The Sound of Engine Revs
KingKong
PostPosted: 11:48 - 25 Feb 2012    Post subject: The Sound of Engine Revs Reply with quote
A bit of a strange post, but please bear with me.
I have noticed that sports bikes make various different sounds when they are revved. Was riding with another 600 last night and as we departed each other's company for our separate turn offs, the chap on the R6 revved his engine as a farewell bid.
Well, here's what it sounds like - go to 2m 53s, please:
https://www.youtube.com/watch?v=TTf-rNte5Eo
How does one make their revs sound like that, does it have something to do with some sort of customised component?
Kwak 636 (2005)
Past - 2016 Ninja 300 (dark grey); K4 GSXR 600 (sexy yellow); 2002 CBR600FS; 2004 GSXR 1000; 2006 Kwak 636; 2005 Yamaha XVS 1100 Dragstar (facepalm); 2005 Kwak 636; 2011 Yamaha R125.
nowhere.elysium
The Pork Lord
PostPosted: 11:56 - 25 Feb 2012    Post subject: Reply with quote
What, bouncing it off the limiter? Laughing
KingKong
PostPosted: 11:58 - 25 Feb 2012    Post subject: Reply with quote
eh? Confused
Kwak 636 (2005)
lihp
PostPosted: 11:59 - 25 Feb 2012    Post subject: Reply with quote
Engine noise comes down to only a few parameters.
Engine capacity, engine configuration, and system. Largely though the system only really affects the volume of the engine, configuration and size are responsible for the tone.
lihp
KingKong
PostPosted: 12:02 - 25 Feb 2012    Post subject: Reply with quote
Thank you; so which type of configuration would render such a sound?
Kwak 636 (2005)
lihp
PostPosted: 12:20 - 25 Feb 2012    Post subject: Reply with quote
R6 is an inline 4 so take your guess Wink
plugger147
PostPosted: 12:38 - 25 Feb 2012    Post subject: Reply with quote
It's being rev'd up to hit the limiter like so...
https://m.youtube.com/index?desktop_uri=%2F&gl=US#/watch?v=rRcs856CT_w
Nothing special added, it's like a safety device to stop you over reving...
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
KingKong
PostPosted: 12:51 - 25 Feb 2012    Post subject: Reply with quote
Link took me to an unrecognised playlist.
Aha... a limiter, now I understand Smile Are there any detriments to having a rev limiter in place?
Kwak 636 (2005)
Walloper
PostPosted: 13:20 - 25 Feb 2012    Post subject: Reply with quote
Most of wot you hear is from the exhaust.
Fit a different muffler and you get a vastly different sound.
Engine gas flow has an effect.
Engine timing has an effect but Exhaust Note FTW.
plugger147
PostPosted: 13:46 - 25 Feb 2012    Post subject: Reply with quote
Sorry, that was a mobile link try this one...
https://www.youtube.com/watch?v=rRcs856CT_w
Paulington
PostPosted: 13:53 - 25 Feb 2012    Post subject: Reply with quote
As has been said it's just bouncing off the limiter. All this means is that when it hits the rev limiter (around the redline) the ignition gets cut/fuel stops or anything like that momentarily to stop the engine revving over that pre-determined number.
A limiter is there just for the safety of the engine as the manufacturer has decided that revving over that number could heavily damage the engine. Almost all modern bikes have a rev limiter, same with cars.
No detriment to having one. To make that noise on a bike with a rev limiter just hold the clutch in and pin the throttle back. It will rev, hit the limiter and just keep 'bouncing' off of it until you let the throttle go.
Cheers!
KingKong
PostPosted: 12:33 - 26 Feb 2012    Post subject: Reply with quote
Aha Surprised That makes a lot of sense now Smile
Thank you very much for clarifying that for me Paulington; Plugger 147; and nowhere.elysium
Kwak 636 (2005)
Jim Mc
PostPosted: 13:58 - 26 Feb 2012    Post subject: Reply with quote
Reving to 15k without any load can't be healthy for the engine.
weasley
PostPosted: 17:06 - 26 Feb 2012    Post subject: Reply with quote
It isn't. The pistons are moving at maximum speed but they aren't being 'pushed' back down by very much pressure (since there's no load and therefore not much fuel being used). Hence the top dead centre turnaround is quite hard on the con rod bearings.
