my Car
Unsure if its the same on m/c's
Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
Current Bike: Suzuki GSX1300R Hyabusa.....
PostPosted: 13:49 - 03 Feb 2012    Post subject: Reply with quote
Sulfation gonna getcha.
If I turned up to buy a vehicle and the engine was warm, I'd walk away. Shocked
c-m
PostPosted: 14:11 - 03 Feb 2012    Post subject: Reply with quote
Before I sell bikes I usually take them for one last ride, but a good few hours before the sale so they can see it starting from cold.
Can't say i've ever had a problem with a bike not starting due to cold. Usually it's just a case of wipe the snow off the seat, and the bike is ready to go.
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
goto10
PostPosted: 14:29 - 03 Feb 2012    Post subject: Reply with quote
In the evening after getting home I shut the engine off and then slide the choke lever halfway on - I've had the lever frozen solid before and I couldn't get the poxy thing started. Since then never had an issue :)
MightyZoltar
PostPosted: 15:07 - 03 Feb 2012    Post subject: Reply with quote
I haven't used my bike at all since last Friday. Went to start it today. It started first time with the choke on, bit died after a few seconds. Couldn't get it to start after that. Battery was turning the starter motor, but it just wouldn't get going.
It's a 2001 GPZ500. I'm guessing I just need to take a kettle of water to it (carb area?), and it will then start up. Can't imagine there's anything else going on.
_Troy_
PostPosted: 15:14 - 03 Feb 2012    Post subject: Reply with quote
My bike has been starting fine this week, even though its all covered in ice. I'm actually quite impressed given that its a run down GS500! Laughing
Current bike: ZX6R J1
Previous bikes: CLR 125 | GS500 | ZX6R G2 | SV650
mr jamez
PostPosted: 16:04 - 03 Feb 2012    Post subject: Reply with quote
A cheap bike cover will save you a lot of trouble over the winter Thumbs Up
Jayy
Mr. Ponzi
PostPosted: 16:22 - 03 Feb 2012    Post subject: Reply with quote
Mine has started on the first touch of the button every time since I got it. Today, took about 3 seconds before it started, really was freezing this morning.
kawakid
PostPosted: 23:38 - 03 Feb 2012    Post subject: Reply with quote
Optimate everynight for me when it is like this.
I've a twin and a 4.
Seb
PostPosted: 23:52 - 03 Feb 2012    Post subject: Reply with quote
Amusingly my clutch was frozen solid this morning, I'm guessing it was the actual basket and plates as it freed up perfectly within a minute of the bike starting thankfully.
2010 Triumph 1050 Sprint ST
Gazz
PostPosted: 23:57 - 03 Feb 2012    Post subject: Reply with quote
I remember when I was sitting my lessons. It was January and was really freezing outside. The bikes (mine, other guy and our instrctor's) needed fuel so we pulled into a petrol garage.
We couldnt get the fuel tanks open on any of the bikes, so then my instrctor decides to bring out her cigarette lighter right in the middle of the petrol garage and decides to heat the keys under a naked flame!!! Shocked
Cue us being thrown out of the petrol garage and not being allowed to fill up there! Rolling Eyes
kawakid
PostPosted: 00:33 - 04 Feb 2012    Post subject: Reply with quote
My work mate's bike is the luckiest, he has an integral garage and the boiler for the house is in there, just by his bike.
Jealous....
ajbsmirnoff
PostPosted: 00:34 - 04 Feb 2012    Post subject: Reply with quote
Go to the local supermarket. Buy pasty and newspaper. Impulse purchase deicer on way out.
Squirt deicer onto ice, eat pasty while making pithy comments about newspaper. Admire deiced locks. Repeatedly forget to put troll faces into photobucket.
stonesie
PostPosted: 18:46 - 04 Feb 2012    Post subject: Reply with quote
WD40 or ACF-50 in the locks will stop the water building up in there and if it's not there it can't cause problems, oil the sticky cables too.
I stripped/cleaned/greased the lock on my dads car 4 years ago and it has never frozen since Thumbs Up
The last post was made 14 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 125.63 Kb
