Advice please, on toilet plungers.
x.carol
PostPosted: 22:44 - 06 Feb 2012    Post subject: Advice please, on toilet plungers. Reply with quote
Hello!
I have no idea who/where to ask, so I thought this forum would have to do :L
Could anyone recommend a good toilet plunger for around <£10?
Had a few people round at mine for drinks the other night & bog hasnt been the same since Rolling Eyes Don't wanna know whats down there.
Thanks!
Yammy Viragoo 535 ♥
fatpies
PostPosted: 22:50 - 06 Feb 2012    Post subject: Reply with quote
Eww..
Have you tried pouring down some boiling hot water?
If this fails then try some causdic soda.
If that fails THEN you get your hands dirty.
Any plunger will do tbh even the £3.99 ones you get at indie hardware stores.
Just push it down the toilet hole and try and make a seal and pump a couple of times. Be wary if you live in a block o flats you may get.... erm blow back.
Serendipity
PostPosted: 23:29 - 06 Feb 2012    Post subject: Reply with quote
I remember watching some fly on the wall show about a casualty department in the Caribbean several years ago. One thread followed an unfortunate chap who had attempted to clear his blocked toilet with sulphuric acid and petrol. Then, for reasons known only to him, he introduced a naked flame to the situation. Being treated for heat AND chemical burns simultaneously is not cool.
However, back on topic. I’m a serial toilet blocker. I produce turds of such girth and volume that I can overwhelm all but the most heroic bog. My current house has an amazing toilet that I haven’t been able to block in nearly six years. Amazing build quality… Cool
…but I digress. My standard remedy is a large vessel (bucket, washing up bowl, etc. Whatever will hold several litres) filled with plain old cold water, poured rapidly from a decent height directly into the bowl. That’ll shift almost anything. I’ll wager that’s all you’ll need. Quick, clean, effective. But! If it’s so blocked that water is draining really slowly please choose a bucket with less volume than the toilet bowl, just in case.
Failing that unbend an good stiff coat hanger and put your best stabbing technique into practice. If you suspect that it may be “lady products” maybe bend a little hook into the end of the wire and see what you can drag out.
After that all you need is a strong stomach and a good nail brush… …for your nails obviously, not for clearing the toilet. Thumbs Up
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
yambabe
PostPosted: 23:32 - 06 Feb 2012    Post subject: Reply with quote
check that you don't have an blockage outside before you go plunging inside. Thumbs Up
Raffles
PostPosted: 23:33 - 06 Feb 2012    Post subject: Reply with quote
Plungers are OK for clearing blockages in sinks, baths, showers etc but are nigh-on useless for clearing blockages in shitters. Whenever a bog gets blocked the first place to take a look is inside the nearest manhole inspection chamber.
harscot
PostPosted: 00:00 - 07 Feb 2012    Post subject: Reply with quote
Smile Ok, you can get what you require in the likes of B&Q,Focus,£ stretchers etc, or a hardware shop for a couple of quid, if you just have a loo brush, wrap an old cloth around it, push it down the pan ( wrap well so it won't come off to exasperate situation ) to create a seal, push up/down a few times to get sucksion, and hopefully dislodge whats there, if unsucsesfull try the bucket of water trick, watching carefully for overfill....keep going with the rest of above suggestions, if all else fails phone a plumber, maybe you've got a very good friend who might help you !!...good luck in you endevours Smile Thumbs Up
andys675
PostPosted: 01:35 - 07 Feb 2012    Post subject: Reply with quote
get a garden hose and ram it down the hole, one of those thick ones with the reinforcement you can see in the tubing, keep twisting it and pushing it until it will go no further and then keep ramming it in and out
for a plunger, go buy a mop, the old type with cotton string head, a nice big one, then use that as a plunger in the bowl
Ingah
PostPosted: 01:42 - 07 Feb 2012    Post subject: Reply with quote
Tie a plastic bag around the end of a mop and use it as a plunger, in and out a few times and it suddenly clears. Awesome Very Happy
Tried, tested and working when the "suddenly pour a load of water" trick had failed.
-- Ingah
-LG-
PostPosted: 02:52 - 07 Feb 2012    Post subject: Reply with quote
Wire coat hanger works wonders...my toilet is shit for taking my crap...always getting blocked!
Snow rider wrote: I'm far to annoying to be near for long periods of time
Suntan Sid
PostPosted: 07:44 - 07 Feb 2012    Post subject: Reply with quote
It's highly unlikely it's the toilet that is blocked.
Any blockage will be further down the pipe work.
Look for the first cover on the outlet pipe, this won't neccesarily be a large manhole cover, it could be a small cover on a rodding point.
Once you've found that, lift the cover, if the chamber is full, obviously the blockage is downstream, if it's empty you'll need to clear the blockage from upstream.
If the pipes are a relatively straight run, buy or borrow some drainage rods and remove the blockage with them. If you suspect that there are some bends in the pipe get a garden hose and work it into the pipe using full mains pressure once you've got the hose in.
Remember if the blockage is a reasonable distance from the toilet, there will be enough pressure behind the blockage to push the sewerage out of the manhole, so make sure your head isn't to close to the chamber!
I used to work with a CCTV unit, surveying sewers, and I've unblocked more drains than I care to remember.
FACT, sweetcorn is undigestible, don't know why anyone bothers eating it!!
neil.
PostPosted: 10:28 - 07 Feb 2012    Post subject: Reply with quote
https://images.manufactum.de/manufactum/produktdetail/71559_1.jpg
Skudd
PostPosted: 12:09 - 07 Feb 2012    Post subject: Reply with quote
+1,000,000 Thumbs Up
I bought a brand new house on a very new estate and the first Xmas most of the estate had backed up. Some had tried to clear from inside the home and made a right mess. I had rods, so was able to do every thing outside and clear my bit to the main drain. the main issue was builders leaving rubble down the drains or just the fact that sand and gravel got stuck in there.
angryjonny
PostPosted: 12:46 - 07 Feb 2012    Post subject: Reply with quote
Be honest Sid. Is that brown hue to your skin really a suntan?
PostPosted: 12:53 - 07 Feb 2012    Post subject: Reply with quote
If it is the toilet end just put a bin bag round your arm and go grabbing.
Speed
PostPosted: 17:10 - 07 Feb 2012    Post subject: Reply with quote
Boiling hot water, let it sit for a bit. Failing that, a wire coat hanger and a bin bag Laughing
Suntan Sid
PostPosted: 22:37 - 07 Feb 2012    Post subject: Reply with quote
Laughing Well these days my tan is real, however I shall tell you a tale.
I got roped into doing some sampling work at various treatment plants.
At the time the water authority was looking to upgrade the sewers in Gretna.
Consequently we had monitoring equipment at a sewerage pumping station.
As the system was working at 120% the sump at this particular pumping station needed to be emptied on a regular basis.
So I turn up to download the data from the samplers, as I'm doing this the honey wagon turns up to pump a tanker load of effluent from the well. Everything was going smoothly until the connection to the tanker gave up the ghost. The resultant shower of effluent covered me, the tanker driver and the foreman from head to toe.
I was not best pleased!!
Fortunately I was on my bike (KR1s) so I didn't stink my car out on the way home! Rolling Eyes
The last post was made 14 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 92.62 Kb
