Pinlock - what the hell I'm I doing wrong
Cleveland
PostPosted: 22:20 - 16 Feb 2012    Post subject: Pinlock - what the hell I'm I doing wrong Reply with quote
Evening'
I ve got a new Hjc lid which comes with a pinlock but for the life of me I can't get the bloody pinlock to fit to any of the visors!! What the hell am I doing wrong!!
From what I can work out the pinlock is to big but it's the right one Hj-20 pinlock and Hj 20 lens.
Ta
C
Quote Me Happy
PostPosted: 22:25 - 16 Feb 2012    Post subject: Reply with quote
You can turn the pins with a screwdriver to adjust the distance between them - they're an eccentric cam type thing.
Give them a turn and see if you can make it fit.
jimspeed
PostPosted: 22:27 - 16 Feb 2012    Post subject: Reply with quote
are you removing the visor and flattening it down to fit the pinlock?
it should be a tightish fit even with the visor flat and some times the pinlock pins are made with offset slots in so you can turn them to make it a tighter fit.
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
whitedevil
PostPosted: 23:41 - 16 Feb 2012    Post subject: Reply with quote
https://www.youtube.com/watch?v=bNZndb1uTAc
Ta-Daaaaaaaaa!!!
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
MaDMaX68
PostPosted: 07:26 - 17 Feb 2012    Post subject: Reply with quote
as above Thumbs Up
unfortunately its another one of those great inventions where you need an IQ of 300!!! or in this case to be an octopus to hold down the visor and fit the insert ( or even better a decent set of instructions)
also once done its worth while just running around the pinlock seal with a clean soft cloth to make sure its sealed against the visor,
else if it rains etc it all still goes misty n yet inside,as mine did on the 1st attempt and as much use as a chocolate fire-guard Mr. Green
iMark
PostPosted: 07:38 - 17 Feb 2012    Post subject: Reply with quote
Hmm, Mines is fine in the rain.
The only thing I notice is when I took the breath guard out of my helmet (Just got in the way and I didn't like it) I get a build up of condensation blow the pinlock, but not behind/inside it
K8 GSXR 1000
MaDMaX68
PostPosted: 07:45 - 17 Feb 2012    Post subject: Reply with quote
oooh snap Thumbs Up that was the exact thing happening when i rode my newly aquired bike home last week from shrewbury!! tbh it dint really bother me as i was more concerned for the nuclear winter blst i was facing riding home Crying or Very sad
but did notice once i had got home the condensayion had gone, was it a shoei you got, damm breath guard just irritated me, lol
p.s meant to mention the rain thing may also have been my inability to fit in correctly the 1st time Embarassed
iMark
PostPosted: 07:51 - 17 Feb 2012    Post subject: Reply with quote
Nah its just a Box FZ-1 »Click«
and yeh if you dont get it right the silicone bead doesn't put pressure on the inside and doesnt seal right Razz
K8 GSXR 1000
Cleveland
PostPosted: 08:32 - 17 Feb 2012    Post subject: Reply with quote
Thanks guys but I've tried all those. The pins don't seem to be offset, I've laid it flat still no luck. Even when I lay the pinlock flat in the visor you can actually see that it's too big' I can easily get the pinlock into the pins but since it's too big it bends outwards rather than against the visor. My only thought is that it's faulty.
iMark
PostPosted: 08:39 - 17 Feb 2012    Post subject: Reply with quote
Does it just pop back towards you even when you push it in as your letting the visor flex back into its natural position ?
Make sure the silicone beading around the edge of the pinlock is facing the visor, not in towards the helmet.
Make sure both pins are orientated so the slit in them is facing towards the middle of your visor, Bend your visor on the floor (Dont need to use too much pressure) and hold it with your knee, insert one side of the Pinlock and make sure its in secure, then bend it towards you in the middle and insert the other side, you should then press the pinlock against the visor and let the visor flex back out, it should want to stay pinned against the visor
K8 GSXR 1000
Cleveland
PostPosted: 20:35 - 17 Feb 2012    Post subject: Reply with quote
Imark - the pinlock just comes away from the visor all the time.
pits
PostPosted: 02:50 - 18 Feb 2012    Post subject: Reply with quote
Which is why you buy the Fog City Hyper Shield thing
https://www.google.co.uk/search?client=opera&rls=en&q=Fog%20City%20Hyper%20Shield&oe=utf-8&channel=suggest&um=1&ie=UTF-8&hl=en&tbo=u&tbm=shop&source=og&sa=N&tab=wf&ei=KwM_T5HrFIPa8QOKysSOCA
My Caberg has one, you peel the backing off, you fold it into a U shape, you stick onto visor, seal the edge of it down with your finger, job jobbed, hasn't misted up on me once in 2 years, it seems less hassle than the pinlock fitting as well, not sure what range they cover lid wise, but I think it is awesome.
Thumbs Up Thumbs Up Thumbs Up
Walloper
PostPosted: 05:51 - 18 Feb 2012    Post subject: Reply with quote
The silicone seal bead has to be tight on the visor or it will not work. It can easily be fitted this way:
Remove visor from hat.
1 Hold one side of the visor with left paw.
2 Push the side of the visor down and by using the elbow end of left arm to prevent the visor lifting up at t' other end. Spread it open flat-ish.
They are quite tuff so need a bit of oomf to open.
3 Clip one end of the insert into one of the pins.
4 Bend the insert to make a sort of S shape and tuck the other end into the other pin.
5 Allow the insert to resume it's normal shape flatted against the visor and 'importantly' align the insert for best fit in the visor before you remove the elbow-hand clamp.
6 Release your vice like grip on the visor and Vwah-Lahh you have fitted a pin-lock.
7 Check the bead has good contact around the pin-lock and stick the visor into the hat.
magpiemale
PostPosted: 10:14 - 19 Feb 2012    Post subject: Reply with quote
Btw try to only touch the sides of the pinlock or else you will see finger marks on the visor,just to make it more difficult.pinlocks tend to be a bit bigger than the visor so that is is tight,but anything over 5mm then the pinlock may be not the right fit.double check your helmet and visor against the pinlock on the pinlock website,racevisor website or hjc.
NSR125 1992 (sold) kawasaki Z750S,fazer FZ1 07 now gone present bike 2012 fz1s Fazer,beowulf rad protector,heated grips,sw motech gps holder,power socket.
magpiemale
PostPosted: 11:00 - 19 Feb 2012    Post subject: check this out Reply with quote
https://www.pinlockshop.co.uk/category-pl/hjc-helmet-pinlock-inserts
Check your visor and helmet code here.
The last post was made 14 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 86.57 Kb
