Nsr engine problem
nsr125.98
PostPosted: 22:05 - 25 Sep 2004    Post subject: Nsr engine problem Reply with quote
When I accelerate hard my engine is stuttering and jolts. It seems to be getting worse and my rev counter has a mind of its own. Its also backfiring and popping. Any Ideas as to why its doing this,as it getting dangerous when I pull out of junctions now.any help greatly appreciated
Gary
mr jamez
PostPosted: 22:10 - 25 Sep 2004    Post subject: Reply with quote
I would check the timing, could possibly be a fault in the ignition system as it is backfiring and popping. Reed valve might be buggered?
Change the spark plug first though.
nsr125.98
PostPosted: 22:13 - 25 Sep 2004    Post subject: Reply with quote
I changed the plug and cap today and cleaned up the connection on the coil. How would I adjust the timming?
gary
mr jamez
PostPosted: 22:18 - 25 Sep 2004    Post subject: Reply with quote
It is factory set and cannot be adjusted as such, you will need a timing light to check that it is correct, sorry I can't remember off heart what would cause it to be wrong (wait for kickstart to arrive Smile)
Oh and if it is reving randomly perhaps check for an airleak, make sure the rubber intake manifold is not split, and spray WD40 around the base on the gasket to see if air is getting sucked in. You will need to remove the carb and the manifold to check the reed valves.
alains
PostPosted: 22:19 - 25 Sep 2004    Post subject: Reply with quote
i agree , any of these problems come from , sparkplug (try a BR9EIX from https://www.sparkplugs.co.uk ) , carbon or badly timed RCvalves , tired reed valves (try bue-oil carbon set) . you may check in this order , avoiding to lost money for nothing . by the way using an EIX sparkplug will save 1/2 to 3/4 L each time you fill up .
nsr125.98
PostPosted: 22:26 - 25 Sep 2004    Post subject: Reply with quote
I think that my dad checked the timing(used to be a mechanic) using a light thing and said it was alright.
And I thought Honda's were supposed to be reliable Rolling Eyes
mr jamez
PostPosted: 22:31 - 25 Sep 2004    Post subject: Reply with quote
No bike will go on forever and ever Smile it won't take long to find the problem.
nsr125.98
PostPosted: 22:35 - 25 Sep 2004    Post subject: Reply with quote
It just seems that everything is going wrong at once, like my indicators not flashing, speedo drive breaking, exhaust falling apart, general electrics dodgy! Evil or Very Mad
mr jamez
PostPosted: 22:47 - 25 Sep 2004    Post subject: Reply with quote
Get a new relay for the indicators, about £2. You can pic a speedo drive and exhaust up cheap on ebay, even buy a whole wiring loom cheap. NSR's are not hard to fix, there is hardly anything to them really Smile
alains
PostPosted: 22:49 - 25 Sep 2004    Post subject: maintenance Reply with quote
i would like to tell to everyone of you that the NSR is a nice & reliable bike , but like the beautiful women it nees to be cocooned . do your maintenance as recommanded by honda , better your treat your nsr better it will respond to you i forgot prior of this post to recommand a good cleaning of tank & carb (due to water or mud)
NSR125-Kid-UK
Attention Whore
PostPosted: 04:10 - 26 Sep 2004    Post subject: Re: maintenance Reply with quote
The NSR is a reliable bike, in 8 months I've not had any problems with mine Smile.
Just one thing, how would he get mud in his fuel tank?
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
alains
PostPosted: 11:23 - 26 Sep 2004    Post subject: Reply with quote
by low quality petrol , especially when you fill up with the bottom of the services tank or when the % of humidity in the petrol is high . what i will recommand is to clean carb and tank every year .
washhandbasin
PostPosted: 16:28 - 26 Sep 2004    Post subject: Reply with quote
whats the battery like the powervalves are worked by a servo the rev counter is electric to Shocked
skinup!!!!!!!!
alains
PostPosted: 16:39 - 26 Sep 2004    Post subject: Reply with quote
you're wrong because the power tricity is provided by the alternator , but it could be possibly a faulty regulator . this is easy to verify , if you your engine start normally with the starter , your battery is fonctional . but if after several starts you have not any more power in the battery , the charge is not working , and as far as it does not charge your ignition will not work either
nsr125.98
PostPosted: 17:35 - 26 Sep 2004    Post subject: Reply with quote
Im not sure if the battery is ok, mite get it checked. Dont think i've got mud in my fuel tank though Very Happy. Thanks for your helpful replies
gary
alains
PostPosted: 17:48 - 26 Sep 2004    Post subject: Reply with quote
take off the tap and you will be surprised by what you will find inside the filters
The last post was made 22 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 87.59 Kb
