Not bike related... Merc alternator?
MaybeGuy
PostPosted: 13:17 - 13 Feb 2012    Post subject: Not bike related... Merc alternator? Reply with quote
Anyone know their way around a car layout?
I bought a new yuasa battery for the car in november, and the last few weeks have seen it unable to hold charge. I can charge it, shows full in 2 mins, and will start the car, then overnight all the electricity falls out.
First thought was the alternator, but it still seems to charge the battery? Does it double as a reg/rect or something and potentially fry batteries?
Car in question is my 2001 c180
P.
PostPosted: 13:24 - 13 Feb 2012    Post subject: Reply with quote
Forget the alternator at the moment.
Swap the battery on another car for a day and see what happens?
If the other car dies, shit battery.
If your car dies, take a look at the charging system?
Or just charge it and leave overnight.
If battery withers to nothing, its a shit battery.
Completely wild stab in the dark, you aren't doing a paddy special and leaving something on Laughing
Ichy
PostPosted: 13:31 - 13 Feb 2012    Post subject: Reply with quote
All of the cars I've worked on have had the rectifer built into the alternator.
Do you have a multimeter that you can measure current with? My inlaws Merc used to drain the battery. Turns out there was a short in the radio causing continuous current drain.
As Paddy said you need to rule out the battery first. No need for another car, just disconnect it over night and see if there is any charge left in the morning.
Doesn't make a lot of sense that from appearing dead you can charge it in two minutes.
P.
PostPosted: 13:49 - 13 Feb 2012    Post subject: Reply with quote
Only stated that as I happen to have a few cars that are sitting there which can be started whenever.
Then again I trust batteries like I trust females... I have a spare battery and jump leads in the boot Laughing
MaybeGuy
PostPosted: 19:13 - 13 Feb 2012    Post subject: Reply with quote
The battery simply won't hold a charge. I can get it to start the car a couple of times before it dies from ''fully charged'' now. I wasn't very specific in the OP, but it's very dead.
The problem is the battery is less than 3 months old, and yuasa (reputable supposedly?).
I can safely say the battery is nackered. However, it must have been caused by something, hence why my first port of call would be reg/rect on a bike, but it would seem the alternator does it all. Correct?
Ichy
PostPosted: 19:18 - 13 Feb 2012    Post subject: Reply with quote
Yep. Didn't realise you could but the regulator seperately.
https://www.youtube.com/watch?v=wNCnJm92lnY
Have you checked the voltage while the car is running?
RIDINGforKICK...
PostPosted: 19:42 - 13 Feb 2012    Post subject: Reply with quote
Start the car
Put your multimeter on volts, you want 14.2 at the battery terminals.
If you get that the Alternator is OK.
On the battery, did you put the acid in yourself?
Did you put the battery on charge for 24 hours when you first got it?
You want 12.8 volts on a stable battery, when it gets to 12.4 volts the battery is flat.
if you get a reading below 12 volts (most likely 10.5 volts) a cell is dead.
Taught2BCauti...
PostPosted: 19:47 - 13 Feb 2012    Post subject: Reply with quote
I would recommend buying a Bosch battery from GSF - they offer a 3 year warranty, plus additional roadside assistance if the battery fails.
Mercs are prone to having things that will go faulty and drain a good battery overnight - like sticking window motors, sticking fuel filler flap solenoids, and a fault in the Comand system that causes the CD motor and cooling fan to run continuously, faulty seat control module, plus many more.
Disconnect the cable from the battery earth terminal and connect a 12volt bulb (or an ammeter) in series between the cable and the battery. If the bulb lights (or ammeter gives a reading) when everything should be off, remove fuses one by one to see which circuit is responsible for the drain.
Here is a good vid on the subject... https://www.youtube.com/watch?v=GtJMHSY7hso
MaybeGuy
PostPosted: 20:00 - 13 Feb 2012    Post subject: Reply with quote
Cheers guize.
Loads for me to be looking into for now. Thumbs Up I'll steal a tester from one of the sparkys at work and have a fiddle.
I fucking hate electrics.
RIDINGforKICK... This post is not being displayed because it has a low rating. Unhide this post / all posts.
MaybeGuy
PostPosted: 20:49 - 13 Feb 2012    Post subject: Reply with quote
it's currently on a slow charge of around 1amp according to the charger. It cost about £50 at trade price, so I'd hope it's a half decent one.
