spark plug problem
dannie_10
PostPosted: 23:16 - 22 Sep 2004    Post subject: spark plug problem Reply with quote
hi wonder if someone could help .... have recently bought bike .... only had a month and in this time twice now I can't get it started ....it coughs and splutters but does eventually start ...... seems to be that the spark plug has worked itself loose...could anyone tell me if this is a common problem with an older (1993) nsr125... .maybe with the vibration? please use laymans terms as i haven't got a scooby doo about bikes Wink .... hope to pass advice on to boyfriend or brother ..... all help appreciated
Scooby
Scrappy Doo
PostPosted: 23:20 - 22 Sep 2004    Post subject: Reply with quote
Doubt it's 'worked loose'. More likely not been nipped down properly in the first place. Have a look at the plug, if you doubt it's in good condition get a new one for what they cost, tighten it down as much as you can hand tight, then just nip it down a tad with a plug spanner.
dannie_10
PostPosted: 23:22 - 22 Sep 2004    Post subject: Reply with quote
thanks ...will pass advice on to my mechanics *laughs*
PostPosted: 01:12 - 23 Sep 2004    Post subject: Reply with quote
Sparkplugs have a compression washer on them (a kind of squashed down metal tube in effect) which squidges down when you tighten the plug, if the plug has been in and out a few times, this washer can become permanently squashed down which tends to make the plug prone to coming loose.
When tightening up a plug, be carefull not to overtighten it as the metal it is screwing into is pretty soft, stripped threads here are a major pain in the arse! As a general rule, you screw it in 'till it is finger tight then give it 1/4 of a turn using the plug spanner (more accurate than using a torque wrench that, angular wassizname tightening)
PostPosted: 13:07 - 23 Sep 2004    Post subject: Reply with quote
Worth mentioning that it is best to not tighten the spark plugs up in a hot engine as that would make it easy to overtighten / undertighten the spark plug.
Spark plugs working loose is not that uncommon on some 2 strokes, so just keep an eye on it.
freestyler_onli
PostPosted: 17:16 - 30 Dec 2004    Post subject: Reply with quote
My bike wont start full stop. Some old bloke reckons it might be the sparkplugs. Is he right?
Ie- how can i tell if they're the cause of the problem.
PostPosted: 17:44 - 30 Dec 2004    Post subject: Reply with quote
Quite possibly the spark plugs. Cannot really say without more details, but plugs are a common problem and are cheap and easy to replace.
freestyler_onli
PostPosted: 10:56 - 31 Dec 2004    Post subject: Reply with quote
I hope so. I just cant figure out why it wont start.
The last post was made 21 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 56.54 Kb
