| Bikay |
 Bikay Borekit Bruiser
 Posted: 22:07 - 19 Sep 2004 Post subject: Dent removal for cans? |
Very cleverly I managed to dent the can on my CBR600. The dent is on the end where the can narrows to the exit hole. It's a standard stainless job so it'll be there forever and it's really starting to bug me!!
I knocked it against a bar in a bike shed at work. Unfortunately I can't get inside to knock it back out. Does anyone have any ideas on how to get the dent removed? |
 Posted: 22:40 - 19 Sep 2004 Post subject: |
If you can block off the ends, connect it to a compressor whilst heating the area of the dent with a blowlamp, you might be able to pop it out. This is how they make a lot of exhaust systems. I have seen it done with dented petrol tanks too but be carefull, it might also turn into a hand-grenade. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Bikay |
 Posted: 00:53 - 20 Sep 2004 Post subject: |
A 'poor mans' way of doing this which might work for a small, non-creased dent in the body of the can would be to put the can in the freezer and whilst it is still cold, seal up the ends (a big cork and lockwiring?) not exactly sure how you would do this, be imaginative (gaffa tape is your friend).
Take the still cold and now sealed can and pour a kettle of boiling water over it, the sudden expansion of the air inside as it heats up should in theory pop out a small dent. Again heard of this being done for petrol tank dents rather than end-cans but the principle is the same.
I have seen this used in reverse to spectacular effect by throwing iced water over an oil drum (a big one) which was heated then sealed up. Created enough pressure difference to crumple it like a soft drinks can. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Big Pete |
 Big Pete Spanner Monkey
| jay12329 |
 jay12329 Dr. Evil
| Bikay |
 Posted: 17:59 - 20 Sep 2004 Post subject: |
I've had a look at a few dent removal kits that involve glueing a rod into the centre of the dent. Once the glue is set the rod is pulled on. In theory the dent is removed and the glue is diossolved with an appropriate solvent.
Anyone have any experience of these kits?  ____________________ Check out my bikay cha'mone! |
| Big Pete |
| ZRX61 |
 ZRX61 Victor Meldrew
| ZRX61 |
| Big Pete |
| Big Pete |
| Bendy |
 Bendy Mrs Sensible
| ZRX61 |
 Posted: 15:57 - 21 Sep 2004 Post subject: |
This:
https://www.prospot.com/shopping/images/featured-pr2pic.gif
It's a combo welder/slide hammer. You touch the tip to the panel, pull the trigger & it welds itself to the panel, pull on the slide hammer to pull the dent, twist it 90deg to break the weld & all ya have left if a really small pimple instead of a bloody great hole.
Details:
https://www.prospot.com/pr2/index.shtml
I can't honestly believe any course would teach people to drill holes in the panels, thereby creating even more damage to be fixed No prob using the slide hammer you showed with the bendy bits for getting around the edge of wheel arches etc tho. |
| swampy |
 swampy World Chat Champion
 Posted: 16:03 - 21 Sep 2004 Post subject: |
My old man (35+ years as a mechanic/ fabricator) always pulls dents out by the method used by Big Pete, so it ain't that rare.....
And wouldn't you have some problems welding the rod to a stainless steel end pipe ?? ____________________ "I hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me." Hunter S Thompson
"Faster, faster, faster, until the thrill of speed overcomes the fear of death..." Hunter S Thompson |
| Big Pete |
| ZRX61 |
| Big Pete |
| ZRX61 |
| swampy |
 Posted: 09:51 - 22 Sep 2004 Post subject: |
| swampy wrote: | My old man (35+ years as a mechanic/ fabricator) always pulls dents out by the method used by Big Pete, so it ain't that rare.....  |
I suggest he gets retrained with some newer methods....
lol, I'll tell him that, cant see it going down too well though... old dog, new tricks etc ____________________ "I hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me." Hunter S Thompson
| loply |
 loply World Chat Champion
| ZRX61 |
 Posted: 16:24 - 26 Sep 2004 Post subject: |
| loply |
| ZRX61 |
The last post was made 22 years, 13 days ago. Instead of replying here, would creating a new thread be more useful? |