For some reason this is the only time it hasn't shown as full after a few minutes, and it's been going for a couple of hours :S
Right, so homework for me... test light of some description... whip out the brushes in the alternator to see if they're worn (i've got a feeling it's this... the car's done about 110k and it's more than likely the original alternator).
sickpup
Old Timer
PostPosted: 21:15 - 13 Feb 2012    Post subject: Reply with quote
RIDINGforKICKS wrote:
You know that to properly charge a battery, you should use around .5 to 1 amp, for between 12 and 24 hours don't you.
Well you normally charge a lead acid at 10% for 10-12 hours so I'm a bit confused. If you charged a 50 amp car battery at 0.5 amps it would take 100+hours to charge, at 1 amp 50+ hours to charge. Are you sure about what you are suggesting?
Matt
Make sure your charger can kick out enough amps to fully charge your battery.
RIDINGforKICK... This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
herulach
PostPosted: 22:07 - 13 Feb 2012    Post subject: Reply with quote
Well I've just spent 10 minutes thinking about the sheer wrongness of this comment, but I finally gave up.
Without getting a voltmeter of some sort on the car charger - battery, there is no way of knowing what's what.
You suggested charging a car battery (eurocarparts list an e190 2l as needing a 62Ah battery (minimum, better ones run to 90).
How exactly are you suggesting that that will become anything like fully charged at 1A in 24hrs?
Being simple about it (& assuming c. 14 v charging)
14* 1*24=336W
Nominal discharge capacity (at 12.3ishV)
12*1*62=764.6W.
Unless theres some magic going on your 1A for 24hours (being generous - it actually reads as though you were suggesting 1A for 12 hours) is putting something like 50% charge into the battery at best.
Also, charging at such a low current means your charger won't detect the cutoff properly and boil the battery
YBR 125>FZS600
RIDINGforKICK... This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
PostPosted: 23:13 - 13 Feb 2012    Post subject: Reply with quote
OT
I remember when CHR15 called me a sausage...Still receiving counselling for it. Crying or Very sad
RIDINGforKICK...
PostPosted: 23:16 - 13 Feb 2012    Post subject: Reply with quote
do you even know what AH stands for?
Do you?
Anyway He's sussed it, the battery charger was bouncing off the surface charge.
RIDINGforKICK...
PostPosted: 23:26 - 13 Feb 2012    Post subject: Reply with quote
This is what the OP posted, I suggested that the problem was the battery charger. This appears to be a correct diagnosis.
So why did we need all the nastiness?
AndyB1989
PostPosted: 23:36 - 13 Feb 2012    Post subject: Reply with quote
pulse chargers ftw actively fix fucked batteries !
RIDINGforKICK...
PostPosted: 23:52 - 13 Feb 2012    Post subject: Reply with quote
try and charge a 200AH wagon battery at 1amp for 24 hours and see how far it gets you.
If Matt were charging a truck battery I would have advised him differently.
I have fitted hundreds of battery's to trucks, earth movers, to cranes the size of a row of houses, and I can assure you that ALL the manufacturers of battery's advise a slow trickle charge then the battery is new, and when a battery has become fully discharged.
I can't be bothered educating you, when you grow up you will no doubt feel embarrassed about your rude behaviour.
I blame the parents myself.
The Artist
PostPosted: 23:54 - 13 Feb 2012    Post subject: Reply with quote
Ichy
PostPosted: 07:10 - 14 Feb 2012    Post subject: Reply with quote
Just to stir it up a bit.
A battery should be charged at 1/10 of its 10 hour rating so a 100ah battery should be charged at 1amp.
But.
That is not 100% correct.
This is only true for maintenance. For normal charging of a battery discharged to 40-75%, which is the recommended maximum discharge for optimum battery life, you should bulk charge at about 1/5 of its capacity until it reaches about 85% of its charge. For between 85-95% it drops to about 1/10th and then for the last bit aim for about 1/20th.
It's all about the heat. Nobody wants bad thermal cycling do they?
Yeah, your all right! Very Happy High fives all round!
MaybeGuy
PostPosted: 07:24 - 14 Feb 2012    Post subject: Reply with quote
Get your bitch on. Sparkies... Attaaaacckkk
P.
PostPosted: 09:25 - 14 Feb 2012    Post subject: Reply with quote
Well AFAIK, if you charge a battery enough to start the car, the alternator will do its usual recharging shit anyway. I have totally flattened the battery on my GSXR, jumped from a car and it recharged it fully.
So surely under Ridingforkicks rule... it should be dead? Laughing
The last post was made 13 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 133.63 Kb
