Run a 32-bit game on a 64-bit Win7 Home
Dilyan
PostPosted: 16:42 - 17 Feb 2012    Post subject: Run a 32-bit game on a 64-bit Win7 Home Reply with quote
Just wasted £16 on a game I used to love playing back in the day. However on my current rig things wouldn't start.
https://s14.postimage.org/uhe5kztan/F22.png
Tried the Properties/Compatibility/Run this program in compatibility mode for (tried all the options there), still get the same thing.
https://s10.postimage.org/kxridzxnb/F22_1.png
Any software I can use to sort this out?
Current: 2007 VFR800; Ex: 2001 YZF600R Thundercat
Škoda Octavia (yes, a taxi driver)
Alpha-9
PostPosted: 16:45 - 17 Feb 2012    Post subject: Reply with quote
What's the game?
I might be able to help, plenty of experience doing that shit.
Why wont it work? - Errors, jsut not running etc.
I upgraded my GPU and found i couldnt play UFO aftershock anymore due to pixel shaders Sad
If all else fails you can try a virtual box
Fzr-600 1999
Phil.
PostPosted: 16:47 - 17 Feb 2012    Post subject: Reply with quote
Your Images;
https://s14.postimage.org/trvd8msr3/F22.png
https://s10.postimage.org/ek2faqsrb/F22_1.png
Dilyan
PostPosted: 16:54 - 17 Feb 2012    Post subject: Reply with quote
How about now:
https://i1230.photobucket.com/albums/ee494/didodimov/F22.png
https://i1230.photobucket.com/albums/ee494/didodimov/F221.png
Game is F-22 Air Dominance Fighter.
Alpha-9
PostPosted: 16:56 - 17 Feb 2012    Post subject: Reply with quote
Oh, didnt see those screenies.
You're doing the compatability wrong. You set it to run in the compatability of what it works in, eg. if youre on win7 and the game doesnt support win7 and is an XP game, run it in compatability for windows XP, not windows 7 (Jah get me dawg?)
It's a 16bit app so its pre windows xp it seems?
What's the game?
Also right click run as admin, fixes some problems, looks to me like thats the setup.exe not the actual game. You should still be able to install it regardless of 32/64bit unless it has some weird override which disables installing on 64bit....
But that screenie of it being like /??/setup.exe
looks like its wildly confused....did you actually buy this game or is it weirdly mounted? o.O
If its that old its actually 16bit then you'd be better off in DOSBOX Mr. Green Thumbs Up
Fzr-600 1999
Dilyan
PostPosted: 17:11 - 17 Feb 2012    Post subject: Reply with quote
Tried them all, not just XP. All from the drop down menu. Result is always the same.
When I got it I played it in Windows 95, Pentium 1, 16mb RAM.
What's the game?
not this one Sad
It is Smile
Bought original copy. As posted (16 quid!)
Don't think it has anything to do with DOS. It's loong after the Vikings Wink
PostPosted: 17:19 - 17 Feb 2012    Post subject: Reply with quote
Find program called dosbox.
Alpha-9
PostPosted: 17:28 - 17 Feb 2012    Post subject: Reply with quote
[quote="Dilyan"]
*ahem*
It's a very old 16bit game, so yeah it wouldnt run on windows without emulation. Get DosBox, it's confusing so you'll be back here asking how it works in no time Thumbs Up
Also you've paid £16 for a game that's probably abandonware by now....
Quick google says nope. Not abandonware, people must still like it Thumbs Up
I'm going home from work now, maybe check out https://forums.guru3d.com/showthread.php?t=320322
Fzr-600 1999
CaNsA
PostPosted: 17:39 - 17 Feb 2012    Post subject: Reply with quote
Try this
https://taw.wikia.com/wiki/Installing_and_Running_ADF/TAW_on_a_Modern_System
Dilyan
PostPosted: 18:03 - 17 Feb 2012    Post subject: Reply with quote
CaNsA wrote:
Yeah, that's what I did. Somehow managed to run my old Vista laptop, installed the game on a USB and it's running now.
Just annoys me that a better OS wouldn't run an old OS's game.
CaNsA
PostPosted: 18:10 - 17 Feb 2012    Post subject: Reply with quote
Dilyan wrote:
Just annoys me that a OS based on different technology wouldn't run an old OS's game.
EFA Wink
Colin Edwards
PostPosted: 18:53 - 17 Feb 2012    Post subject: Reply with quote
XP mode..
CE
Dilyan
PostPosted: 19:01 - 17 Feb 2012    Post subject: Reply with quote
Colin Edwards wrote:
XP mode..
CE
CE??
Game is currently crashing non stop. So, to put an end to my suffering I've decided to bring my old laptop to life with a fresh XP copy. Problem solved.
Have a load of other pre-historic games I'd love to have a go at again so it will save me a lot of trouble.
CaNsA
PostPosted: 19:07 - 17 Feb 2012    Post subject: Reply with quote
Dilyan wrote:
CE??
No-one tell him
LOL
Alpha-9
PostPosted: 19:20 - 17 Feb 2012    Post subject: Reply with quote
XP mode..
CE
CE??
I kept a separate 32 bit windows7 on another partition for that reason Thumbs Up
Fzr-600 1999
Colin Edwards
PostPosted: 19:43 - 17 Feb 2012    Post subject: Reply with quote
CE for Colin Edwards...
Pleased you got it sorted
el_oso
PostPosted: 19:56 - 17 Feb 2012    Post subject: Reply with quote
instead of using a separate system, why not use VM?
https://www.virtualbox.org/
Duke 390
Car: Jeep Wrangler 4.0L
Colin Edwards
PostPosted: 20:07 - 17 Feb 2012    Post subject: Reply with quote
Like XP mode that downloads as a W7 add on https://www.microsoft.com/windows/virtual-pc/download.aspx
Runs an XP in virtual PC mode....
CE
Stevie GooGs
PostPosted: 20:17 - 17 Feb 2012    Post subject: Reply with quote
TAW kicked ass if they updated the skins it would rock again, loved that game.
Dilyan
PostPosted: 23:36 - 17 Feb 2012    Post subject: Reply with quote
https://images.sodahead.com/profiles/0/0/2/2/6/8/2/8/9/triple-face-palm-43542681040.jpeg
The View Askew
PostPosted: 04:50 - 26 Feb 2012    Post subject: Reply with quote
32 bit app with 16 bit installer? 64 bit can't run 16 bit code, if it's popular someone is bound to have written a 32/64 bit installer for it.
Normally only the installers are 16 bit, app will probably run fine under compatibility once installed.
ninja_butler
PostPosted: 11:48 - 26 Feb 2012    Post subject: Reply with quote
I've successfully used Windows Virtual PC 2007 in the past; it isn't supposed to work on Windows 7 but it usually does. The only annoyance is that you've got to install the games as OEM's unless you can figure out how to run them from the DVD/CD drive, which is more complicated than it sounds.
Some old games just will not run on Windows 7 at all but most games made for Windows XP can be made to run with some tweaking.
ThoughtContro...
PostPosted: 17:18 - 26 Feb 2012    Post subject: Reply with quote
F22 ADF was around when Win 95 OSR2 was all the rage, it's hardly made for XP.
Prize cunt
The last post was made 14 years, 199 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 123.27 Kb
