| Raphy |
 Raphy Derestricted Danger
| monkeyman |
 monkeyman Scooby Slapper
| Beamexican |
 Beamexican Borekit Bruiser
| Raphy |
| jimmyRS |
 jimmyRS Scooby Slapper
 Posted: 16:22 - 07 Feb 2012 Post subject: |
as above have asked, does it feel like its lacking fuel? or does it feel like its bogging down due to too much fuel? Does holding it at 1/4-1/2-3/4 throttle make any difference to how the revs climb or does it still die?
if you bought it like this and it hasn't run right since the get go, id suggest that you may have to small/big a main jet.
correct pilot but incorrect main jet size would explain how it idles nicely but revs poorly.
if it used to run fine and all of a sudden now has just decided to play up, i'd hazard a guess at compression buddy. test the compression if you can
gluck
p.s. no hard feelings monkeyman
| Beamexican |
| bikenut |
 bikenut World Chat Champion
| Raphy |
| Speed |
 Speed Could Be A Chat Bot
 Posted: 13:17 - 08 Feb 2012 Post subject: |
May be a stupid suggestion so bear with me...
CDI unit?  |
| st3v3 |
 st3v3 Super Spammer
| Raphy |
| bikenut |
| Raphy |
| Raphy |
| mysterious_rider |
 mysterious_rider World Chat Champion
| Raphy |
| bikenut |
| bikenut |
| dungbug |
 dungbug Could Be A Chat Bot
| jimmyRS |
 Posted: 16:41 - 09 Feb 2012 Post subject: Re: me again |
| Raphy |
| nightshaddow |
 nightshaddow Nearly there...
 Posted: 18:27 - 09 Feb 2012 Post subject: |
no one has asked you to check the inlet manafold
you have stipulated the fuel is good and jets and carb is clean
it has been advised you check spark and replace plug and check lead i presume you have
you have checked the reeds
once you have tried the cdi check there is no holes,splits or cracks in your inlet manafold that would cause it to die instantly when reved had one split on me before it would idle perfect then die with anything above 1500 rpm
[/quote] ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
| Mikey CB500 |
 Mikey CB500 Scooby Slapper
| Raphy |
| Mikey CB500 |
The last post was made 14 years, 2 days ago. Instead of replying here, would creating a new thread be more useful? |
