Technical Guru's Click Here!!!
MarsBar
PostPosted: 17:50 - 05 Sep 2002    Post subject: Technical Guru's Click Here!!! Reply with quote
Ok. I remember a while ago, someone posted complaining their NSR held back for a short time at about 6000-7000rpm (ish). Did you fix this problem coz now mine does it?
PLEASE HELP!!! Crying or Very sad Evil or Very Mad
Hunter
PostPosted: 18:11 - 05 Sep 2002    Post subject: Reply with quote
Check carb and spark plug.
Not a guru on 2 strokes.. but I had a similar problem and was sorted after a carb cleanup and plug re-gap.
Smile
Doddmaster
PostPosted: 18:34 - 05 Sep 2002    Post subject: Reply with quote
When I rode an NSR for the first time, I noticed a flat spot there. It might be normal
Wingchunal
PostPosted: 18:37 - 05 Sep 2002    Post subject: Re: Technical Guru's Click Here!!! Reply with quote
What do you mean by that? no power in that spot???
I found if you drop below that amout of revs it takes a while to get back up again without dropping a gear
Scotty
Scooter Boi
PostPosted: 19:11 - 05 Sep 2002    Post subject: Reply with quote
when i was first getting used to the bike and i changed gear going quite fast and it dropped into the 7000rpm range i noticed it took a second or so to get the bike pulling again even when ive got the throttle wide open.
Ive sold this problem by learning how to change the gears better......
and not suffered with any flat spots since
scott
Regards
Scott
JimboJ
Manc Pikey
PostPosted: 19:13 - 05 Sep 2002    Post subject: Reply with quote
too much fuel for too low revs i think youll find Smile!
I THINK
[00:42] <NSR-Andy> which one's the missionary position
[00:42] <NSR-Andy> i've heard it's good
[9:42pm] <Shaun> you came first mike | <Shaun> yes gav, because I really want to fuck you
Wingchunal
PostPosted: 19:14 - 05 Sep 2002    Post subject: Reply with quote
The only time my bike see's low revs is when its just ocme nout fo the garage Very Happy
MarsBar
PostPosted: 16:50 - 06 Sep 2002    Post subject: Reply with quote
Cheers for all your replies!! Laughing
It seems to happen when i accelerate (even in first gear) and when i hit 6000rpm ish it will suddenly hold back. A sort of stutter, then it will pick up agian at about 7000rpm and pull away like the bollox!! Laughing
I think i will change the spark plug and clean the carb out. Cheers guys!!
Dylan
PostPosted: 18:04 - 06 Sep 2002    Post subject: Reply with quote
Probably get better when it warms up, when ive warmed mine up and take it into the powerband for the 1st time it holds back magorly at 6000!
Dyl
Phoenix
Twisted Firestarter
PostPosted: 18:05 - 06 Sep 2002    Post subject: Reply with quote
I havent had an NSR, but a lot of bikes have flatspots just before the power bad kicks in, its where the engine starts to 'race'. My TZR was at roughly 5000rpm, i wouldn't ride with the revs there because it just wouldnt run smoothly.
My FZR400 had a similar problem at 5-6K rpm but much more noticeable, just adjust your gears so you don't wind up sitting on it.
PostPosted: 21:33 - 06 Sep 2002    Post subject: Reply with quote
A flat spot in the midrange is normal. 2 strokes seem worse for it when the spark plug is getting old. Also, check the power valve is working and not stuck open
My guess is that a new plug will greatly reduce the problem
The last post was made 24 years, 78 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 67.59 Kb
