| grantl |
 grantl Two Stroke Sniffer
 Posted: 10:24 - 21 Sep 2004 Post subject: new bike needs some work |
i bought another 250r last weekend for a pretty cheap price, it seems to run great but does have some probs listed below,
1st
https://www.galleryworkers.com/images/moto/part.jpg
this part whatever it is called has a small crack in it leaking some oil what is your guys opinions on fixing this? is there a way of blocking up the crack or is it wiser to buy a new part, how much would a new one set me back?
2nd
https://www.galleryworkers.com/images/moto/gearever.jpg
gear lever is bent should i just hammer it back to place or is it cheap enough to buy a new one and put that on?
3rd
https://www.galleryworkers.com/images/moto/footrest.jpg
foot rest got bent out of shape and if you look closer you can see that the metal is fractured. How much for new one of these?
finally
4th
https://www.galleryworkers.com/images/moto/handle.jpg
handle bar seems to be bent a little how would one get it back to better shape? or if it functions ok as should i just leave it as is.
as for the clutch lever thats only 12 bucks i should know i broke it on my other bike
thanks for help guys  |
| kev |
 kev I Hump Things
| grantl |
| kev |
 kev I Hump Things
| Big Pete |
 Big Pete Spanner Monkey
| grantl |
| stinkwheel |
 Posted: 13:57 - 21 Sep 2004 Post subject: |
If you open that crack out a bit, you will be able to repair it with a product called JB weld or lumiweld, nae bother (degrease thoroughly first). They are both epoxy based chemical metals and once cured can even be machined...handily they are also the same colour as your alternator casing. If it is alloy you could also get someone to TIG weld it.
That lever will bend back but take it slowly and use plenty of heat.
You might find you can get a set of flashy aftermarket rearsets for less than a replacement hanger.
If it were me, I would see if I can live with the bar like that, possibly rotate the clamp round the fork-leg a bit. Others are bound to argue with me on this point. A set of universal clip-ons aren't all that expensive if you don't like the idea. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| grantl |
| ZRX61 |
 ZRX61 Victor Meldrew
 Posted: 16:03 - 21 Sep 2004 Post subject: |
The trick to bending levers back to shape it getting the temp correct. Rub a bar of soap on the part & then heat it, when the soap turns black it;s the right temp to bend (gently!!)without snapping  |
| grantl |
| grantl |
 Posted: 10:13 - 22 Sep 2004 Post subject: |
btw what should i use to heat the metal up without blowing the bike up
or is there not much risk of using open flame near clutch lever?  |
| stinkwheel |
 Posted: 13:39 - 22 Sep 2004 Post subject: |
| grantl |
 Posted: 03:18 - 23 Sep 2004 Post subject: |
yep silly question, i was being part lazy not wanting to take it off
fixed it early this morning seemed to work well
thanks for help |
| ZRX61 |
| Big Pete |
| leg-end |
 leg-end Derestricted Danger
The last post was made 21 years, 359 days ago. Instead of replying here, would creating a new thread be more useful? |
