Honda NTV 600 revere possible problem?
groovylee
PostPosted: 16:57 - 11 Mar 2012    Post subject: Honda NTV 600 revere possible problem? Reply with quote
Guys, i might have an issue. or i might not.
basically, i removed the generator casing on the revere, and there was oil in there. being a bit of a bike engine newbie (cars i'm fine with - engineer by trade, just never on bikes) i'm not sure if that's normal, or if my crank seal is boogered?
many thanks,
Lee
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
Taught2BCauti...
PostPosted: 17:27 - 11 Mar 2012    Post subject: Reply with quote
Sorry it's not better news, but there should never be oil inside the generator casing.
However, I think you can change the crankshaft seal fairly easily without stripping too much of the engine, just by removing the stator plate.
IIRC, the seal can be removed by carefully drilling two small holes on opposite sides of the seal, screwing in 2 x self-tapping screws a couple of turns, then pulling the seal out with pliers.
The new seal can be tapped back into place, using a suitably sized box spanner or piece of tube as a drift.
I'm sure someone with more detailed knowledge of the specific model will correct me if I'm wrong.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
groovylee
PostPosted: 17:39 - 11 Mar 2012    Post subject: Reply with quote
balls! oh well, cheers mate Smile
groovylee
PostPosted: 19:05 - 11 Mar 2012    Post subject: Reply with quote
ok, good news, just had a reply from someone on the NTV forum, and they say it is perfectly normal as the starter pinion gears etc are in there, and it runs a wet generator.
Phew! Thumbs Up
sickpup
Old Timer
PostPosted: 19:54 - 11 Mar 2012    Post subject: Reply with quote
Complete and utter rubbish in so many instances.
Have you ever worked on bikes before as your knowledge is woeful?
groovylee
PostPosted: 22:37 - 11 Mar 2012    Post subject: Reply with quote
cheers for confirming sickpup Thumbs Up Karma
The last post was made 14 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.48 - MySQL Queries: 13 - Page Size: 48.42 Kb
