NSR Front Panel/Light removal....
NSR125-Kid-UK
Attention Whore
PostPosted: 22:47 - 23 Sep 2004    Post subject: NSR Front Panel/Light removal.... Reply with quote
Yep, following on from my thread about removing the NSR fuel tank (thanks lads who answered Thumbs Up), I'm wondering, how on earth do I remove the fairing panels from around the headlight assembly. The diagram (borrowed from Kr0n's site and coloured in because I was bored) shows the panels I mean. I'm currently worried about the two side panels and the one between the headlights.
Any ideas how I get them off and back on again please?
All help appreciated hugely Smile.
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
swampy
PostPosted: 00:39 - 24 Sep 2004    Post subject: Reply with quote
Okey dokey... These fairings should be attached as one unit. First remove your side fairings (or the upper two fairing screws on each side). Then unbolt your mirrors, and then unbolt where the farings meet the fairing hangers on the frame. The 'unit' should then come off with the headlight attached (remember to unplug the headlight loom from the main loom using the multiplug that can be found on the right side of the subframe thingy). Then unscrew the headlight, and then (if you want) you should be able to unscrew the individual panels from each other... Umm is quite hard to explain, but basically just unbolt it all Wink Thumbs Up Hope this helps, give us a shout if you have any difficulty...
alains
PostPosted: 01:00 - 24 Sep 2004    Post subject: handlebar head fairing Reply with quote
it's not necessary to take the side low parts . take off mirors , then the 3 upper bolts on each side , then pull slowly the whole bit and when you've got enough room to pass your hands , unbolt the speedometer cable , and finally undo all connectors attached with it . tools : big screwdriver , 8 spanner , universal pliers . mind the connectors , if my remains are good they have a lock system
swampy
PostPosted: 01:07 - 24 Sep 2004    Post subject: Re: handlebar head fairing Reply with quote
[quote="alains"]it's not necessary to take the side low parts ./quote]
agreed mate, but you still need to undo the screws that attach the lower fairings to the upper fairings.
NSR125-Kid-UK
Attention Whore
PostPosted: 02:17 - 24 Sep 2004    Post subject: Reply with quote
Cheers dudes Smile. Basically what i'm doing is because *blablablabla* i'm removing all my fairing panels and replacing them. Smile.
swampy
PostPosted: 09:18 - 24 Sep 2004    Post subject: Reply with quote
Good luck fella, hope you have deep pockets Laughing Thumbs Up
The last post was made 21 years, 362 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.75 - MySQL Queries: 13 - Page Size: 50.09 Kb
