Advice with vinyl wrapping
PostPosted: 13:02 - 02 Mar 2012    Post subject: Advice with vinyl wrapping Reply with quote
Hey,
Just looking for advice from anyone who has vinyl wrapped anything.
Anything to do that will help or anything that I shouldn't do?
Its for this tank..
https://www.muamat.com/adpics/4c7c8aa7949b18f71a707262a.jpg
PostPosted: 13:10 - 02 Mar 2012    Post subject: Reply with quote
Heat, lots of if on the tank then some (but don't burn it) on the vinyl.
PostPosted: 13:20 - 02 Mar 2012    Post subject: Reply with quote
I have a hair dryer, I also have a 250 and 450 degree C heat gun Thumbs Up
PostPosted: 13:39 - 02 Mar 2012    Post subject: Reply with quote
I'd say 250C heatgun on the tank and hairdrier on the wrap I can't imagine that a heatgun would cause the Tank to explode but It might be worth draining it and leaving the cap open over a few nights for peice of mind.
The heatgun may be fine for the vinyl but use it at a distance.
Also as a side note, if you have any black plastics that has gone a bit grey, blasting it with a heatgun will bring back the colour. My Givi box had gone very grey and looked tired and crap, about 15 minutes boiling it with a heat gun and it looked new.
PostPosted: 14:02 - 02 Mar 2012    Post subject: Reply with quote
Tank is off the bike, in my kitchen.
I've been using the 450 mode stripping the paint off with a thin wallpaper scraper Laughing Cuts through paint with no effort.
I'll heat the tank up, being metal its stellar at absorbing and retaining the heat.
Looking at online guides and videos, I reckon I'll be in there for over an hour getting it done Laughing
PostPosted: 15:55 - 02 Mar 2012    Post subject: Reply with quote
I personally would have left the paint on, unless it was properly fucked I reckon it would produce a better finish to wrap over. I'm not sure how well the wrap will stick to bare metal.
PostPosted: 16:47 - 02 Mar 2012    Post subject: Reply with quote
Tank was stripped ready for painting but....sod that. I need the bike.
I can always primer it and dry that with the heat gun Laughing
Shaft
PostPosted: 17:17 - 02 Mar 2012    Post subject: Reply with quote
Vinyl will stick fine to bare metal, but use your hairdryer, heat gun is too harsh.
What you're aiming for is even warmth, rather than spot heat; hold the gun in one place for just a few seconds too long and the vinyl will over stretch, which is not what you want.
Ideally, you want the tank and vinyl up to normal room temperature, say 60-65 degrees, then use the hairdryer just to tease round the tightest curves and angles. You would also do well to use a very weak solution of washing up liquid, sprayed onto the metal surface, which allows the plastic to slide and lets you get any air bubbles out with a squeegee.
If you can, practice on some scrap metal and vinyl and get a feel for how the plastic behaves.
One thing that's absolutely essential is to get the surface totally clean; the slightest bit of old paint or dust will show up as lumps four times as big and cause air pockets, which will grow over time.
The last post was made 14 years, 201 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.07 - MySQL Queries: 14 - Page Size: 57.01 Kb
