| P.addy |
 P.addy Red Rocket
| chris-red |
| P.addy |
 P.addy Red Rocket
 Posted: 13:20 - 02 Mar 2012 Post subject: |
I have a hair dryer, I also have a 250 and 450 degree C heat gun  |
| chris-red |
| P.addy |
 P.addy Red Rocket
 Posted: 14:02 - 02 Mar 2012 Post subject: |
Tank is off the bike, in my kitchen.
I've been using the 450 mode stripping the paint off with a thin wallpaper scraper Cuts through paint with no effort.
I'll heat the tank up, being metal its stellar at absorbing and retaining the heat.
Looking at online guides and videos, I reckon I'll be in there for over an hour getting it done  |
| chris-red |
 Posted: 15:55 - 02 Mar 2012 Post subject: |
| ##Paddy## wrote: | Tank is off the bike, in my kitchen.
I personally would have left the paint on, unless it was properly fucked I reckon it would produce a better finish to wrap over. I'm not sure how well the wrap will stick to bare metal. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| P.addy |
 P.addy Red Rocket
 Posted: 16:47 - 02 Mar 2012 Post subject: |
Tank was stripped ready for painting but....sod that. I need the bike.
I can always primer it and dry that with the heat gun  |
| Shaft |
 Shaft World Chat Champion
 Posted: 17:17 - 02 Mar 2012 Post subject: |
Vinyl will stick fine to bare metal, but use your hairdryer, heat gun is too harsh.
What you're aiming for is even warmth, rather than spot heat; hold the gun in one place for just a few seconds too long and the vinyl will over stretch, which is not what you want.
Ideally, you want the tank and vinyl up to normal room temperature, say 60-65 degrees, then use the hairdryer just to tease round the tightest curves and angles. You would also do well to use a very weak solution of washing up liquid, sprayed onto the metal surface, which allows the plastic to slide and lets you get any air bubbles out with a squeegee.
If you can, practice on some scrap metal and vinyl and get a feel for how the plastic behaves.
One thing that's absolutely essential is to get the surface totally clean; the slightest bit of old paint or dust will show up as lumps four times as big and cause air pockets, which will grow over time. ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
The last post was made 14 years, 200 days ago. Instead of replying here, would creating a new thread be more useful? |
