Restricting a previously tuned bike
grant965
PostPosted: 22:10 - 04 Mar 2012    Post subject: Restricting a previously tuned bike Reply with quote
Hi, looking around for a new (to me) bike and Ive seen a tidy bandit, only problem is that it has been dynojetted and tuned to suit and Im on a restricted license.
Surely the same standard restrictors wouldn't work?
Any ideas, other bandits in this good condition don't come up that cheap within a reasonable distance very often so looking for another wouldn't be my first choice.
thanks, Grant
Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R
temeluchus
PostPosted: 22:19 - 04 Mar 2012    Post subject: Reply with quote
They should be ok-the restictors fit between the carbs and the engine stopping the engine from breathing properly-in effect, no matter how far you open the throttles on the carbs, the restrictors keep the engine throttled.
I assume we are talking a bandit 600 running a dynojet kit and maybe an aftermarket can. that would only add at most a few horsepower, mostly at the top end.
lihp
Get it back to standard first, then restrict, simples Wink
I personally don't like buying modified bikes where original parts are unavailable, are they? If so, it should be just a few hours of work to get it back to standard.
grant965
PostPosted: 22:21 - 04 Mar 2012    Post subject: Reply with quote
it says this:
'the bike has been dynajetted on a rolling road and had the engine professionally tuned (all paperwork included)'
not entirely sure what that includes though
lihp
PostPosted: 22:23 - 04 Mar 2012    Post subject: Reply with quote
I would imagine that restricting with a dynojet kit fitted will make a mess of fuelling.
grant965
PostPosted: 22:24 - 04 Mar 2012    Post subject: Reply with quote
Am i right in thinking a dynojet is added/used in the carbs? Could I simply change the carbs to some standard ones?
thanks
hornetmike
Buy a different Bandit there is loads of them
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
grant965
PostPosted: 22:27 - 04 Mar 2012    Post subject: Reply with quote
not like this one, body and paint looks spot on. Isn't in the usual dull/faded red, unusually there is nothing I would change on it.
Priced just below other bandits, looks like its owned by a guy who knows his stuff.
hornetmike
PostPosted: 22:34 - 04 Mar 2012    Post subject: Reply with quote
Its going to take effort put it back to standard and will run rubbish if you don't do it right, restrictors make most bikes run rough without extra fuel from dyno jets
PostPosted: 22:35 - 04 Mar 2012    Post subject: Reply with quote
Don't think it will make a major problem with the fueling. Should behave just like not opening the throttle that much.
However depends on what they have done to tune it. It could still produce a bit more power than a standard restricted bike. Could also land up producing a bit less than a standard bike. Depends on what has been done to shuffle around the power (ie, different design of exhaust, not just the can, different cams, etc).
Redoko
And ragged it to boot.
Don't rush. There are plenty of other bikes.
temeluchus
PostPosted: 22:42 - 04 Mar 2012    Post subject: Reply with quote
Why? Can you explain this?
Restrictor plates effectively mean the throttle is never fully opened. Will not have any effect on fuelling.
lihp
PostPosted: 22:52 - 04 Mar 2012    Post subject: Reply with quote
removed as inaccurate, don't want to mislead.
PostPosted: 23:21 - 04 Mar 2012    Post subject: Reply with quote
Restrictors that restrict air flow, such as the washers that go under the carbs, can cause fuelling issues for numerous reasons, some bikes have issues, some don't.
Shouldn't really. The washers after the carbs limit the air flow, in the same way that the throttle does. It is this air flow that moves the slide in the CV carb that controls the fueling.
lukamon
PostPosted: 00:07 - 05 Mar 2012    Post subject: Reply with quote
thanks
hi there id like some dynojetting put in my carbs please
certainly sir, ill just finish putting the headlight fluid in this obe and ill be right with you
killa wrote: Im an ass man myself
Frost
PostPosted: 00:34 - 05 Mar 2012    Post subject: Reply with quote
The bike is like a fit runner, normal bandits are like normal people. Restricting is like making them breathe through a straw. Both are going to be massively down on performance Laughing
The dyno kit might add a few bhp to a full power bike, but once restricted it will probably be exactly the same as a normal one.
janner_10
PostPosted: 00:37 - 05 Mar 2012    Post subject: Reply with quote
I can't find any headlight fluid on ebay, it must be rare.
lukamon
PostPosted: 00:52 - 05 Mar 2012    Post subject: Reply with quote
thanks
temeluchus
PostPosted: 01:05 - 05 Mar 2012    Post subject: Reply with quote
I suppose it would depend on the method of restriction. Throttle restrictors, then yes, it will be just like using partial throttle.
However, a lot of sports bikes have issues restricted by this method and really don't run well at all restricted with Washers.
The higher state of tune that the engine is in, the more and more critical the fuelling becomes for smooth and correct operation, this makes restriction with washers less reliable and more likely to have running problems.
If you're going to restrict a bike, then a tuned/modified, or high performance engine isn't the ideal place to start from.
If there is a restrictor on the throttle, or slides then it's a better way of doing it, and in my opinion gives a more guaranteed operation post restriction.
You show ignorance of how CV carburettors operate. There is NO functional difference between a throttle stop, slide stop or restriction washers. The rider opens the secondary throttle which allows the engine to place demand on the carburettor. This demand (vacuum) controls the primary throttle which holds the needle and controls the fuelling. The plates place a maximum on the demand-they will not alter the fuelling as a CV carb works on demand, regardless of the operators ham fist.
Dont get confused with straight "slide" (non CV) carbs.
I doubt the bandit has had any real performance tuning. Adding a aftermarket can and a dynoject kit is only tuning in the sense of making the engine run correctly with the new pipe.
lihp
PostPosted: 09:41 - 05 Mar 2012    Post subject: Reply with quote
Admitedly Carbs are not my area, I'm from a fuel injection era, and only worked with carbs on bikes, plus I've never used restrictors, I'll edit my above post so I don't mis lead anybody.
Thanks Thumbs Up
PostPosted: 10:03 - 05 Mar 2012    Post subject: Reply with quote
grant965 wrote:
it says this:
Ask the man what it included. I'd be dubious of any engine tuning actually having occured. Firstly because it's on ebay, and secondly because he can't spell "dynojet" correctly.
Ask for a photo of the paperwork and details of the actual tuning. Thumbs Up
(My money's on an oil change and some iridium spark plugs)
PostPosted: 10:32 - 05 Mar 2012    Post subject: Reply with quote
Go for it. It shouldn't nob up the fulling, and how many people bother to check that their 'restricted' bike is really making <=25kW (at the crank!) anyway?
The last post was made 14 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 118.96 Kb
