Interchangeability of Suzuki GP100 and Yamaha RXS100????
Dan79
PostPosted: 20:49 - 05 Mar 2012    Post subject: Interchangeability of Suzuki GP100 and Yamaha RXS100???? Reply with quote
My RXS100 has died and I have been looking for a replacement. I am considering a GP100 in my local area.
The GP100 seems superficially quite similar to the RXS; my question is, are there parts that are interchangeable between these two bikes, should I decide to retain the corpse of the RXS100 - thinking of items such as switches, chain and sprockets, battery, brakes, cables.
Cheers,
Dan
Previous bikes - 1984 Honda VF500 (FII) Interceptor and 1990 Yamaha RXS100
Current bikes - 1984 Honda VF500 (V30) Magna
Dan79
PostPosted: 20:58 - 05 Mar 2012    Post subject: Reply with quote
Rob Fzs wrote:
whats up wuth the rxs?
The engine melted.
Dan79
PostPosted: 22:26 - 06 Mar 2012    Post subject: Reply with quote
Thanks for the responses, whilst not answering the question, it has however made me think that I should perhaps reconsider given the stock that a lot of contributors to this forum give to the RXS100. My only concern is the fact that whilst can fit tyres, brakes, gears, etc - basicall other moving parts where I can see cause and effect, I have zero experience diagnosing and fixing faults with engines and zero cash to spend on a whole new engine.
Sounds as though i had better start a new topic in The Workshop.
Dan79
Teflon-Mike
tl;dr
PostPosted: 22:56 - 06 Mar 2012    Post subject: Reply with quote
RSX Engine is as simple as they come. If you can replace drum brake shoes; you can rebuild an air-cooled two stroke single!
Support for the old Yams is FAR better than the less popular and more obscure Suzukis, as not only did they make a lot more of any individual model, they also did a lot of parts-bin raiding and made bits interchangeable accross many models.
Eg: headstock bearings in my DT175 are common to about twenty different bikes! Fork seals are same as DT100, RSX and a few others.
Stick with the Yam. Get a Haynes for it of you dont have one, and get brave with that motor.
If you cant 'handle' the mechanics on that; you're on a high road to no-where with an old GP100!
Dan79
PostPosted: 23:34 - 06 Mar 2012    Post subject: Reply with quote
thanks Teflon Mike, this is the sort of thing I was hoping to hear, I've known for a long time that bits for the RXS100 are abundant and that they don't come much simpler, and am now reconsidering its fate.
PostPosted: 00:02 - 07 Mar 2012    Post subject: Reply with quote
To go to your original question, next to nothing will be easily swapped between the 2. Maybe handlebars, clutch and brake levers with pivots (ie, swap complete assemblies over).
The last post was made 13 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 67.92 Kb
