| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 13:17 - 13 Feb 2012 Post subject: Not bike related... Merc alternator? |
Anyone know their way around a car layout?
I bought a new yuasa battery for the car in november, and the last few weeks have seen it unable to hold charge. I can charge it, shows full in 2 mins, and will start the car, then overnight all the electricity falls out.
First thought was the alternator, but it still seems to charge the battery? Does it double as a reg/rect or something and potentially fry batteries?
Car in question is my 2001 c180 ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| P. |
 P. Red Rocket
 Posted: 13:24 - 13 Feb 2012 Post subject: |
Forget the alternator at the moment.
Swap the battery on another car for a day and see what happens?
If the other car dies, shit battery.
If your car dies, take a look at the charging system?
Or just charge it and leave overnight.
If battery withers to nothing, its a shit battery.
Completely wild stab in the dark, you aren't doing a paddy special and leaving something on  |
| Ichy |
 Ichy World Chat Champion
 Posted: 13:31 - 13 Feb 2012 Post subject: |
All of the cars I've worked on have had the rectifer built into the alternator.
Do you have a multimeter that you can measure current with? My inlaws Merc used to drain the battery. Turns out there was a short in the radio causing continuous current drain.
As Paddy said you need to rule out the battery first. No need for another car, just disconnect it over night and see if there is any charge left in the morning.
Doesn't make a lot of sense that from appearing dead you can charge it in two minutes. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| P. |
 P. Red Rocket
| MaybeGuy |
 Posted: 19:13 - 13 Feb 2012 Post subject: |
The battery simply won't hold a charge. I can get it to start the car a couple of times before it dies from ''fully charged'' now. I wasn't very specific in the OP, but it's very dead.
The problem is the battery is less than 3 months old, and yuasa (reputable supposedly?).
I can safely say the battery is nackered. However, it must have been caused by something, hence why my first port of call would be reg/rect on a bike, but it would seem the alternator does it all. Correct? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Ichy |
| RIDINGforKICK... |
 RIDINGforKICK... Scooby Slapper
| Taught2BCauti... |
 Posted: 19:47 - 13 Feb 2012 Post subject: |
I would recommend buying a Bosch battery from GSF - they offer a 3 year warranty, plus additional roadside assistance if the battery fails.
Mercs are prone to having things that will go faulty and drain a good battery overnight - like sticking window motors, sticking fuel filler flap solenoids, and a fault in the Comand system that causes the CD motor and cooling fan to run continuously, faulty seat control module, plus many more.
Disconnect the cable from the battery earth terminal and connect a 12volt bulb (or an ammeter) in series between the cable and the battery. If the bulb lights (or ammeter gives a reading) when everything should be off, remove fuses one by one to see which circuit is responsible for the drain.
Here is a good vid on the subject... https://www.youtube.com/watch?v=GtJMHSY7hso |
| MaybeGuy |
 Posted: 20:00 - 13 Feb 2012 Post subject: |
Cheers guize.
Loads for me to be looking into for now. I'll steal a tester from one of the sparkys at work and have a fiddle.
I fucking hate electrics. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| RIDINGforKICK... |
This post is not being displayed because it has a low rating. Unhide this post / all posts.
| MaybeGuy |
 Posted: 20:49 - 13 Feb 2012 Post subject: |
it's currently on a slow charge of around 1amp according to the charger. It cost about £50 at trade price, so I'd hope it's a half decent one.
For some reason this is the only time it hasn't shown as full after a few minutes, and it's been going for a couple of hours :S
Right, so homework for me... test light of some description... whip out the brushes in the alternator to see if they're worn (i've got a feeling it's this... the car's done about 110k and it's more than likely the original alternator). ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| sickpup |
 sickpup Old Timer
| RIDINGforKICK... |
This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
| herulach |
 herulach World Chat Champion
| RIDINGforKICK... |
| RIDINGforKICK... |
This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
| Howling TerrorOutOfOffice |
| RIDINGforKICK... |
| RIDINGforKICK... |
| AndyB1989 |
 AndyB1989 Scooby Slapper
| RIDINGforKICK... |
| The Artist |
 The Artist Super Spammer
| Ichy |
 Posted: 07:10 - 14 Feb 2012 Post subject: |
Just to stir it up a bit.
A battery should be charged at 1/10 of its 10 hour rating so a 100ah battery should be charged at 1amp.
But.
That is not 100% correct.
This is only true for maintenance. For normal charging of a battery discharged to 40-75%, which is the recommended maximum discharge for optimum battery life, you should bulk charge at about 1/5 of its capacity until it reaches about 85% of its charge. For between 85-95% it drops to about 1/10th and then for the last bit aim for about 1/20th.
It's all about the heat. Nobody wants bad thermal cycling do they?
Yeah, your all right! High fives all round! ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| MaybeGuy |
 Posted: 07:24 - 14 Feb 2012 Post subject: |
Get your bitch on. Sparkies... Attaaaacckkk ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| P. |
 P. Red Rocket
 Posted: 09:25 - 14 Feb 2012 Post subject: |
Well AFAIK, if you charge a battery enough to start the car, the alternator will do its usual recharging shit anyway. I have totally flattened the battery on my GSXR, jumped from a car and it recharged it fully.
So surely under Ridingforkicks rule... it should be dead?  |
The last post was made 13 years, 344 days ago. Instead of replying here, would creating a new thread be more useful? |
