piston issue
mgs41987
PostPosted: 17:18 - 01 Feb 2012    Post subject: piston issue Reply with quote
ordered a piston off ebay for my clr 125 and the one i have recieved is slightly different its slightly taller oil holes in the same places etc just height about 3 - 4mm will i be an issue
mgs41987
PostPosted: 19:00 - 01 Feb 2012    Post subject: Reply with quote
it 3 mm bigger
dangerousdave
PostPosted: 19:21 - 01 Feb 2012    Post subject: Reply with quote
If the skirt clears the crank then 3mm more on the skirt wont make a difference.
The problem comes if the longer skirt reduces the clearance to the crank webs to the point where it hits the crankshaft. Install the piston onto the con-rod and turn the engine over by hand. If it doesn't hit the crank, then it will work ok.
This is the problem with buying pattern parts - they aren't always the same as the standard parts in some ways. They usually work fine though.
If the piston you have bought off eBay is for a CLR125 then it will probably fit ok. If it doesn't then send it back.
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
mgs41987
PostPosted: 19:35 - 01 Feb 2012    Post subject: Reply with quote
ok cool will i have to assemble engine completely as its cam chain
to rotate it so i dont get my timings wrong
PostPosted: 20:34 - 01 Feb 2012    Post subject: Reply with quote
mgs41987 wrote:
it 3 mm bigger
What is 3mm bigger? Gudgeon pin to crown or gudgoen pin to edge of skirt?
If it's bigger from pin to crown don't try to fit it - you'll mash up your valves perhaps worse.
mgs41987
PostPosted: 21:05 - 01 Feb 2012    Post subject: Reply with quote
its gudgeon to crown lol il order a genuine one
dangerousdave
PostPosted: 13:45 - 02 Feb 2012    Post subject: Reply with quote
... and send the other one back to where it came from for a full refund - they've sent you a part that doesn't even fit your bike.
bikenut
PostPosted: 14:26 - 02 Feb 2012    Post subject: wrong piston Reply with quote
:karma: absolutely right, send it back and get proper one.
if piston sits 3mm higher then it will most probably hit the cylinder head, mangle plug and valves. compression height.
compression ratio would be effected if piston cleared.....but suspect valve may well crash with piston.
it may have been possible to fit head with out camshaft ( or rockers maybe ) so that the engine could be rotated to see if everything clears, but what about revs.....
the right thing to do is get correct piston and your money back for the incorrect one.yuo are protected by law
some pics would be nice......
mgs41987
PostPosted: 17:13 - 04 Feb 2012    Post subject: Reply with quote
fitted it and roatated engine and all seems fine no friction etc goes nice and smoothly no knocks etc would it be safe to put back in frame and start it up in peoples opinion and also i split the gasket where the barrel meets the bottom end where the cam chain goes through is that an issue could i put some liquid gasket in place as its not on the barrel part and only cam chain
Robby
Dirty Old Man
PostPosted: 18:14 - 04 Feb 2012    Post subject: Reply with quote
I'm somewhat confused, did you send it back for the right one, or just it anyway, knowing that it's the wrong part for your bike?
Nope.
PostPosted: 00:51 - 05 Feb 2012    Post subject: Reply with quote
I think he did the latter.
Since you've already gone that far you may as well just fire it up. Whats the worst that could happen?
Rolling Eyes
The last post was made 13 years, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 86.04 Kb
