Gilera DNA - 2 days old and wont start
Morcs74
PostPosted: 19:18 - 26 Sep 2004    Post subject: Gilera DNA - 2 days old and wont start Reply with quote
Sad I brought a brand new Gilera DNA 50 on friday, Already put 70 Miles on the clock.
But the electric Starter doesnt want to work any more so it takes about 20 minutes kickstarting it every time.
Because the DNA is notorious for cutting out in wet wheather i bought some 'damp start' spray and sprayed all the electrics and it forms a conductive rubber seal around them.
Ever since ive done that the electric starter hasnt worked but im not sure if that caused it.
HELP!
tatters
Exxon Valdez
PostPosted: 19:26 - 26 Sep 2004    Post subject: Reply with quote
if its "new" take it back to the dealership you got it from
Morcs74
PostPosted: 19:31 - 26 Sep 2004    Post subject: Reply with quote
I thought of that obviously, I need a quick fix though, ive got a 13 mile trip to work in the morning and i dont want to be stood outside kickstarting it at 7 o'clock freezing my B*locks off!
PostPosted: 19:57 - 26 Sep 2004    Post subject: Reply with quote
If you've sprayed some stuff all over the electrics and after you did that it now doesn't work the shop won't fix it as it sounds like the spray has killed the electrics. Remove all of it and see if that helps, if not something in the electrics is probably fried and you've got to try to find out what.
AdamBoyle
PostPosted: 19:58 - 26 Sep 2004    Post subject: Reply with quote
Make sure the dealer hasnt had the thing sitting in his showroom for ages taking no care of the battery.. Check it on a multimeter and shove the thing on charge if it needs it..
Always worth checking Very Happy
Nath
PostPosted: 22:05 - 26 Sep 2004    Post subject: Reply with quote
Do all the other electrics work? If it's just the electric start, then try using a multimeter to see whether it's the starter motor itself, or just the wiring.
Hard livin', hard luck.
Morcs74
PostPosted: 19:03 - 27 Sep 2004    Post subject: Reply with quote
Today, after trying the electric start, something was wurring away but not engaging on something, even when engine turned off and keys taken out it carried on. Only a kick in frustration stopped it!
Ive taken the advice and contacted the dealer, apparently the battery is defective and needs replacing because its not charging properly?!
Thanks for the suggestions anyway. Thumbs Up
Rollins
PostPosted: 02:15 - 28 Sep 2004    Post subject: Reply with quote
My DNA NEVER cut out, 15 months worth of riding, 2 winters, every single day it was ridden - electrics were all 100% immaculate. No corrosion inhibitor spray, just Halford's Car wash and its "protective film".
"... I wouldn't mind doing 130 up to a T junction, but unfortunately my bike tops out at 120 which is gay..."
2005 CBR600RR
Morcs74
PostPosted: 08:59 - 28 Sep 2004    Post subject: Reply with quote
Your lucky then mate, from what ive heard, a DNA with no problems is a rareity.
bikedudextrm
PostPosted: 13:53 - 28 Sep 2004    Post subject: Reply with quote
Sounds to me like the through-out starter gear has come loose, that's what the wurring sound is. Just take the engine casing off, give it a bit of a greasing and put it back in place.
Police Tut Tut
https://www.bikepics.com/members/bikedudextrm/
Rollins
PostPosted: 22:44 - 28 Sep 2004    Post subject: Reply with quote
To be fair, it wasn't 100% reliable - the HT disconnected itself once (in dry weather). But apart from that - unblemished record. Maybe 99.99% reliable.
2005 CBR600RR
The last post was made 22 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 66.67 Kb
