| MG#43 |
 MG#43 Nova Slayer
 Posted: 14:54 - 12 Feb 2012 Post subject: Rust in tank! |
Hi,
I've tried a search for this and haven't found anything yet. Anyone got any tips for rust in fuel tanks? It's not too bad, just the bag a bolts i chucked in and swirled around in brake cleaner hasn't done the trick. I'm going to try some Oxalic acid solution and leave in the tank for a while... Anyone tried this?
thanks!  |
| MickC |
 MickC Spanner Monkey
 Posted: 18:07 - 12 Feb 2012 Post subject: |
Here's a link to an older thread discussing your problem.
https://www.bikechatforums.com/viewtopic.php?t=214555&highlight=rusty+tank
Hope it helps ____________________ XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
| MG#43 |
 MG#43 Nova Slayer
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
 Posted: 19:29 - 12 Feb 2012 Post subject: |
| MickC |
 Posted: 19:34 - 12 Feb 2012 Post subject: |
| MG#43 wrote: |
Not seeing any links there chap - unless i'm being a bit thick of course!!  |
Fixed it ____________________ XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1 |
| bikenut |
 bikenut World Chat Champion
 Posted: 15:14 - 13 Feb 2012 Post subject: rust |
( sorry admin ) hi dude,
water getting in somehow, past rubber seal.........
when tank flushed ( and plumming, tap etc, then carb ) try to see if the small vw type petrol filter will fit tween tank and carb, these will stop all crap ( even water ) from getting to the carb.
have fitted these to bikes for years now, they work with no problems for gravity feed systems but didnt on my kwak750, which had vaccum tap ( it did work on prime position though ). |
| bikenut |
 Posted: 15:16 - 13 Feb 2012 Post subject: oxalic acid |
oxalic acid, brilliant for rust but not tried with petrol? do test first, its nasty stuff so be carefull. |
The last post was made 14 years, 13 days ago. Instead of replying here, would creating a new thread be more useful? |
