Bros 400 tank respray at last!
mysterious_rider
PostPosted: 15:22 - 13 Feb 2012    Post subject: Reply with quote
Looks good. Just done some spraying myself. It requires a real knack to it. Laughing
B10Hazard
PostPosted: 18:56 - 13 Feb 2012    Post subject: Reply with quote
looks shite
No longer any socks
ajbsmirnoff
PostPosted: 19:06 - 13 Feb 2012    Post subject: Reply with quote
Time to learn wet sanding to get a nice shine.
mysterious_rider
PostPosted: 19:44 - 13 Feb 2012    Post subject: Reply with quote
explain please? Very Happy
ajbsmirnoff
PostPosted: 20:00 - 13 Feb 2012    Post subject: Reply with quote
Wet sanding is the process which flattens the orange peel effect of spray paint or clear coat to give (eventually) a high shine. Its also used to remove swirl marks and light scratches.
Essentially a few days after clearcoating (the longer the better) you use coarse -then increasing fine wet/dry sanding paper to even out the rough clear coat surface. Usually followed by some fine polishing compound (or T-cut for cheapos like me). It does require a lot of elbow grease.
Initially it appears to utterly ruin the surface of the paint/clearcoat, and creates a huge mess - but as you get to the T-cut stage it starts to look as good as professionally done painting.
I learned how to do it while painting guitars, but its a very useful technique.
Frost
PostPosted: 20:12 - 13 Feb 2012    Post subject: Reply with quote
So you did: Filler, sand, colour?
Should it not go: Strip, fillter, sand, prime, sand, colour, laquer?
Drake
PostPosted: 20:43 - 13 Feb 2012    Post subject: Reply with quote
missed remove filler cap...
Frost
PostPosted: 20:57 - 13 Feb 2012    Post subject: Reply with quote
I also missed 'remove tank from bike' along with 'drain out fuel so the paint will actually dry' Wink
denarmmm
PostPosted: 21:57 - 13 Feb 2012    Post subject: Reply with quote
Couldn't be botherd to fuck around with it as selling soonish so just wanted to make it look tidier
surely if you were selling it soon it would be more of a reason to do it well Rolling Eyes
HD
PostPosted: 22:52 - 13 Feb 2012    Post subject: Reply with quote
The paint on your filler cap is gonna chip so quickly and your gonna be pissed that you didn't just take it off...
WannaBeDude
PostPosted: 23:08 - 13 Feb 2012    Post subject: Re: Bros 400 tank respray at last! Reply with quote
The dogs face say's it all tbf ..............
https://img818.imageshack.us/img818/1986/img20120213123948.jpg
HD
PostPosted: 23:21 - 13 Feb 2012    Post subject: Re: Bros 400 tank respray at last! Reply with quote
https://i1126.photobucket.com/albums/l618/HDrayton7/dissapoint.jpg
HD
PostPosted: 23:23 - 13 Feb 2012    Post subject: Reply with quote
Shit! Yes I am disappoint* with my spelling too Laughing
Nexus Icon
PostPosted: 00:30 - 14 Feb 2012    Post subject: Reply with quote
It looks like an improvement in the pics but a bit of effort with the wet or dry and it could've been a half decent job. I can still see the filler.
Greetings from Shitsville!
StormCrow
PostPosted: 02:08 - 14 Feb 2012    Post subject: Reply with quote
Pretty sure you can't wetsand petrol resistant lacquer - although I may be wrong... (best to check first)
Nexus Icon
PostPosted: 14:27 - 14 Feb 2012    Post subject: Reply with quote
You can sand the filler down (dry) before you put the paint on though!
nowhere.elysium
The Pork Lord
PostPosted: 16:31 - 14 Feb 2012    Post subject: Reply with quote
Fuxache.
hahadumball - the gift that keeps on giving. Laughing
robs321
PostPosted: 08:35 - 15 Feb 2012    Post subject: Reply with quote
If your attitude is you cant be arsed to spend a bit of time doing a proper job on your tank, then how well is the rest of the bike looked after?
Look what you can achieve with a little bit of effort!
https://i8.photobucket.com/albums/a12/robs321/Image046.jpg
waffles
PostPosted: 11:17 - 15 Feb 2012    Post subject: Reply with quote
Can you open the filler cap or has the drying paint got into it and sealed it shut?
Rncv
PostPosted: 16:20 - 15 Feb 2012    Post subject: Reply with quote
how did you achieve that finish? :O
Current: 01' Bandit 600, 92' Goose 350
Previous: Lots!
mysterious_rider
PostPosted: 16:41 - 15 Feb 2012    Post subject: Reply with quote
Please make a 'how to'! Very Happy
robs321
PostPosted: 18:33 - 15 Feb 2012    Post subject: Reply with quote
The tank had a few dents so lots of prep sanding and then priming, more filling then final prime coat. Wet flat with 1200 paper. Put the colour on in even coats. wet flat with 1200 paper then use a paste like G3 or finesse it with a mop on a polisher or drill. Then put the clear coat over the top and do the same. Just takes time and a bit of effort like doing most things right do!
How a tatty old bros I got my better half ended up!
https://i8.photobucket.com/albums/a12/robs321/fuel.jpg
The last post was made 14 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 127.97 Kb
