cbr 125 07 plate chain comes loose quick
superleeds76
PostPosted: 13:46 - 07 Mar 2012    Post subject: cbr 125 07 plate chain comes loose quick Reply with quote
hello all
i have as posted a cbr 125 on a 07
i bought the bike from a dealer about 6 months ago and everything is great apart from my chain
i had it replaced by a garage 2 months ago as it had streched as far as it could go
its a heavy duty DID chain and sprocket
its now nearly at its max again im tightening the chain every week and half is this normal?
since buying the bike ive done 2000 miles and use it everyday
im a complete novice on why this could be happening and any help advice would be great
P.
PostPosted: 14:07 - 07 Mar 2012    Post subject: Reply with quote
When are you cleaning and adjusting it?
It should have about 2cm - 2.5cm movement.
My CBR did a chain and sprocket set every ~10k...thats with a fair bit of abuse, not so much cleaning Laughing
jimbopea
PostPosted: 14:42 - 07 Mar 2012    Post subject: Reply with quote
and how often are you lubing it, i've been recomended to do it every 200 miles and to do it after youve ridden it so the chains warm and it soaks in, dont do it in the morning before you go as you'll just chuck it back off. hth
superleeds76
PostPosted: 16:36 - 07 Mar 2012    Post subject: Reply with quote
i clean the chain and re lube every week as i use it nearly everyday for work
im adjusting it to 3cm play
this new chain had prob only done 500-700 miles just seems to be coming slack too quick
P.
PostPosted: 16:52 - 07 Mar 2012    Post subject: Reply with quote
Do it tighter... aim for about 2cm.
Hows your wheel alignment?
superleeds76
PostPosted: 17:38 - 07 Mar 2012    Post subject: Reply with quote
i think the alignment should be ok i have the small marks on the tensioner same both sides plus i use a metal ruler to measure both sides back
ive tightened it now to about 2 cm of play
PostPosted: 17:55 - 07 Mar 2012    Post subject: Reply with quote
Sounds like it is wearing far too quickly to me. Wouldn't expect it being slightly loose to make that much difference (too tight would though).
Was it definitely a DID chain and were both sprockets replaced?
jimbopea
PostPosted: 18:44 - 07 Mar 2012    Post subject: Reply with quote
You may also want to get a mate or someone to check the tension when your sat on the bike, if its really tight when your sat on it you may want to leave a little more slack.
James
superleeds76
PostPosted: 20:08 - 07 Mar 2012    Post subject: Reply with quote
yea def DID chain and he replaced both sprockets
thats why i cant understand why its wearing so quick
is there anything that could be causing it?
ive sat on the seat and had chain play measured at 2 cm
just cant get my head round it
superleeds76
Taught2BCauti...
PostPosted: 22:06 - 07 Mar 2012    Post subject: Reply with quote
Chain would stretch if it was too tight - try adjusting it to 30mm and see if that makes a difference over 2 weeks.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
andys675
PostPosted: 22:13 - 07 Mar 2012    Post subject: Reply with quote
did you buy the chain off ebay really cheap?
the unbelievably cheap DID chain on ebay is counterfeit!
1cyl
PostPosted: 23:17 - 07 Mar 2012    Post subject: Reply with quote
Have you checked the tension at each 1/4 turn of the wheel to see if its the same, i remember being puzzled for ages with the Z to get the tightness right because it had tight and loose spots.
Try accurately measuring a set number of links, at least 18, and keep a record of it then check again at a later date for stretch.
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
The last post was made 13 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 76.65 Kb
