Painting an exhaust pipe
rob-jones
PostPosted: 23:40 - 04 Feb 2012    Post subject: Painting an exhaust pipe Reply with quote
I was wondering what is the best way to go about painting an exhaust pipe?
Can I just simply remove it from the bike and paint it? Or do I have to sand anything? I have absolutely no idea Embarassed
Thanks in advance!
Currently own a Honda NSR 125.
Moxey
PostPosted: 00:39 - 05 Feb 2012    Post subject: Reply with quote
If its just mild steel then maybe sand any rust off (use wire wool/brush or sand paper whatever) if there is any.
Look for a specific type of heat resistant paint doesn't have to be exhaust specific, for example on my Varadero used to use a can of matt black designed for painting chimney sections covered up to 1500 degrees I think.
Right now doing the CBR headers, just sanded a little rust off them and sprayed two coats of VHT matt black, no need for primer with that stuff but check the back of the tin/can before use some may require a primer.
gray84
PostPosted: 11:26 - 05 Feb 2012    Post subject: Reply with quote
What I've done in the past it.
Sand down with 400grit paper. Smoother the pipe the better it looks.
Clean with thinners or white spirit of some sort
Get warm near heater
Paint with high temperature paint..recommend Pj-1 paint. Even used this on a log burning stove. And goes on nice and even looking. Buy the spray type not brush on.
0l0dom0l0
PostPosted: 11:38 - 05 Feb 2012    Post subject: Reply with quote
pj-1 seems to get the best reviews.
If you use the search function you can also find loads of other threads on this subject and see what you think.
The last post was made 13 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 44.25 Kb
