| dannie_10 |
 dannie_10 Two Stroke Sniffer
 Posted: 23:16 - 22 Sep 2004 Post subject: spark plug problem |
hi wonder if someone could help .... have recently bought bike .... only had a month and in this time twice now I can't get it started ....it coughs and splutters but does eventually start ...... seems to be that the spark plug has worked itself loose...could anyone tell me if this is a common problem with an older (1993) nsr125... .maybe with the vibration? please use laymans terms as i haven't got a scooby doo about bikes .... hope to pass advice on to boyfriend or brother ..... all help appreciated |
| Scooby |
 Scooby Scrappy Doo
| dannie_10 |
 Posted: 01:12 - 23 Sep 2004 Post subject: |
Sparkplugs have a compression washer on them (a kind of squashed down metal tube in effect) which squidges down when you tighten the plug, if the plug has been in and out a few times, this washer can become permanently squashed down which tends to make the plug prone to coming loose.
When tightening up a plug, be carefull not to overtighten it as the metal it is screwing into is pretty soft, stripped threads here are a major pain in the arse! As a general rule, you screw it in 'till it is finger tight then give it 1/4 of a turn using the plug spanner (more accurate than using a torque wrench that, angular wassizname tightening) ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| freestyler_onli |
 freestyler_onli World Chat Champion
| freestyler_onli |
The last post was made 21 years, 322 days ago. Instead of replying here, would creating a new thread be more useful? |
