Strange ignition problem
Helen
PostPosted: 11:40 - 27 Sep 2004    Post subject: Strange ignition problem Reply with quote
Wonder if anyone could help. I have an old Honda CG125 on a K plate. The bike runs fine but I have a problem with the ignition. The bike starts up no matter which way the handlebars are turned but will only turn off if the handlebars are pointing forward or to the right. I can even take the key out and the engine will still be running if I do so when my handlebars are turned to the left. I have absolutely no idea on how to get to the ignition wiring (and no idea on what to do once I get to it) and the only bike mechanic around here would charge £35 just to look at it. The sad thing is, that I have had the bike for 2 months now and have never noticed the problem so don’t know if I have never tried to stop the engine with the bars pointing left or if it is a new problem. Has anyone ever had the same problem? I will buy a Haynes manual and attempt to find the problem myself if the ignition is easy to get at, or will have to get it looked at if not.
Helen
alains
PostPosted: 11:46 - 27 Sep 2004    Post subject: Reply with quote
it's obviously a loose contact on the wiring , look around any connector beetween the key and the battery (probably the connector at the key with the wiring scraping on the handlebar)
PostPosted: 19:09 - 27 Sep 2004    Post subject: Reply with quote
The ignition switch works to turn the engine off by earthing the ignition system through it. So if the earth wire to the ignition switch is broken the it will not stop the engine. My guess is that the wiring is broken and just happens to make contact when you turn the bars to the right, or the wire is hanging around and catches on the frame / etc when you turn the bars to the right.
alains
PostPosted: 19:34 - 27 Sep 2004    Post subject: Reply with quote
i was not talking about the kill switch (have a check too) but the key lock switch
Helen
PostPosted: 01:52 - 28 Sep 2004    Post subject: Reply with quote
Traced the wire back, the casing already had electrical tape on it and when I got it off I could not see any loose wires so I took it to the guy I mentioned earlier and booked it in for Friday. Won't cost nearly as much as I thought (£20) as he said what I have is probably a faulty earth. So he is only going to charge me an hours labour as it also needs a new netural switch which I believe he has to get behind the gearbox to fix.
Thanks for the advice.
Helen
PostPosted: 13:52 - 28 Sep 2004    Post subject: Reply with quote
Suspect they might just fit a new ignition switch (non original one for the older CG125 is about £11). Chances are that the problem is in the wire from the main wiring loom up to the ignition switch.
For the neutral light the sensor is probably next to the front sprocket. You will see a "bolt" with a small wire going to it. The wire probably attaches to the "bolt" with a small cross head screw.
The last post was made 22 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 49.14 Kb
