Welding cast Iron
Will it hold?
Yes, indefinately
14%
 14%  [ 1 ]
Yes for a bit
28%
 28%  [ 2 ]
Fall off when up to temp
57%
 57%  [ 4 ]
Total Votes : 7
Fairies attack This post is not being displayed because the poster is banned. Unhide this post / all posts.
Quote Me Happy
PostPosted: 18:29 - 29 Feb 2012    Post subject: Reply with quote
4 thou, throat punch, tranny, Denmark etc.
Walloper
PostPosted: 18:37 - 29 Feb 2012    Post subject: Reply with quote
Why do you have a lamp shining in there?
Could you not see when you flipped the mask down??
You never said wot electrode you used so you fail like fcuk.
Ariel Badger
PostPosted: 19:12 - 29 Feb 2012    Post subject: Reply with quote
Doubt you will have any joy overhead with CI as the weld metal drips rather than sprays from the electrode.
tatters
Exxon Valdez
PostPosted: 19:18 - 29 Feb 2012    Post subject: Reply with quote
Dont you have to heat the cast iron up before you weld it? to stop it cracking?
Walloper
PostPosted: 19:21 - 29 Feb 2012    Post subject: Reply with quote
It was right at the back of the fire box, at the top so quite hard to use.
Ok then,
The rods used were just normal 6013Vodex, why would I need to use a different rod like Nickel?
You need specific cast rods for Cast Iron/Steel. Dissimilar rods can be used at a push but expect poor life.
And you need to preheat and protect from chilling. Prep the joint properly to prevent inclusions and or propagation.
The thermal loading on a hearth/grill/flue etc. requires integrity in the material of it will clack again and again.
mr jamez
PostPosted: 19:32 - 29 Feb 2012    Post subject: Reply with quote
Thrilling.
Walloper
PostPosted: 19:39 - 29 Feb 2012    Post subject: Reply with quote
If you reread my reply to yours, you will see I put the rod type in my answer on the sly.
I do know how to weld, and what rods to use.
So WTF are you posting for?
I know how to weld too, and burn and grind and mill and turn and fit and fart and stuff but I don't fire up a random poll about it.
You asked if you should have used nickel.
Were you being funny then?
Ariel Badger
PostPosted: 19:47 - 29 Feb 2012    Post subject: Reply with quote
You used 6013 Vodex, they are a general MS electrode absolutly of no use with CI, It will have cracked by now.
You need a specific CI electrode (high nickel content) pre-heat and slow cool in an oven.
Kwaks
I'm not a fast rider
PostPosted: 19:49 - 29 Feb 2012    Post subject: Reply with quote
more lies, pic certainly not welding one handed, and not there alone as someone took the pic. Rolling Eyes
www.cliqueycuntsmcc.co.uk
angryjonny
PostPosted: 20:01 - 29 Feb 2012    Post subject: Reply with quote
Just as a bit of amusement.
How's that working out for you?
yen_powell
PostPosted: 20:04 - 29 Feb 2012    Post subject: Re: Welding cast Iron Reply with quote
You've not really got the hang of using that microwave have you......
XT1200Z and a DR350 in bits
MattJ
PostPosted: 20:10 - 29 Feb 2012    Post subject: Reply with quote
Had a boring day on the farm all alone and sheep weren't there
That's because it's a funny farm.
Fisty
PostPosted: 20:11 - 29 Feb 2012    Post subject: Reply with quote
To test it what you should do is lighe a blazing fire, let it burn for an hour or so. add more wood then stick your head up to check the weld.
Fatter and faster than Fret
Fisty
PostPosted: 20:21 - 29 Feb 2012    Post subject: Re: Welding cast Iron Reply with quote
Just had to get someone in who knows how to weld to weld the fire box at home.
It's about 30yo and cast iron. Had to do it over head one handed.
And just about to light a fire to see if it will hold.
Edit:
Obligatory picture taken by me as I watched
EFA
kestrel
PostPosted: 20:42 - 29 Feb 2012    Post subject: Reply with quote
High nickel content rods are indeed used for cast iron repairs. They can be used as a stick welding electrode or as a bare wire with Tig or Oxy/Acet as a heat source.
Cast Iron can be successfully welded with or without preheat, although using preheat is the preferred method. After selecting a method you can not change half way through the job, you must either weld it hot or weld it cold.
If opting for preheat then you need to be able to raise the temperature of the entire component to a working temperature of between 250*C and 650*C which will require a substantial heat source if dealing with a large component. After welding the temperature must be reduced slowly.
Welding without preheat requires that you keep the component relatively cool. To achieve this, limit weld runs to 1" max and allow the component to cool between runs, peening the joint during cooling. Never allow the component to become completely cold until the repair is complete.
Isle of Man.........Road Racing Capital Of The World
Quote Me Happy
PostPosted: 21:04 - 29 Feb 2012    Post subject: Reply with quote
It's nice to see you and your Dad don't let his beating you in the past get in the way of your father-son relationship.
swampy
PostPosted: 21:30 - 29 Feb 2012    Post subject: Reply with quote
Well done for spotting that it is my dad in the pic. Fail for not spotting he is welding r/h since I am L/H and couldn't get in the right position to get a decent run.
The point is, to those of us blessed with not being able to see your facebook page, you implied that it was you welding. You continued to imply this all through this post until someone called you out.
This is why people can't believe a word you say. You can say that you never meant us to believe you were welding, but clearly you did.
Walloper
PostPosted: 21:49 - 29 Feb 2012    Post subject: Reply with quote
Well you can see pretty clearly that it is being welded with 2hands. Also there is a slight size difference between me and my dad. He is massive compaired to me.
I get it now...
That's not even the hearth he's welding.
It's your cage door he's re-attaching after you gnawed through the hinges.
The last post was made 14 years, 207 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.34 - MySQL Queries: 15 - Page Size: 130.78 Kb
