Milky brown Liquid from engine
machete101
PostPosted: 18:36 - 03 Mar 2012    Post subject: Milky brown Liquid from engine Reply with quote
Hello
I have just notice on my KH125 project bike that when you kick it over a milky brown liquid is coming out from the engine throught the carb intake, and is a fair amount of liquid.
Im guessing that is off oil that been sitting, but what i am wondering is was is the best sort this problem, have i got to drain the oil and flush out the old, if not what would i need to do?
thanks
PostPosted: 19:46 - 03 Mar 2012    Post subject: Reply with quote
How much is a "fair amount"?
A few tens of ccs or a few hundreds of ccs? Drips or a stream?
machete101
PostPosted: 20:03 - 03 Mar 2012    Post subject: Reply with quote
it not a massive amount but the carb inlet is soon full will then go it to the carb after around 4+ kicks. But will only start to come out when the engine is being kicked over.
seen as it only happens then, im guessing it oil that either been sitting, or it been mixed with water or something else.
what can i do to solve the problem
thanks
temeluchus
PostPosted: 20:50 - 03 Mar 2012    Post subject: Reply with quote
thanks
Give the cases a good swill out with paraffin or petrol to clean out all the gunk.
May be easier to get the engine out, remove the head and barrel so you can give the bottom end a good shake around to get at all the nooks and crannies.
machete101
PostPosted: 20:55 - 03 Mar 2012    Post subject: Reply with quote
ok then thanks. I got the engine out the frame today ready, could this liquid being causing the engine not to run aswell, as it get it to the carb after a around 5 or so kicks.
Is there anything else i should check while i have the engine out, as it has been sitting for a while.
thanks
temeluchus
PostPosted: 21:00 - 03 Mar 2012    Post subject: Reply with quote
thanks
drain the gearbox oil and check for any rust/metallic particles.
Check the piston and barrel for scuffs, that the conrod has no side to side slop and the bearings on the crank for corrosion. Carburettor will most likely need new seals and a new float needle. Points will need looking at as well.
Im not overly familiar with two strokes, but I think the KH is autolube so the function of the oil pump will need checking. Someone more familiar with smokers will no doubt come along shortly.
PostPosted: 16:54 - 04 Mar 2012    Post subject: Reply with quote
To add to the suggestions above, check your air filter. Could be someone has heavily oiled the foam filter element and that has drained down to the carb
Quikmac
PostPosted: 22:16 - 05 Mar 2012    Post subject: Re: Milky brown Liquid from engine Reply with quote
machete101 wrote:
Hello
thanks
Any 'milky brown liquid' sounds serious, as though oil is mixing with water. Check to see if oil is getting in your water and vice versa.
Forward, cultivate and speed!
Quikmac
PostPosted: 22:50 - 05 Mar 2012    Post subject: Reply with quote
Rob Fzs wrote:
oil in 2 stroke bottle full of water ?
Ah! See wot you mean!
machete101
PostPosted: 13:22 - 06 Mar 2012    Post subject: Reply with quote
thanks for the replies
im gunna give the engine a rinse out try get all the rubbish out, but do you reckon be better to take the cylinder off so i can clean it a bit easier, or is it not needed?
Also what is the best way to rinse it all out?
thanks
The last post was made 13 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 71.01 Kb
