Exhaust wrapping...
Valentino Mossy
PostPosted: 23:54 - 12 Feb 2012    Post subject: Exhaust wrapping... Reply with quote
Pros and cons please ?
Fancy wrapping the pipes on the duke while its all stripped down once i've cleaned them all up..
Corrosion problems ? Keeps the heat down ?
Any one fitted them before ?
Thanks all...
lozzypop1
Certified MILF!
PostPosted: 23:59 - 12 Feb 2012    Post subject: Reply with quote
Pros: Um
Cons: It costs money, looks shit, does absolutely nothing, causes corrosion, smells of wet sheep when wet.
In other words... No No No No No.
That is all.
Valentino Mossy
PostPosted: 00:03 - 13 Feb 2012    Post subject: Reply with quote
Is that your words or the voice of sickpup being channeled through you Wink lol....
I like wet sheep, they make me horny....
lozzypop1
Certified MILF!
PostPosted: 00:09 - 13 Feb 2012    Post subject: Reply with quote
I said the No No No No No part... Wink
sickpup
Old Timer
PostPosted: 00:18 - 13 Feb 2012    Post subject: Reply with quote
I asked if you'd caught the ghey?
Rowey
PostPosted: 00:58 - 13 Feb 2012    Post subject: Reply with quote
Exhaust wrap is only acceptable on choppers, retro or rats.
Ceramic coating. That is all.
ZX6R C6F.
iooi
PostPosted: 10:08 - 13 Feb 2012    Post subject: Re: Exhaust wrapping... Reply with quote
Thanks all...
Any corrosion on the pipes will get worse as you can't see it...
How ill it keep heat down ? Heat is generated by the gasses produced by combustion.... So no matter what the pipes will get that hot.
All you are doing is helping that heat stay in the pipes.
Pipes are easy to keep clean Thumbs Up
How easy is this lagging to keep clean ?????
What next wrap the whole bike in bubble wrap Laughing
GixxerChick
PostPosted: 11:19 - 13 Feb 2012    Post subject: Reply with quote
If the wrapping get wet and covered in road grime, its all wrapped round your pipes, so you cant see what is happening beneath until your unwrap it and ten its too late and may cost you a new set of down pipes.
Also people will think your trying to hide something, ie a hole in a weld joint or already badly corroded pipes.
My opinion, more hassle than its worth.
Chase Me. Chase Me
steven_191
PostPosted: 11:46 - 13 Feb 2012    Post subject: Reply with quote
From what I undersnd the heat in the gases give the gas a higher velocity. The hotter the exhaust gas the faster the evacuation of said has.
The heat wrap keeps the heat inside. It aids to prevent the loss of heat and help keep the higher velocity of the gas. Get the gas out quicker and you have more room to put the new exhaust gas in.
How well it works I can't say but it could well be one of those 'chasing that last 0.1bhp' sort of things. I would only do it if the exhaust was close enough to burn something and I wanted the protection. Shiny exhaust pipes also look good. Grimey shit doesn't.
sickpup
Old Timer
PostPosted: 12:14 - 13 Feb 2012    Post subject: Reply with quote
I suspect that it gives it a higher velocity as it is expanded and has to move faster to evacuate the pipe as more gas is forced in from the engine. In fact as the expanded gas is at a higher volume I suspect it doesn't clear as well as exhaust gas at a lower temperature and volume.
PostPosted: 19:24 - 13 Feb 2012    Post subject: Reply with quote
I did it for larks, it generated huge clouds of steam whenever it was wet (and it's always wet round here) and yes, it rusted the hell out of my pipes. Fine for California, forget it in the UK.
Valentino Mossy
PostPosted: 20:31 - 13 Feb 2012    Post subject: Reply with quote
Thanks for the info guys and gals !, think i'll give it a miss and just get the autosol out instead Thumbs Up
oooh, bubble wrap, anyone bubble wrapped their tank before instead of carbon wrapping or fur ? Thumbs Up Wink
lozzypop1
Certified MILF!
PostPosted: 00:23 - 14 Feb 2012    Post subject: Reply with quote
Thought you did that...
...My bad, those were stomp grips! Laughing
Valentino Mossy
PostPosted: 00:46 - 14 Feb 2012    Post subject: Reply with quote
That was the gsxr.... and they looked more like hot water bottles...lmao !
The last post was made 14 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 83.74 Kb
