KH100 Exhaust alternatives,
appaloosadude
PostPosted: 19:19 - 03 Mar 2012    Post subject: KH100 Exhaust alternatives, Reply with quote
Hi people,
does anyone have an idea of an exhaust that will fit a KH100 Kawasaki?
I was wondering if something like a CG125 exhaust will fit with a small amount of modification.
Carvel
PostPosted: 19:26 - 03 Mar 2012    Post subject: Reply with quote
https://lolmart.com/files/2011/03/i-lold.jpg
temeluchus
PostPosted: 20:55 - 03 Mar 2012    Post subject: Reply with quote
There are several KH100 pipes on fleabay for 20-30 quid.
appaloosadude
PostPosted: 08:58 - 04 Mar 2012    Post subject: Reply with quote
The ones on fleabay are worse than the one off the bike, I've had mine off and had a good look at it, there is nothing special about it, no expansion chamber etc, so there is no reason a 4t exhaust shouldn't do the trick.
PostPosted: 11:11 - 04 Mar 2012    Post subject: Reply with quote
Yes there is. The expansion chamber will be internal to the exhaust. I used to have a KE100 which is virtually the same bike, and it definitely had an internal shape that worked as an expansion chamber.
DO NOT graft on an exhaust from a four stroke. You'll just ruin the bike.
stevo as b4
PostPosted: 15:26 - 04 Mar 2012    Post subject: Reply with quote
If you want something that works better than std, then a custom made 2stroke expansion chamber would be the way to go. Even if the dimensions were based on something like a KX100, it would still give the KH a fair bit more top end poke. Matching the pipe volume to the cylinder capacity is the No.1 factor in getting something else to work. Then you'd look at matching the pipe cone shapes and lengths to get the power to the correct rpm range, probably around 8500-10000rpm on a KH100.
dangerousdave
PostPosted: 18:31 - 05 Mar 2012    Post subject: Re: KH100 Exhaust alternatives, Reply with quote
Hi people,
Whats wrong with your original exhaust ?
If the ones on eBay are worse than yours then why not just give yours a good clean up, decoke, and if leaking then get it welded up?
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
temeluchus
PostPosted: 19:57 - 05 Mar 2012    Post subject: Reply with quote
As marjay says, there is a tuned region in the can.
The pipe as fitted to the kh100 is configured to help the bike have a wider powerband than it would with a more aggressive expansion chamber.
Fitting a simple 4 banger pipe will kill the motor.
The last post was made 13 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.66 - MySQL Queries: 13 - Page Size: 65.36 Kb
