| grant965 |
 grant965 Brolly Dolly
 Posted: 22:10 - 04 Mar 2012 Post subject: Restricting a previously tuned bike |
Hi, looking around for a new (to me) bike and Ive seen a tidy bandit, only problem is that it has been dynojetted and tuned to suit and Im on a restricted license.
Surely the same standard restrictors wouldn't work?
Any ideas, other bandits in this good condition don't come up that cheap within a reasonable distance very often so looking for another wouldn't be my first choice.
thanks, Grant ____________________ Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R |
| temeluchus |
| lihp |
 lihp World Chat Champion
 Posted: 22:19 - 04 Mar 2012 Post subject: |
Get it back to standard first, then restrict, simples
I personally don't like buying modified bikes where original parts are unavailable, are they? If so, it should be just a few hours of work to get it back to standard. |
| grant965 |
| lihp |
| grant965 |
| hornetmike |
 hornetmike World Chat Champion
| grant965 |
| hornetmike |
| Kickstart |
 Kickstart The Oracle
 Posted: 22:35 - 04 Mar 2012 Post subject: |
Don't think it will make a major problem with the fueling. Should behave just like not opening the throttle that much.
However depends on what they have done to tune it. It could still produce a bit more power than a standard restricted bike. Could also land up producing a bit less than a standard bike. Depends on what has been done to shuffle around the power (ie, different design of exhaust, not just the can, different cams, etc).
| Redoko |
 Redoko World Chat Champion
| temeluchus |
| lihp |
| Kickstart |
| lukamon |
 lukamon World Chat Champion
| Frost |
 Frost World Chat Champion
 Posted: 00:34 - 05 Mar 2012 Post subject: |
The bike is like a fit runner, normal bandits are like normal people. Restricting is like making them breathe through a straw. Both are going to be massively down on performance
The dyno kit might add a few bhp to a full power bike, but once restricted it will probably be exactly the same as a normal one. |
| janner_10 |
 janner_10 World Chat Champion
| lukamon |
| temeluchus |
 Posted: 01:05 - 05 Mar 2012 Post subject: |
| PhilDawson8270 wrote: | I suppose it would depend on the method of restriction. Throttle restrictors, then yes, it will be just like using partial throttle.
Restrictors that restrict air flow, such as the washers that go under the carbs, can cause fuelling issues for numerous reasons, some bikes have issues, some don't.
However, a lot of sports bikes have issues restricted by this method and really don't run well at all restricted with Washers.
The higher state of tune that the engine is in, the more and more critical the fuelling becomes for smooth and correct operation, this makes restriction with washers less reliable and more likely to have running problems.
If you're going to restrict a bike, then a tuned/modified, or high performance engine isn't the ideal place to start from.
If there is a restrictor on the throttle, or slides then it's a better way of doing it, and in my opinion gives a more guaranteed operation post restriction. |
You show ignorance of how CV carburettors operate. There is NO functional difference between a throttle stop, slide stop or restriction washers. The rider opens the secondary throttle which allows the engine to place demand on the carburettor. This demand (vacuum) controls the primary throttle which holds the needle and controls the fuelling. The plates place a maximum on the demand-they will not alter the fuelling as a CV carb works on demand, regardless of the operators ham fist.
Dont get confused with straight "slide" (non CV) carbs.
I doubt the bandit has had any real performance tuning. Adding a aftermarket can and a dynoject kit is only tuning in the sense of making the engine run correctly with the new pipe. ____________________ Some shite cruiser. Now with guns and FREEDOM! |
| lihp |
 Posted: 09:41 - 05 Mar 2012 Post subject: |
Admitedly Carbs are not my area, I'm from a fuel injection era, and only worked with carbs on bikes, plus I've never used restrictors, I'll edit my above post so I don't mis lead anybody.
Thanks  |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:32 - 05 Mar 2012 Post subject: |
Go for it. It shouldn't nob up the fulling, and how many people bother to check that their 'restricted' bike is really making <=25kW (at the crank!) anyway? ____________________ Biking is 1/20th as dangerous as horse riding.
The last post was made 14 years, 182 days ago. Instead of replying here, would creating a new thread be more useful? |