Walloper
PostPosted: 17:48 - 26 Feb 2012    Post subject: Reply with quote
Kack.
If the engine is designed to last at the max continuous RPM it will not harm the engine.
MAX RPM has more to do with inertial/centrifugal forces than load.
An engine at full chat will probably be under more strain than an engine at a no-load max RPM.
But sustained MAX RPM will not be very healthy for any engine under any loading.
sickpup
Old Timer
PostPosted: 22:42 - 26 Feb 2012    Post subject: Reply with quote
So all those Diesel engines that suffer damage from the MOT rev test every year are designed like that. Thanks for clearing that up for me Thumbs Up Wink
lihp
PostPosted: 23:43 - 26 Feb 2012    Post subject: Reply with quote
An engine with no load on it, can rev beyond the limit due to the momentum and lack of load, the engine revs will drop down again, but it will over rev.
Walloper
PostPosted: 05:34 - 27 Feb 2012    Post subject: Reply with quote
I don't think that is the issue and I do not have any relevant info on it but I will investigate toot-sweet.
Engines should be governed to limit max RPM.
lihp
PostPosted: 08:28 - 27 Feb 2012    Post subject: Reply with quote
Engines are not designed to be revved with no load though.
The revs pick up far far faster without a load, and the resolution often not quick enough to "catch" the revs before they over shoot the limiter.
It's common for cars to have 2 limiters, for in gear and not in gear, however, I'd be suprised if this has shifted over to bikes yet, and even then, it would only be on the newest of the models.
Walloper
PostPosted: 12:49 - 27 Feb 2012    Post subject: Reply with quote
Which manufacturer fits two governors to their engines?
Previously Diesel engines were mechanically governed via linkages now a days most modern Diesels are governed electronically and there is no issue of an engine running past it's designed max RPM without load.
That is called an Overspeed.
Engines overspeed if the fuel system malfunctions or the engine is driven by the load it is carrying.
i.e. A vehicle put into a low gear at high road speed will drive the engine over it's rated Max RPM. Electrical supply can back feed to a generator and drive the engine.
MOT engine smoke tests is done at max RPM but some old cars lose drive belts. Probably the drive belt was near end of service life anyway.
I can't find any reliable information for newer vehicles failing during that test.
Dracon
PostPosted: 22:13 - 27 Feb 2012    Post subject: Reply with quote
Honda do.
You can't rev the Type R more than 6k when it's not in gear. In gear, and it'll rev through to 9k.
L4Isoside
PostPosted: 22:23 - 27 Feb 2012    Post subject: Reply with quote
Dracon wrote:
Honda do.
Same for my old Mk2 Seat leon!
Walloper
PostPosted: 08:53 - 28 Feb 2012    Post subject: Reply with quote
So what damaging forces at max No Load Speed are at work when the same speed is OK at Full Load?
I think there is a confusion in physics at large in this thread.
Engine RPM is limited by the various moving masses in the engine (and, to a degree, the amount/mixture/type of fuel burned during combustion.)
The masses are moving with MORE stored energy under load than at no load.
1000s of psi combustion gas pressure pushing against the load.
I do not see any reason for a manufacturer to fit limiters (Which I would call them as opposed to governors which not only control max speed but max power too. Vastly different things) for no load speeds unless only to meet emission tests where an idle mixture may produce more NOX etc. Or something more scientific.
Where the hell are the bcf chemists and fizzicysts when needed. Same as the police and taxes I guess.
Rolling Eyes
weasley
PostPosted: 09:26 - 28 Feb 2012    Post subject: Reply with quote
I have a degree in Chemistry and have worked in the field of engine oil product development and testing for 20 years. Does that count?
The last post was made 13 years, 178 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.85 - MySQL Queries: 13 - Page Size: 130.48 Kb
