NSR electrics help!!!
Bunter
PostPosted: 18:55 - 26 Sep 2004    Post subject: NSR electrics help!!! Reply with quote
ok was doing some work on nsr and had the air filter and all out. Put all back together and turned the key and there was nothin, no sounds lights or anything. Checked the main fuses and they looked ok.
Any other ideas???
c058y
PostPosted: 19:19 - 26 Sep 2004    Post subject: Reply with quote
I recently had this problem! It turned out to be corroded wires within the loom!
I put a post on here regarding this, have a look at it and it should help you!
Good luck
https://www.bikechatforums.com/viewtopic.php?t=29643
Bunter
PostPosted: 19:31 - 26 Sep 2004    Post subject: Reply with quote
so am i just gonna have to wiggle everything until it lights up or sumthin???
c058y
PostPosted: 19:54 - 26 Sep 2004    Post subject: Reply with quote
tried that myself, but it just didnt work. You can give it a go but the thing is if you manage to fix it temporarily, when will it stop working again? While your riding the thing? I know I wouldnt want to risk it.
Good luck if you try and locate the corroded wires within the loom. Just remember after checking a section replace the wires where they came from otherwise the mechanic that you hand the bike over to will hate you for it, plus it will cost you even more to repair!
alains
PostPosted: 20:21 - 26 Sep 2004    Post subject: Reply with quote
first , check the battery voltage (sould be 12.8 to 13.2 Vots) and if it's less than that , put it in slowly charge for 6 hours (max 2Amps)
secondl , check the fuse (take it off , check with ohmmeter) , if OK then clean the contacts (even on the support)and replace it
third , check your ground connection wiring , it's a green big wire going from the battery to the starter (may be broken somewhere)
The last post was made 22 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 42.93 Kb
